Question about NEC VT460 Multimedia Projector
1 second in betweent flash
About 1 second in between flash
  • 10,594 Answers
Thats ok, In my openion, projector has power supply problem. Please open it and check fuses in secondry power area. Atleast one fuse is open there.
Posted on Jul 25, 2008
Hi i have a sharp aquos lc-37d43u tv and I can't get it to connect to my computer .I tried HDMI and VGA but I just don't seems to understand how to make it work ;( Please HELP
prob with sansui sty 0330 LCD TV
hi,i have a sansui sty 0330 tv and the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Dec 18, 2013 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
Sansui LCD TV STY0332Flat cable connecting Ti-con board to LCD panel. 35mm x 80mm.
hey i have a sansui sty 0330
hi, the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Jul 18, 2013 | Televison & Video
How to switch off engine service waring display
G'day mate i think you will find only the dealer can using a special little resistance tool which are normally to expensive for the average garage, take it for the service it new enough to look after
Apr 04, 2010 | 2009 Nissan Altima
What should the fuel pressure be on a 2004 Ford Freestar?
Ford states it should be betweent 35-70 psi
Mar 23, 2010 | 2004 Ford Freestar
Number one cyl on coil pack not firing, all others are, codes reads misfire on 1 cyl should i replace the coil pack and how do you test the pack
Check the spark plug first. then if the plug is good you wil need a digital ohm meter to test the coil pack. if you need to know how to remove the coil pack let me know, to test put on ohms should not have more than 2 1/2 ohms restance betweent coil lead to coil connector. If you test the coil pack on both sides of the pack and get a reading then the coil is bad, if it does not read then you haave a bad fireing plate diode.
Mar 12, 2010 | Ford Explorer Cars & Trucks
2002 bmw 530i key does not (remotely) unlock doors or trunk but they work fine manually.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
Mar 09, 2010 | 2002 BMW 5 Series
Tune-up between what mileage range
Most manufactures say up to 100,000. However I look at the plugs after 40,000. airfilter and pcv every 12,000.
Jan 22, 2010 | 2002 Nissan Frontier Crew Cab
Electric dryer leaving brown marks on clothes
i would asssume that the marks are "crescent moon" in shape??? if so either the front or rear felt has/is going bad and casuing clothes to slip betweent the tub and the seal causing the streaks
Mar 14, 2009 | Whirlpool Dryers
Connecting a labtop to the modem
Can you provide the following details:
1. Are you attempting to connect via wired or wireless?
2. Is your laptop configured with a static or DHCP address?
3. If Wireless, are you using WEP or WAP, and do you have matching credentials betweent he router and laptop?
Dec 30, 2007 | Zoom 5515A (55150200A) Modem
NEC VT460 Multimedia Projector Logo
Top NEC Office Equipment & Supplies Experts
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
