MONITOR Hello fellow tech. It's Abi again in regards to the RAD-5S Monitor, I forgot to tell you that I'm a tv repair technician. The reason that I asked for assistance is because I don't have the service manual for this unit and I was wondering if you had a repair tip for it. Thanks in advance for your help. My regards, Abi AR Audio/Video Tech Luquillo, PR 787-889-5246 email: lopezreyes@prtc.net
  • Abimael Reyes
    Abimael Reyes Jul 25, 2008
    thanks for your assistence.
  • 3,940 Answers
Nope
I leave the CRT's to someone with electronics training (Something I lack) and documentation of KDS items is pretty hard to get.
SOrry I can't help/
Posted on Jul 25, 2008
Hello, I have a Kds Radius RAD-7C monitor and the original power supply is no longer working. I have a universal power supply with a range from 15 to 24 volt and 6 amp, my question is, can I use this for...
6A is OK, HIGHER CURRENT is OK but not higher voltage, the main key is that the pwoer supply MUST be REGULATED power supply. Does it say that on the universal power supply that you have?
Basic LCD monitor and LCD TV troubleshooting guides:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed LCD monitors, LCD TV's pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Dec 20, 2010 | KDS Radius RAD-7 17" Flat Panel LCD...
How can i used my crystal eye webcam on windows 7
I would suggest you to try downloaing the web cam drivers once again. Install the drivers in Windows 7 compatibility mode. You can download the drivers from the following website:
http://www.liutilities.com/device-driver/acer-crystal-eye-webcam/
Regards,
Aby
Apr 23, 2010 | Computers & Internet
No audio in my sony vaio vgn-sz1xp/c,can anyone tell me howto trouble shoot?
May be the sound drivers are missing from your system.
I beleive installing the drivers would resolve your problem. Visit the following link and download the sound drivers again on your system. This would resolve your issue http://download.cnet.com/Realtek-AC-97-Audio-Driver-XP-W2K-W98-WDM-driver-VER-5-10-0-5554-zip/3000-2110_4-210198.html
On the website select the appropriate driver depending on the Operating systen being used on your Laptop.
Regards,
Aby
Apr 22, 2010 | Computers & Internet
I accidently plugged something into the Service UART and now my TV doesn't work. What can I do to fix it?
The Service UART is used to make internal adjustments or updates to your tv. It is intended to be used by service technicians only.
Since you accidently plugged something into it, it's possible that an internal component has been damaged. Your best option is to call a tv repair shop have have a technician check out your tv.
Hopefully, your tv hasn't been damaged and the tech can get it working again. At the very least, the tech will be able to tell you exactly what's wrong with it and what it will cost to repair it.
Aug 14, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
RAD-9p shuts off for no reason
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 23, 2009 | KDS Radius RAD-9p 19" Flat Panel LCD...
KDS FLAT MONITOR
best I can tell, the Rad 5S is out of warranty, and you appear to be having a problem with the image inverter.
#1 Try the monitor on another system and ensure that the issue is the monitor, and not the video card it is attached to as the point of failure.
#2 If the monitor appears to be failing, contact a local TV repair shop on a repair estimate. Likely answer is that you can buy a larger better monitor cheaper than you can get the one you have repaired, even if the parts cost is low, due to the bench fee/labot cost of repairs.
Here is one site I like for monitors:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010190020+4017&name=%24100+-+%24200
Jul 24, 2008 | Computers & Internet
LCD Screen problem
You have a failed inverter circuit. This is a very common fault with BenQ and other LCD monitors. I have seen more FP737 and FP731's and all their cousins in the last 2 years then I care to count.
You will be best to take it to a TV technician and have them do the repair. There are ways to fix it yourself, but the chances of success are not great without a decent amount of electronic knowledge.
Call several places and get approx quotes based on the inverter fault. A lot of TV techs will not work on LCD monitors and is another good reason to call around first.
One final thing, check the manufacture date on the back of the monitor, these normally come with a 3 year warranty and it will be either expired now, or very close to it. If it is still under warranty, then contact BenQ near you to facilitate the repairs.
BenQ support webpage.
Apr 15, 2008 | BenQ FP731 17" LCD Monitor
Dell computer screen blacked out
Hello Sir,
Can you see any dull image on the screen, if yes, then The problem is with the inverter board in the LCD Screen,
Regards,
Aby
Dec 21, 2007 | AOC LM729 17" LCD Monitor
Problems with monitor settings
You need to replace the front panel control buttons,
Regards,
Aby
Dec 21, 2007 | iiyama LS 704U 17" CRT Monitor
Computers & Internet Logo
474 people viewed this question
David Payne
David Payne
