Question about Refrigerators
Adjustment for defrost control - GE Monogam
I installed a new WR9X502 defrost part in my 8 yr old GE Monogram. The technician said they go out at this age, and suggested I could install it myself (which I did - very easy). However, he did not tell me there is a small adjustment hole that can be rotated clockwise by a screw driver.
Question: How do I know how much to rotate that adjustment?
  • rayandhelen Jul 28, 2008
    The solution posted on Jul 26 by 22yooper was helpful, but I need a little more clarification.
    When the part was installed the frig would not come on at all until I rotated the clutch head screw slightly clockwise.
    My only remaining question is ---how far should it be turned???
    Does the rotation of this screw simply select a time of day to defrost - or does it select an interval of time between defrosts??
    Thank you very much. Ray Irwin
  • rayandhelen Jul 29, 2008
    Thank you very much! You've been very helpful!
  • 828 Answers
You should not have to adjust this clutch head screw. And it turns counter clockwise to change the time of defrost.
Posted on Jul 26, 2008
  • 1 more comment
  • James Helmer
    James Helmer Jul 26, 2008
    Sorry about that, it is clockwise.
  • James Helmer
    James Helmer Jul 29, 2008
    The screw turns a cam. To begin, the defrost timers are shipped in the defrost position. If you had waited 18-22 minutes after you finished installing the new defrost timer it would have automatically restarted the cooling cycle.
    It depends on what method the manufacturer of your refrigerator uses to time the cycles. Some use run time of compressor to determine how often the defrost takes place and some use strictly the time cycle. In any event all things should now be automatic and a defrost cycle will never under normal condition be noticeable.
  • James Helmer
    Glad to be of help. Its nice to be needed.
Defroster not working
The WR51X322 Defrost Heater Assembly
could be burned out in your model. Can you look inside the fresh food section and find the model number for me. The answer to the problem on your model depends on having the correct model number so I don't miss other parts that may cause a defrost failure. I know you said Monogram Side by Side but that does not tell me for sure what the Model Number on your refrigerator is. If your model is like the models in the GE Monogram Refrigerator Service Manual the I can have an idea of those parts. Those models have the defrost controls as part of their motherboard and that board does not fail at least in the defrost part of the board. defrost very often. You may need to also test or replace the WR50X10088 Defrost Thermostat I will be here should you have questions Thanks Sea Breeze
Apr 07, 2013 | GE Monogram Side by Side Refrigerator
GE Monogram ZISW36DYA ... frozen ice-cycle rivulets run down both sides of freezer (water off for days to verify it is not ice maker) ... defrost control clicks when rotated and advances with time ... do...
Seems to me that might be a clogged defrost drain or maybe a dripping water valve. Doing that. I have the service manual with nice pictures in it that show clearly how to access the components.
GE MONOGRAM SERVICE MANUAL
Nov 10, 2010 | GE Monogram Side by Side Refrigerator
GE Monogram Freezer wont defrost
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 30, 2010 | GE Monogram ZDI15C Automatic Icemaker
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
heatman101
Mar 30, 2010 | GE GTS22KBP Top Freezer Refrigerator
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram Fridge/Freezer
A frosty freezer in the back panel is an indication of a defrost failure issue. Problem may lie in the the control board, heater or defrost terminator. The problem usually is a broken defrost element. Hope that helps :)
http://tclaundryrepair.com/
Feb 25, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
Refrigerators Logo
503 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
