Lexmark X5470 All-In-One InkJet Printer Logo
Posted on Feb 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm getting a a message that says "Left Cartridge
  • Official Brand Answer 3,344 Answers
  • Posted on Mar 09, 2011
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
922761
Points
5508
You can try to do the Clean Cartridge function on your printer. While on Copy mode, press Menu -> Tools -> Maintenance -> Clean Cartridges. You can try to insert a known working cartridge to determine if the other is faulty. If your original Lexmark cartridge is faulty, please contact Lexmark technical support and have it replaced. Thanks.
2 Related Answers
tbirdfan1
Michael Thomas
  • 3056 Answers
  • Posted on Nov 23, 2009
SOURCE: MESSAGE SAYS RIGHT CARTRIDGE INCORRECT
Hello there:
what this is refering to is that the cartridge is either not the right one for the printer or the device is having a problem with that cartridge i would remove the cartridge and verify that it is the right one that goes in their and also since youare having the cartridge out i would clean out the contact area to get rid of the old ink that may be sitting on the contact areas ok
best regards Michael
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
  • Posted on Feb 11, 2010
SOURCE: left cartridge incorrect for lexmark x5470
Check to see if the installed cartridge is the correct one for the printer. . If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact to Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Have a nice day and do not forget to rate please...!
Left cartridge incorrect
Is it a factory new cartridge, or was it refilled somewhere?
It's more likely to be bad if it's a refill. If it wasn't the Lexmark label on the box, it's a refill.
Put the old one back in to see if you get the same error. If you get no error, your new cartridge is bad, get a replacement.
Just tried installing a new photo31 ink cartridge and I am getting right cartridge incorrect message.
If you are using a photo cartridge, in your case the #31 cartridge, insert that in the left carrier where the black cartridge is. Make sure your color cartridge is inserted in the right carrier to continue printing.
"LEFT CARTRIDGE INCORRECT" everything was ok
Re-seat the black cartridge and make sure it's properly inserted. If error continues, try to insert a different known working black cartridge to determine if the other is faulty.
Message on printer says "The
The HP D145 uses a special print head cartridge for each ink cartridge. They are not interchangeable.
Message says printer ink low. left cartridge in
You need to carry out alignment to correct the left cartridge, go to the setup on the printer, under maintenance, you will see align cartridge,perform this exercise to align the black and color cartridge and see if it will still prompt this message.
Compliments and wish you best of luck
Lexmark x4550 install new cartridge but printer read incorrect
Are you using a Lexmark factory new cartridge or a re-filled / third party cartridge. If the answer is that you are using re-filled or a third party cartridge that is your failure. Lexmark does not support the use of these products in there products. In fact, use of these type of products is considered to be -product tampering and will cause Lexmark to void the printer's warranty. Please do not shoot the messenger for the contents of the message. Truth is Truth!
Have a error message left cartridge incorrect
Hey!
Are you using Jet Tec ML32 Cartridge re-manufactured cartridges or genuine Lexmark Cartridge?
If it is the Jet Tec cartridge then it is known to be faulty - purchase a Lexmark cardridge and you should be fine.
If it is the Lexmark Cardridge then I would recommend taking all of the cartridges out, turning the printer off (from the power), turning it back on, inserting the cartridges again and checking if it works.
If none of the solutions work, then your cartridge is damaged and should be replaced.
Cheers,
Matt Newelski
I have a lexmark x4580 and was working quite happily over the last few days. i replaced its ink cartridge a week ago and just printing some documnets , it threw up an error message " rigt and left...
Clean and make sure to put it back exactly as you got it, incase you are like me sometimes, i take pictures before i remove an object, so that way i can go back and look at the picture to make sure i get it back in right
2helpful
Right cartridge incorrect" and "Left cartridge incorrect
Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
Outrageous, but true.
A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
