Question about HP Compaq ProLiant DL380 G4 Server
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Server: HP Compaq DL380 G4
Current HDD Size: 36GB 15K RPM
No of Drives in Server: 5
The DL380 G4 is set-up with 5 hard disks with the first two configured for the OS (C drive, Win 2003) {RAID 1+0 - Drive Mirroring} and the remaining 3 as RAID 5 (Drive E:).
Problem:
The first array C drive is running extremely low on Hard disk space i.e it only has 255MB left.
Solution Required:
To upgrade the current drives to bigger 146GB drives
HP - Hard drive - 146.8 GB - hot-swap - 3.5" - Ultra320 SCSI -15000 rpm.
I do have a spare Machine of the same make and model i.e HP DL380 G4 and a copy of Acronis Echo .
I need to know how best to install the new HDD and build the Raid Array and and copy the current hard disk Raid images (C drive Raid 1+0 & E drive Raid 5) to the Server with 146GB HDD.
Your help is very much appreciated
thank you
Lam Van lee
  • 3 more comments
  • lamvanlee Jul 25, 2008
    Dear Sirs,
    My machine is a HP Compaq DL380 G4 machine hence the Raid is different from the one you mentioned.
    It is in fact a HP Smart Array Controller (U320 SCSI RAID)
    What is the easiest and safest way to upgrade the hard drives 36GB---> to 146GB
    please advise of a solution
    thank you
    Lam vanlee
    Problem Questions:
    1. How do I upgrade c drive (2 HDD) Raid 1+0 Drives 36GB to ---> to 146GB Hard drives?
    2. How do I upgrade E drive (3 HDD)Raid 5 Drives 36GB to ---> to 146GB Hard drives?
    Summary of Server Hardware & Configuration
    My Hardware is:
    No. of Drives in the Server: 5
    Problem:
    Solution Required:
    To upgrade the current drives to bigger 146GB drives (so it reflects the same raid array setting though with bigger hard drives)
    My new drives are:
    I have bought 6 x of these.
    I need to know how best to install the new HDD and build the Raid Array and copy the current hard disk Raid images (C drive Raid 1+0 & E drive Raid 5) to the Server with 146GB HDD.
    thank you
    Lam Van lee
    ginko
    kindly note this is a SCSI Server server and has Raid implemtation.
    5 x 36GB U320
    SCSI Hard Disk Drives (HDD) are installed
    they are configured as follows:
    (Drive E:).
    I need a solution that allows me to upgrade the drives keeping the data intact as well as the Raid array.
    please help!
    thank you
    LVL
    Ginko, thanks for your support ,appreciated.
    Please tell me how I may image the SCSI hard drives since they are not ATA or SATA which can easily be connected via USB.
    SCSI is a different story and I have no idea as how to image these drives as i do not have a physical SCSI---> to USB tool.
    I do however have Acronis for imaging which is very much like Ghost (though much better)
    Your prompt help is much appreciated
    thank you very much
    LVL
    Thank you for your comments , I am fully compent with Acronis ( I have used ot for 3+ years for backing up Cloning images of ATA/SATA /SCSI to USB HDD drives mostly XP Pro & Windows 2003 Server)
    Though I am not comfortable with SCSI Raid Arrays. I feel very very nervous about it to be honest. I know I can use my SATA /ATA connector to USB to Backup & Restore. though I am not aware of any such kit available for SCSI to USB i.e for taking out the SCSI 36GB drives and imaging them and then restooring the image to the bigger HDD in this case the 146GB.
    Regarding your eariler comment about taking out the 2nd Raid 1+0 Drive and inserting the bigger 146GB drive. How will the raid array recnoiish this? will it not just try to mirror first 36GB drive to the newly inserted drive i.e 146GB? Sorry i do not follow, kindly explain, thank you.
    Also thank you very much for the HP links, there appears to be expired, kindly forward the more recent /relevent ones please
    many thanks for your kind help
    LVL
    Brigadier General:
  • HP Master
  • 3,614 Answers
Try to look at this Guide & Manual on "HOW TO"
Just let me know..
Hope my initial idea/info helps you..
Thanks,
micro
Posted on Jul 25, 2008
  • HP Master
  • 19,396 Answers
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
  • 2 more comments
  • Ginko
    Ginko Jul 25, 2008
    Check if you are usinc SCSI hard drives or ATA copy the whole image from master hard drive (36GB?!) into one of the other raid drives, I understood you have a 150 GB.
    Replace one of the hard disk with an empty 120 GB or more.
    Install the image from old primary HD on new hard disk, this will delete all files in new hard disk.
    Set new hard disk as boot disk in boot sequence in bios.
  • Ginko
    Ginko Jul 25, 2008
    Roughly you do the same, you save image from your boot disk, replace one of the other disks, on restart you probably get error invalid disk array configuration, to fix it re-configure array using array configuration utilty.
    Here you can download the software.
    Once the new disk is in Array, restore image on new disk and change boot options to use new disk as boot disk.
  • Ginko
    Ginko Jul 25, 2008
    If you have first two disks already mirrored,( ensure), then you can replace one of the two at time, set the new disk in array, copy image from the old disk and then replace the second disk.
