Question about Sony STR-DE485 Receiver
Equalizer connections I have a RCA equalizer Radio Shack # 31-5001and a Sony DE-485 and cannot get them to work together, HELP PLEEEEASE !! P.S. I'm old in years but new to stereos THANKS,
    Novelist:
    Champion:
  • 218 Answers
Usually you hook your equalizer between the pre out and main in RCA jacks and then open the connection between the pre and main with a switch. If your unit doesn't have pre out/ main in jacks then I have seen it done by putting your equalizer between the tape in and tape out jacks and then select that tape function on your front panel. The tape out goes to eq. in and the eq. out goes to tape in. Good luck.
Posted on Jul 26, 2008
I tried to install my boss Ava 1210-7 equalizer but I have a 2din001 radio i have a rca jack plug at the back of the radio say AV in its 3 jacks red,white and yellow. I only connect a rca jack to the red...
Regardez bien au derriere des file rca son ecrit in ou out dans le radio bracher le fil blanch out et fil rouge out vers au in de l' ampli le jaune fonctionais image que ce soit in ou out si le son et marche ou ne marche pas vous avez de probleme circuit son verifier
Aug 15, 2017 | RCA Televison & Video
The 1/4" headphone jack broke on my Sony STR-DE 485 receiver. How do I replace it and what it the part number?
1-683-763-11 is the p/n for the headphone board. Should be easy to replace. Just unplug the old one, take take the screws out, and put the new one in.
Mar 30, 2013 | Sony STR-DE485 Receiver
Need manual for TRC 484
Radio shack doesn't list that radio for having a manual but there is one for the trc 485
Oct 28, 2011 | Radio Shack TRC-447 CB Radio
Pls send me a connection diagram of how to connect my dbx 215 graphic equalizers to a powered mixer
ftp://ftp.dbxpro.com/pub/PDFs/Manuals/English/dbx2SeriesManualA2.pdf It's all in there. Here is a little extra guidance. if you are getting your left and right channels out through RCA you will need a RCA to 1/4 in adapter Radio Shack carries them relatively cheap. If it's already 1/4 or XLR skip this Left goes into Left in, Right goes into Right in. Then work backwards Right comes out of Right out, Left comes out of Left out. channel 1(left in) and Channel 2(right in) of your powered mixer. you should be set.
Good Luck, Cody J.
Dec 16, 2010 | DBX -215 Home Equalizer
The digital sound is off after 1 houre str de sony str de 485
It sounds like the receiver is either failing or going into a thermal protection mode.
There should be NO reason why the input source (digital versus analog) should make a difference unless you play the digital sources obscenely louder than the analog ones.
If you suspect heat, you should be able to feel it.
Can you verify that the digital sources ONLY do this?
Mar 01, 2010 | Sony STR-DE485 Receiver
Mono
http://www.radioshack.com/product/index.jsp?productId=2102978
http://www.radioshack.com/product/index.jsp?productId=2102977
What you need is one of each of the RCA Y-adaptors like at the above links. Radio shack probably has non-gold cheaper ones in the store. on the one that is radio shack model #42-2608 hook the two 'female' connectors to your turntable's red n white RCA outputs. then take the radio shack model 42-2609 and hook the two 'male' connectors to your serato. finally connect the two Y-adaptors together in the middle! This merges both channel but keeps them both equally going into your serato so that no actual musical info is lost.
Feb 11, 2009 | Technics SL-1200 Turntable
Connect Bose 901 VI EQ to a Harmon Kardon AVR 247 Amp
Similar problem...I came up with a solution with help from Onyko. For my receiver, at least, the bottom line was that the output from the equalizer MUST go to 'Receiver, Tape In'! Since that is the ONLY input source from the equalizer, you must combine elsewhere. Part of my setup included the Radio Shack Audio/Video Selector box which costs $21.99...you might not need it, but in my case, I couldn't plug all components into the back of the receiver and have them go through the equalizer.
Since I have a satellite receiver, DVD player and TV, that I want to route through the equalizer, here is the way mine is set up and working:
Satellite receiver and DVD player out to Radio Shack audio/video selector
Audio/video selector out to VCR in.
VCR video directly to TV
VCR audio red/white (audio) out to equalizer
Equalizer out to Receiver Tape IN (Receiver Out not used)
Hope this (or a variation of it) helps.
Nov 17, 2008 | Bose 901 VI Main / Stereo Speaker
Dont know how to connect everything so it all works
you need a small mixer from radio shack near you.
1-connect cd player to channel 1 in mixer.
2-connect tape to channel 2 in mixer.
3-connect mixer out to equalizer in.
4-connect equalizer out to amp in.
Nov 09, 2008 | Audio Players & Recorders
Sony rear projection tv How to de-solder
I would suggest not to desolder that transformer until you are certain that is defective.
Try to change D6116 and D6301 first.
You can try Radio Shack or check this site.
Good Luck.
Apr 10, 2008 | Sony KP-57WS520 57" Rear Projection...
DVD/TV Combo - Won't read DVD
Compra el disco limpiador de laser que vende Radio Shack,si con eso se soluciona tu problema que bueno si no llevalo a un centro de reparaciones.
Oct 17, 2007 | RCA F36645 TV
Sony STR-DE485 Receiver Logo
336 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
