My 'maxtor' hard drive has been formatted to Mac OS extended- therefore it is not recognised by my other non-mac laptops and PCs. How can i format it so that i can transfer music and photos from macs to non- macs using this hard drive, and also back up files from both types of computer? Thanks.
    Novelist:
    Scholar:
  • 160 Answers
If it's a drive in an external case with a USB connector, and you're idea is to plug it into each computer, that won't work.
Otherwise, you share it on a network. Choose which machine it will be in permanently, then share it.
Of course, that means you have to have a network...
Posted on Jul 25, 2008
I can not format a non apple macbook hard drive
Go to the applications folder and then utilities and open up disk utility once opened select your 320 gig hard drive and under the tabs click on erase, select Format "Mac OS Extended (Journaled) then name your hard drive and then click on the erase button. Remember this will erase everything on the hard drive. Hope this helps.
Dec 04, 2011 | Apple Macbook Computers & Internet
My portable drive is not recognised many times
The format of your drive is probably not correct. If data is not stored on your hard-drive, format it to NTFS if on Windows, or Mac OS Extended (Journaled) if on a Mac. If there is data, back it up to a computer that can read it and then format the drive.
May 31, 2011 | Buffalo Technology 320GB MINISTATION TURBO...
I have a powerbook G4 and just purchased a Seagate 500 GB external hard drive and i can not drag and drop do i need to format something or what ?
Yes.
You should use the Disc Utility in Macintosh >Hard Drive> Applications>Utilities>Disc Utility to format the new externql to Mac OS Extended Journalrd or non-Journaled is fine.
For video applications I prefer non-Journaled.
Select the drive on the left side of the window to highlight it.
Select the Erase tab. (Top of window)
Select VolumeFormat: and Name:
In Secutity options select Zero Out Data, hit Erase (middle of window) and wait for formatting to complete.
Could be an hour or two depending on disc size.
Apr 03, 2011 | Apple PowerBook G4 Mac Notebook
I work with OS X (mac) , I can not copy a file bigger that 4 GB into my WD my book. I 've tried to change the format, but i can just chose between : Mac OS Extended ( Journaled) ,Mac OS Extended, case-...
Although Macs are designed to Read NTFS, they aren't designed to write to them and therefor cannot format a windows drive. If you are simply moving files onto the Mac from a windows PC you can format the drive using a PC and the Mac will be able to read and copy the files from the drive. If your goal is to have both windows and Mac read and write to the drive, your best bet is to use Mac OS Extended, then to buy and install Macdisk on your Windows PC. This will allow both to fully utilize the drive.
Any file size limitations you're running into at that point would have to be dealt with through compression or you may need to set up a NAS server that uses either NTFS or Linux format and copy files across the network rather than through a direct port like USB or FireWire.
Feel free to respond back and pick my brain if this advice only gets you half way solved.
Hope this helps FixYa,
Chris
Dec 23, 2010 | Western Digital My Book Essential Edition...
My laptop does not recognize my iomega hard drive
You need to format your drive to work with your Mac. The drive is shipped formatted as NTFS (Windows).
I'm going to assume that you are using Mac OS X 10.5 or later.
1. Open Disk Utility
2. Select Applications > Utilities > Disk Utility
3. In the left hand column, click on the drive icon for the Iomega Hard Drive.
********Make sure you click on the high level icon, not the second level volume icon.********
4. Select the Partition tab.
5. Change Volume Scheme from Current to 1 Partition.
6. Select the format type from the Format drop-down menu.
Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended.
7. Click on the Options button.
8. Select the type of partition you want to use:
GUID Partition Table - for boot ability on Intel-based Macs
Apple Partition Map - for boot ability on PowerPC-based Macs
Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type.
CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC).
9. Click OK.
10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
Dec 17, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
Want to change a maxtor 3200 from windows format to apple mac
When you plug the drive, once mounted on the mac, go to applications>utilities>disk utilities then select the drive and choose partition. If you want the drive to be bootable you should then choose Mac OS Extended (journaled).
Cheers
Dec 03, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Im trying to copy from mac to pc using seagate removable hard drive and its not working? When i plug the Seagate into my PC nothing happens
The hard drive volume format is only for MAC. Check the volume format if it is MAC OS Extended or MAC OS Extended (Journaled). If it is, then change it to MS DOS to make it readable and writable to a PC and MAC OS
Jul 08, 2009 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
Maxtor Basics portable 320gb Mac to pc compatability problems
Hi Tys,
I had a similar issue with my Maxtor Basics portable 500GB drive. I hadn't formatted mine yet, but had heard there were issues, so decided to find out before I start. I even saw your post here looking for an answer. Finally, one of my friends told me the following solution, which worked fine for me:
Don't format the drive as any of the Mac OS Extended options, simply reformat it as MS-DOS (it should be one of the options in Disk Utilities when you choose Erase and go to the Volume Format dropdown list).
Your Mac should be able to recognise and use the drive in this format and it works for PCs. Transferring files between the two shouldn't be a problem.
A thing to note, though, is that these Maxtor drives apparently come ready-formatted as MS-DOS (mine did). But while my Mac recognised the drive, I couldn't copy files on to it. If this happens, erase this MS-DOS formatting with... MS-DOS. Don't ask me why this works, I'm not a Mac Genius, but now my Maxtor is trouble-free and can transfer files from PC to Mac and back again.
Hope this works out for ya!
K
Apr 27, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Computers & Internet Logo
David Payne
David Payne