    If you are mirroring them you will need to have the two hard disks of same size, thene ventually you replace the second one, configure array and check if mirroring need to be reconfigured.
  • Ginko
    Ginko Jul 25, 2008
    Well, Acronis works the same on SCSI hard drives, providing that you have the full version, you can copy from scsi to scsi, and I think also that it works from scsi to usb. Just backup the disk on one of the raid disksor on us.
    From Acronis website:
    "Also, you can clone from one manufacturer's drive to another; from USB to IDE; from SATA to IDE; from SCSI to PC CARD or IEEE 1394 (Firewire); or any combination thereof. "
    I will see if I can find detailed instructions.
Unable to boot HP DL380 G4 with display message no signal on the monitor
Just Clear NVRAM (by SW6 maintainance switch )/ else systemboard has to be replaced
Aug 11, 2012 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant DL380 G2 Server won't boot from cdrom
Hello, I think you might find more information on starting up the DL380 G2 at the link shown below:
http://h20566.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c00972124
Also, the replacement instructions, in case it needs to be replaced, (and relevant troubleshooting info) for the 5i controller are found in the link here :http://h20566.www2.hpe.com/hpsc/doc/public/display?sp4ts.oid=316587&docLocale=en_US&docId=emr_na-c00688182
Please first make sure that you are using the proper startup boot disk for the server before entering the CD ROM option from the boot menu. Also, check the front panel of the SCSI drives for any errors or blinking LEDS that correspond to an error code. You can run a diagnostics CD/DVD that arrived with the manufacturer's pack to detect any raid issues on startup.
If you are still facing difficulties with booting up the server, you can find a video for replacement of the appropriate scsi drive here if you are still facing any issues of your scsi drive. Try a different hard disk or check the relevant diagnostics to verify whether is the controller or the drive that complicates the booting of the server
For more details check the scsi manual in the link below (section "FBWC LEDs" , pages 15-17).
http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c04441382
May 18, 2012 | HP Compaq ProLiant DL380 G2 Server
Hp proliant dl380 g4 not booting from hard drive
I bought an HP DL380 G4 from here, and called them up any time I had a question like this. These guys were amazingly smart. Perhaps you can call them up and pretend to be a customer?
May 07, 2012 | HP Compaq ProLiant DL380 G4 Server
We can not boot up server. status are LED 2 3 8, what must we do?
Disconnect HDD cable from the Raid controller card.
Update firmware of the controller / replace controller.
that's it
Aug 26, 2011 | HP Compaq ProLiant DL380 G4 Server
I have HP PROLIANT DL 380 (G4). I removed hard disk. Its start and few seconds restart again. its happening continuously. Any solution.
need to provide moreinfo.
is the server (prolaint DL380) constantly rebooting within BIOS mode or has it got to the stage of running windows.
The other item not mentioned here, is, IF the raid controller has failed, you will not see any disks initializing and would cause the system to continually reboot.
If it is an internal raid controller, it is part of the motherboard, you will need to contact HP to have it replaced.
If an pci related array controller .. i.e. separate to the motherboard, this will need to be replaced to see the HDD's.
Either way sounds like a hardware issue. Best to liaise directly with vendor to have the faulty components replaced.
Sep 28, 2010 | HP Compaq ProLiant DL380 G4 Server
I have an HPL ML server with 146GB x 3 under RAID 5. I have 3 slots free. Now I need o add 320 HDD to these slots and configure different raid for them and to display the same as a different partition. Is...
dear mjabim,
it is possible...
actually raid has formed with hdd lun noand id nos ,
your old raid may formed with 1,2,3 id's
if you are adding these three disks
it will display as a physical dries in your raid bios and also it will not be covered under your old raid
you create one more raid array on your with those new disks
when you are these things , you have to do very carefully ...
for additional info please reply with raid card model for getting info about raid bios
Aug 11, 2010 | HP Compaq ProLiant DL380 G5 Server
Drive array problem
Hi Nick ,
As of now you can Select "F2" to accept data loss and re-enable logical drive. This Load OS Normally .
It seems that one of the HDD in the RAID 5 has failed , Did you notice any LED indications like red or amber on the HDDs ?? if so get that hdd replaced . Make sure the Failed HDD is replaced .
You can run the Array Diagnostic Utility from HP System tools to check the Failed Drives and also frimware version of the controller . If the frimware is not latest Update it from HP website. DL380 G4 should have Smart Array 6i controller .
Hope This was Helpful
cheers :)
May 17, 2008 | HP Compaq ProLiant DL380 G4 Server
Problem with DL380 G4 after reboot
do you use software/hardware raid?
hopefully hardware :-)
and is it mirrord or raid5?
Jan 26, 2008 | HP Compaq ProLiant DL380 G4 Server
Hard disk space
Check on the HP website for BIOS updates and Firmware updates for your raid controller. This sounds very odd that there is a 28GB limitation on drive size? What size drives are in there now? They usually step up in size like 9GB, 18GB, 36GB, 72GB, etc.... Your IT guy maybe misinformed.
Oct 16, 2007 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant DL380 G4 Server Logo
1,364 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
