Question about ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
COMPUTER ON, BUT NOTHING HAPPEN, EVEN BOOTING
I installed all the component in my computer myself. After I push the power On, the LED indicator in the MBoard is on, but nothing happen in the monitor. I didn't see the computer booting, but all the LED in front panel are on.
  • saddlebumVR Aug 31, 2008
    i have the same problem the book says board does not support double sidedX16 memory modules and this is what the dealer sold me.I am hoping this is the cause.Is this a possibility ?
    Master:
  • 763 Answers
Are all the wires connected correctly? if it is, then try to see what is incorrect connection on your motherboard it must be the RAM(memory) or the processor. see also the connection between the monitor to the computer. if it still not working then try to remove the memory and then switch it on without it. you will hear a sound, if you dont then your memory is the problem.also see if the video card are correctly connected too. hope that helps!
CHARCOIS
Posted on Jul 25, 2008
Led 1 and led 2 both are red, what does that indicate?
Led 2 flashing indicates the the computer is undergoing POST (testing components). If it flashing then something is wrong, usually the computer beeps a cumber of times which translates to a code eg ram error.
When led 2 is stable, the computer completed POST and is booting up through bios and then the OS.
Led 1 on which means the computer is receiving power.
See Manual: http://global.aopen.com/userdownload_List.aspx?RecNo=10062&Model=1258
Nov 30, 2010 | AOpen i945Ga-PLF (918EA10I40) Motherboard
My Dell XPS 410 computer will not start, won't do anything.There is however an LED light on the Motherboard labled Stdby Led, this is lighted but the compter won't do anything? I am needing someones...
Your computer power button may not be working, or the CPU may be bad and it can also be the motherboard is faulty.You need a new case or fix the power button or try another CPU in the computer or replace the motherboard.
Aug 16, 2010 | Dell XPS 410 PC Desktop
No power
An AT power supply must have current draw to turn on. Remove every component not needed for boot ( Floppy, Hard, CD DVD Fan. Leave on Motherboard and CPU and Fan. With header connections connected ( HDD led, PWR on, PWR Led and speaker ) push the on switch and make sure the back of supply doesn't have a switch. Does anything happen? Write me back if you want and we'll try to get some juice out of the supply.
Jun 28, 2009 | Computers & Internet
Acer Aspire One Zg5 will not boot up no indicator light come one
Hi there.
Try taking the battery out and booting it on AC power only, if it boots up turn it back off and reinsert the battery, turn the computer on, if it boots up all good, if not please post back.
Good luck
May 21, 2009 | Acer Aspire 5100 Notebook
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
Gateway 7330GZ wont boot
for me this is the try and test situation,
try to remove ram -- look what happen. or try to turn on the laptop with the xp cd in the drive rom, there a similar case and the problem solved after i take out the keyboard and put it on again.
Jan 18, 2009 | Gateway 7330GZ Notebook
Compaq presario 2500 notebook won't boot
This sounds like a weird solution, but it worked for me. I recently bought a used Presario 2500, it worked when the guy showed it to me, when I got home it didn't work two days later. I tried several tips from the web, finally I started pushing several buttons randomly. I pushed the Email (Envelope) button, and the computer powered on suddenly. Now, the Envelope button is the only button that will power the computer on. When the computer is on, that button will also bring up Outlook, but when the computer is off, that button turns it on. Let me know if this fixes it for you.
Dec 11, 2008 | HP Compaq Presario 2500LA Notebook
Satellite 2430 wont boot. when the start button is pushed nothing happens
Dear Customer,
1.if no sound
2.no led indicator lights up
than definatly its a power supply problem check your SMPS at top back side of your cabinet .
disconnected SMPS than ckeck its power supply at different ports.
THNX
May 17, 2008 | Toshiba Computers & Internet
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
61 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
