Question about Certance (CL1001-R) Ultrium Tape Drive
Ultrium tape stuck
I have a certance ultruim tape drive and there is a tape stuck in the drive. I have tried using the Backup Exec software to eject the tape but it did not recognize there is a tape in there. I have rebooted the server hoping the tape would eject but no luck. Any ideas on how to manually remove a tape?
  • 1 more comment
  • aduval Sep 23, 2008
    Quantium support told me to disconnect the SCSI cable and reboot, hold the eject button for 30 seconds during start up. This did not help.
  • Benjamino Dec 31, 2008
    If it is anything like I have, I have a CL1001, and the loading gear has cracked so the drive is unable to eject the tape.
  • Anonymous Apr 06, 2009
    also have a stuck tape...
    disconnecting scsi cable and holding eject at power on didnt help
  • 922 Answers
I highly recommend that you contact Certance for assistance. Tape drives are expensive and you don't want to risk damaging it.
If you are feeling brave you could see if you can manually eject the tape.
Remove the tape drive from the chassis and look for a manual rewind screw on the bottom or back of the drive. This is provided on some drives to allow you to manually wind the tape back into the cartrige and eject it.
I hope this helps.
Posted on Aug 11, 2009
Backup tape(RDX) getting ejected automatically after sometime while backup job is not running.
RDX tape drives, by HP (tandenberg)
did you reload all that HP software and drivers fresh?
did you try fresh tape.
i replace the tape drive, (new , used, NOS , from whom, ebay)
i bet the tape drive, logs errors, if you look,
the driver software will log that, and you can see why the tape
failed, my guess, damage to the tape, end to end.
try fresh new tape, NEW in a box, not used.
Oct 13, 2017 | HP Computers & Internet
Tape cannot eject
This is usually because it is in use still. If you cannot see anything still trying to access the drive (backup software for eaxmple) you could try powering down the tape unit and rebooting the machine that it is plugged into the turn the tape unit back on and see if it will now eject.
Thanks
May 09, 2011 | HP StorageWorks Ultrium 960 Ultrium Tape...
LTO Ultrium 4 Drive/Lecteurs stuck in it
Check that 'Prevent Media Removal' is disabled
Check the Support Ticket Device Analysis for indications of a stuck tape
Run the L&TT*** "LTO Stuck Tape Test"
Try a normal eject operation--Make sure that you allow up to 10 minutes for completion
Perform an Emergency Unload
Reset the drive to reset the drive firmware
Use Library and Tape Tools (L&TT) to Upgrade your Firmware
***Download LTT from www.hp.com/support/tapetools
Jul 29, 2010 | HP StorageWorks Ultrium 960 Ultrium Tape...
Certance DAT 72 tape drive stopped communicating with PC
We have had the same problems with HP drives and Veritas. In our case it was not the drive per se. While I am assuming that based on the date of your post that you have moved to another solution, however, I will provide for you what we did.
First shut all down, disconnect the tape drive from the scsi cable, then restart. Go into computer management and turn all your backup exec services from auto to manual. Now go to devices and do a rescan. Once this is done and you see no tape drive whatsoever in the devices shut down the server. Reconnect the scsi cable to the drive and restart.
Go back into computer management, back to devices and rescan for hardware changes. Do you see it? If so, good! Sometimes a re-seating of connectors will do that. On the other hand, it could also be a tape driver from Veritas that just doesn't work (my case), take the original driver cd that came with the unit and start that loading up. Can you see it now? Can you use windows backup to access the tape drive? Now go into services and start the services individually. Go into backup exec and see if you can read your tape. Go back to services and reset all services back to auto. If you ever have to reinstall/upgrade backup exec, think twice about using their drivers.
Nov 12, 2009 | Certance Internal DAT 72 (cd72lwh-s) DAT...
I am unable to get IBM UlTrium TD4 SCSI device drivers for windows 2000 server
if you "have not" using Backup Software (e.g. Symantec Backup Exec, CA), you can try this IBM LTO-4 driver for Win2K.
IBM LTO-4 Device Driver for Windows 2000
Ned Huang
Tandberg Data Taiwan
Technical Support.
Oct 15, 2008 | Computers & Internet
Tandberg LTO HH (LTO-3)
The error is because the driver isn't loaded for the device. Look up how to add the device in symantec help. If windows recognizes it already then usually you can go to devices and add teh device from within symantec.
Jun 03, 2008 | Tandberg Data 200/400GB 420LTO LTO2...
Certance Ultrium 2 tape drive
have you checked to see how much data is being backed up? Also what software are you using - it all depends on encryption
Apr 18, 2008 | Certance (CL1001-R) Ultrium Tape Drive
40 GB Data backup cartridge keeps ejecting
When was the last time you cleaned out the tape drive. You could get errors like that if the drive is dirty! Regards, Armando
Apr 23, 2007 | Certance Travan 40 GB (stt3401a-sst)...
Certance (CL1001-R) Ultrium Tape Drive Logo
2,492 people viewed this question
Top Certance Computers & Internet Experts
David Payne
David Payne
Are you a Certance Computer and Internet Expert? Answer questions, earn points and help others
