Question about Honeywell Heating & Cooling
Cells were cleaned, installed and now constant snapping, checked wires and plates nothing broke, wires are ok. what to do? honneywell electronic furance filter
  • 182 Answers
If it is totally dry and still snaps.....one of the plates is probably bent.Check the cells to make sure the gap between the plates is consistant.
Posted on Jul 25, 2008
A red light flashing with clean filter
bad connection on plates or wires that run along the front of the plates in the cell. If you hear snapping or arcing then its the plates shorting out, look for bent plates and broken wires or loose sagging wires.
Aug 01, 2014 | Oreck XL Professional Air Purifier
Dear Expert, I do hear scary sound like a electric spark once in a while, and then stop. Should I turn off the switch? Thank you.
Arcing (snapping) seems too frequent
1. If the electronic cell(s) are wet from washing, turn the air cleaner off for two to
three hours.
2. Check the cell(s) for broken ionizer wires or bent plates. Repair if necessary.
3. Wash cell(s) and prefilter(s) if dirty.
Sep 28, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
How do I clean the Oreck Air 7
Hi There,
Here's how you can clean the machine, and I have copied the link to the owners manual below for your convenience.
Cleaning
The Cabinet
You can clean the air purifier cabinet with mild, non-abrasive cleanser and a
soft cloth. IMPORTANT: Unplug the unit from its electrical power source.
Do not spray cleansers or furniture polish into the louver or grill areas.
Collector Cell
Indicator light is green under normal operation and flashes red
when the cell requires cleaning. To clean, proceed as follows:
The red "WASH CELL" light will flash or illuminate when it is
time to clean your cell. However, it is recommended that every four to
eight weeks or if snapping sounds become frequent, clean your
electronic air purifier. Your electronic air purifier is still filtering the air
when the red light illuminates. Cleaning your electronic air purifier is a
snap too... and a must for efficient operation.
1. Turn the unit off and unplug it from the electric power source. If wall
mounted, remove unit from wall.
2. Remove front grill by unscrewing the retainer screw under the grill on
the cabinet bottom. (fig. 1)
3. Pull the cell out of the cabinet by using the two small handles on the
front of the cell. (fig. 2)
4. Snap off the charcoal odor absorber from the back of the cell. Change
as necessary for continued odor removal. (fig. 3)
5. Slide off pre-filter. This can be cleaned with the cell and reused. (fig. 4)
NOTE: Handle the electronic cell with care. Damaged metal plates
and/or broken wires will cause the air purifier to malfunction. (Do
not wash charcoal odor absorber; it is disposable.)
Cleaning with Assail-A-Cell® Cell Cleaner:
6. Using Assail-A-Cell® Cleaner, thoroughly saturate the cell and prefilter.
Be sure to spray between each cell plate and cover every
surface. Allow product to soak for a few minutes, not allowing it to dry.
Rinse thoroughly with water. For extremely heavy deposits, repeat the
process.
IMPORTANT: Dry the collection cell thoroughly outside of the
air purifier before reinstalling it into the air purifier. Ensure
that all areas including corners and areas that may trap
water are dry before reinstalling into the air purifier. DO NOT
process.
place a wet or damp collection cell in the air purifier.
Here's the link to the owners manual for your Oreck Air 7:
http://www.oreck.com/includes/customer-service/owners-guides/pdfs/3323-3018-AIR7-Rev-H.pdf
I hope this was helpful to you. If this helped, please be kind and rate the repair, or leave feedback for me. Thank you,
Chris Jones
GoVacuum.com
May 01, 2010 | Oreck Super Air 7 Air Purifier
I have a F50E electronic filter. The light comes on, but there is no snapping sound when I push the test button. The cells and wires look ok. What could be the problem.
It's possible that the board is at fault. Triple check and make sure all the ionizing wires are in place on both cells and that the thin collector plates are not touching each other. Also, make sure the contact points are clean on both the cells and the cabinet.
The F50 is an obsolete EAC, so parts are becoming difficult to get. If the board is bad, I would recommend unplugging the unit and using a MERV 10 media filter in its place (Honeywell designed that EAC with the same cabinet as the media filter... all they did was add a power pack on top for the EAC. The media filter will slide directly in the cells place.) You will get better filtration with much less maintenance.
