Question about Microsoft Office Outlook 2003 for PC
VCR picture I have an older RCA vcr. Some tapes are perfectly cleal others are all snowy. I have used a head  cleaner and nothing changes.Is it the tapes or the machine? they, the tapes don't have that problem on other machines. Can you please advise. Thank you
  • robandme Jul 26, 2008
    They are all older tapes and the TV reception is fine (without  the vcr tape playing) These same tapes play fine (all of them) in another VCR
  • 876 Answers
It has to be the machine or the TV. Have you purchased a new tv? The old vcrs seem to last forever and run fine. And if some of the tapes work and others don't, that is a bit strange. Is it the newer tapes that work?
Posted on Jul 25, 2008
  • Gayle Ashbach
    Gayle Ashbach Jul 26, 2008
    The VCR must be malfunctioning then. You might try a good vacuum job with a teeny computer vacuum if you have one, or you might just try blowing dust away from inside like with a hairdryer on cool.(Unplug the VCR first!) When I know something is a goner, I'll try most anything. It could have a lot of dust inside or some tiny object.You might want to look around at a "Junk" store to replace it, since so many people are giving theirs away. At Goodwill you can return it if the tags are still on it. So you could try a used one to replace it and see what happens. I can't give up all my old tapes. I have so many that I love, and I'm afraid I will run out of anything to play them on! Good Luck to you.
EWC19T5 problem and solutions'
You need to clean the video head. Though you can buy a tape head cleaner tape, it's much better to take the top cover off and spray the head with Servisol Video 40. Make certain it's dry before putting a tape in.
Jul 14, 2013 | Televison & Video
Tip
Vcr snowy picture
here is a old tip your vcr has a snowy picture and has audio.problem is dirty heads if you don't want to take it apart put a movie in and press play then rewind search and let it go. you will see the pic. come back in revese the tape is cleaning the video heads
on Nov 02, 2011 | RCA Televison & Video
When I record a movie on the vcr it plays back snowy.
Ur VCR signal recorded free air throught an DTV converter box?Yes,this cause is normal,because VCR player have no digital tuner on the VCR player by itself,on it circuitries design.If recorded throught pay cable signal.Yes,than ur VCR video head player is dirty needed to be clean.Tries websites like Amazon.com,Ebay.com to buy a VCR video head cleaner vdeo tape.Just play it as normal as a video tape,when the video head clean,VCR will display clean head eject tape now.
Aug 03, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
When I place a vcr in my machine all I get is a snowy picture. Why would this happen? The DVD player works but not the VCR
Make sure the tape you are trying to view has something recorded on it. Also insure that the tape you are trying to view is not recorded at a speed your DVD Recorder/VCR combo can not handle. If it is a pre recorded tape and it will play on another unit, then your VCR heads are dirty. Try using a VCR head cleaner. If that doesn't work the heads may need to be cleaned by hand or possibly may be bad, a trip to the repair shop would be call for then.
Jul 01, 2010 | Emerson EWR20V4 DVD Recorder/VCR
No video on VHS tapes playback. on a Zenith VR4257HF
Sounds like the video heads are worn and time to replace them. You can try Asti Magnetics. The part number you are looking for is "378". Sells for $55 plus shipping. A bit cheaper but quality parts. I've dealt with them in the past. You can decide if the VCR is worth it to repair.
May 02, 2009 | Zenith VR4257HF VCR
Very snowy picture when recording or watching video tape
If there is snow from the VCR only when the tape is being played, it is possible that there is a head clog or dirt on the heads.
If the head is clean and there is still snow from it, this means that most likely it is faulty.
A service tech who is experienced at servicing VCR's can connect a scope to the pre-amp test points, and run his calibration tape. With this he should be able to look at the signal carrier envelops on the scope and see if there are any faults.
At the same time, he will also see if there is a fault with the head pre-amp area. I've rarely seen any faults in the pre-amp area.
An experienced tech who works on VCR's can change the head for you. This is time consuming because he will have to go through all the guide and tracking alignments with the scope and test tapes.
A problem with most VCR models, unless it is a high end industrial model, most manufactures are no longer supplying replacement parts. They are telling the people to buy a new machine.
In reality, it may not be cost effective to service your VCR. You may end up buying a new one.
Jerry G.
Jun 13, 2008 | Panasonic PV-V4022 VHS VCR
NEC VH-605 VCR - Very Snowy Picture
Video head needs thorough cleaning. If no head cleaner, then run a few long tapes through it in the fast scan mode since the tape itself is abrasive and will over time remove debris from the heads. If that does not do it, try a chemical cleaner to dissolve the material.
Sep 01, 2017 | NEC Audio Players & Recorders
Emerson ewc1302 13 in. tv/vcr combo problem
We had that same problem. Try a VHS head cleaner. Worked for us.
Oct 24, 2007 | Emerson EWC1303 13 in. TV/VCR Combo
No picture
This type of problem may be caused by a dirty video head, people some time try to adjust tracking to take care of this problem this is a mistake. Now to clear up this issue first you put the tracking control mid way in its setting, then you clean the heads of the VCR you can use a head cleaning tape (follow the instructions on the cleaning tape box)for this or if you have experience you use a chamois swab type cleaner (follow the instructions on the package of swabs and liquid cleaner). one the heads are cleaned you acn then try to adjust track to obtain the best picture. If you can not you may have video head problems or a problem in the drum motor (servo) mechanism. In which case I advise taking the unit to a TV repair shop.
Sep 13, 2007 | RCA VR552 VHS VCR
Microsoft Office Outlook 2003 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