Mar 24, 2010 | Honeywell Air Purifiers
The Honeywell electronic air cleaner constantly "snaps" even though it is clean. I have inspected the wires and fins, clean and spaced properly. Any suggestions?
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal .Remove both the cell and check clean the bottom portion by using a vacuum cleaner attachment. If the snapping continues with the cells remove contact your contractor.
Mar 05, 2010 | Honeywell (F50F1032) Air Purifier
After cleaning my electronic filter, it runs well for about a day. Then, it begins to continuously arc until I wipe the wires clean. Again, no arc for awhile, then, continuous arcing. Is there something I...
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal however, and should be investigated as outlined below: Please note that the metal electronic cells may have some sharp edges; use care when handling the cells. Wear gloves to protect your hands from being cut if needed. Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can. Do not vacuum the Pre-filter or Post filter this may damage it. Close the access door, and then turn on the Electronic Air Cleaner and the system fan. If the snapping continues with the cells removed, contact your heating and cooling contractor for service on the unit and turn off the Electronic Air Cleaner’s power. If snapping does not continue, make sure the electronic cells are clean, dry and properly installed. Inspect the electronic cells for bent collector plates, broken wires between the plates, dirt on the insulators, and damaged collector contact tabs located on the top of the cells. Make sure the pre-filters are in good condition and are in the cabinet slot farthest from the furnace (The order of the Electronic Air Cleaner Filters are from the return duct to the furnace is: Pre-Filter, electronic cell, and then Post filter, if your Electronic Air Cleaner has one). If the snapping persists and you are unable to locate any physical cause, please contact your heating and cooling contractor for service on the unit and turn off power to the Electronic Air Cleaner.
Jan 25, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell F50e electronic air cleaner indicator light stays on
Could be a faulty sail switch in the air cleaner that keeps the air cleaner on even without air flow.
Dec 20, 2009 | Heating & Cooling
Filter not clicking or emitting clean air smell and dust is flowing like filter is not energized
MAKE SURE THAT YOUR CELL(S) ARE CLEAN ... CLOSELY INSPECT TO SEE THAT THERE ARE NO BROKEN IONIZING WIRES (THE SMAAL STAINLESS-STEEL WIRES THAT ARE BETWEEN THE COLLECTOR PLATES). MAKE SURE POWER GOING INTO UNIT TO IS "OFF"!!! ... NOT JUST THE SWITCH ON THE UNIT. THEN TRY THE FOLLOWING: THIS AIR-CLEANER THAS A AIR-FLOW SENSOR THAT SOMETIMES GETS CLOGGED ... IT IS INSIDE THE TOP CONTROL PANEL. THERE SHOULD BE A DIAGRAM UNDER THE CONTROL BOX COVER PLATE TO ASSIST YOU LOCATING THAT SENSOR. MAKE SURE IT IS CLEAN. THE HIGH-VOLTAGE TRANSFORMER BEING BAD USEUALLY WILL SMELL LIKE BURNT WIRING. AND WILL LOOK BURNT. MAKE SURE YOU SEE NO LOSE WIRES ... SOME TIMES THE SPARK-PLUG LOOKING WIRE GOING TO THE CELL(S) CAN BURN OFF ITS CONNECTOR. YOU CAN CHECK THE DOOR SAFETY SWITCH TO MAKE SURE IT IS MAKING CONTACT WHEN HANDLE IS PROPERLY CLOSED. GOOD LUCK ... HOPE YOU HERE THAT ZAPPING SOON ... BY THE WAY ... IF YOU GET A POWER LIT ON ... GIVE THE RETURN-AIR DUCT A SLIGHT BANG ... IF IT IS WORHING IT SHOULD SNAP CRACKLE AND POP FOR A FEW SECONDS. MAKE SURE YOU SEE NOTHING (HAIR?) LYING ACROSS THE PLATES OR IOMIZING WIRES ON EACH CELL IF YOURS HAS TWO. ELECTRIC AIR CLEANERS ARE ONLY GOOD WHEN THEY ARE KEPT CLEAN ... PET HAIR IS A CONSTANT MAITENCE PROBLEM AND CELLS SHOULD BE LEANED EVERY TWO WEEKS. FOR BEST PERFOMANCE. Joe_Rex 40+ years Hvac Contractor (retired)
Apr 29, 2007 | Honeywell Enviracaire Elite F300E-1019 Air...
Heating & Cooling Logo
51 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
