How can I get boot menu
I installed the Windows XP and Ubuntu operating systems on two different partitions.After I updated the Windows XP, Now I am not getting my booting option menu.How I can get my linux boot menu without reinstalling the linux.
    Scholar:
  • 162 Answers
Click on START, SETTINGS, CONTROL PANEL, SYSTEM. Click on ADVANCED, SYSTEM STARTUP AND RECOVERY, SETTINGS. Make sure TIME TO DISPLAY LIST OF OPERATING SYSTEMS are checked and put the number of seconds there. Click on OK and you should be good to go.
Posted on Jul 25, 2008
How does ubuntu work does it install an take over windows or what?
It will install on a different clean (empty) partition.
It will reconfigure the boot, so you can boot in ubuntu or windows
Feb 12, 2015 | Ubuntu Computers & Internet
Ubuntu problems
Download the free edition of EasyBCD (it's boot-up software) and install it in 'C' -Windows. Run EasyBCD... it's very straightforward. It will identify the operating systems on your computer ... choose 'use EasyBCD boot loader' (or similar) and save the changes.
It sounds as though you have somehow lost the boot loader for Ubuntu (it's in C - Windows) when there was an update, which is quite common ..
Using EasyBCD will return your computer to dual-boot
Aug 09, 2014 | ubuntu.com
How do I completely wipe all data on my old Windows XP Machine?
You can use a windows 98 floppy boot disk if you have a floppy driver to wipe out the partitions and format your hard drive.
Mar 03, 2012 | Computers & Internet
The operating system that I used in my computer is XP.How would I install ubuntu operating system on my laptop?
the Ubuntu ISO that you choose for you pc needs to be selected (x86 for normal 32 bit pc or x64 for 64bit devices ) download the ISO and burn to cd or DVD your choice. when you running XP insert the disk and it gives you a option to install aside xp or to partition the drive to add ubuntu separately or to do a clean install ( wiping everything ) or boot up with it and it will help partition the XP drive to install alongside xp to do a dual boot.. this can be easy or hard id get a tutorial on this. but the clean install is the easiest and best it wipes out the drive and I'm almost sure everything will work when it comes on look up the model laptop and ubuntu 11.04(newest ) all my devices work all the time and the software is awesome as well as free and virus free
good luck google installing ubuntu for noobs
Oct 01, 2011 | Canonical Ltd. Ubuntu
Am pulling my hair out. I'm a newbie to Linux but keen to get into it. Installed 9.10 as a dual boot alongside XP and after problems with grub, which I have re-mounted, I get to the OS choice page. XP...
Backup, Repairing and Reinstalling GRUB
  • To make a backup a copy of the existing menu.lst file use: cp /boot/grub/menu.lst /boot/grub/menu.lst.oldYou can try re-installing the grub using the Ubuntu Live CD, in two different ways.
GUI
  1. Boot your computer up with Ubuntu CD
  2. Go through all the process until you reach "[!!!] Disk Partition"
  3. Select Manual Partition
  4. Mount your appropriate linux partions / /boot swap .....
  5. DO NOT FORMAT THEM.
  6. Finish the manual partition
  7. Say "Yes" when it asks you to save the changes
  8. It will give you errors saying that "the system couldn't install ....." after that
  9. Ignore them, keep select "continue" until you get back to the Ubuntu installation menu
  10. Jump to "Install Grub ...."
  11. Once it is finished, just restart your computer
Jul 27, 2010 | Canonical Ltd. Ubuntu
HD booting in one PC but not in another
Ubuntu works with RAM and CPU Memory instead of a pc like xp that uses Virtual RAM. If the pc that could not load ubuntu doesn't have enough ram to support the reading of the Hard drive and the Operating System then it won't work and Xp will only run on the computer that xp was installed onto the hard drive.
Dec 19, 2009 | Computers & Internet
I installed Ubunto 9.0 AND when it came up it said, GRUB LOAD,no such partition, then at a prompt it says,grub rescue.
If you run a dual-boot system with Linux and Windows, this has happened to you. You had to do your monthly reinstall of Windows, and now you don’t see the linux bootloader anymore, so you can’t boot into Ubuntu or whatever flavor of linux you prefer.
Here’s the quick and easy way to re-enable Grub.
1) Boot off the LiveCD
2) Open a Terminal and type in the following commands, noting that the first command will put you into the grub “prompt”, and the next 3 commands will be executed there. Also note that hd0,0 implies the first hard drive and the first partition on that drive, which is where you probably installed grub to during installation. If not, then adjust accordingly.
sudo grub
> root (hd0,0)
> setup (hd0)
> exit
Reboot (removing the livecd), and your boot menu should be back.
Only read below if Windows is now missing from the boot menu
If you installed Ubuntu before you installed Windows, then Ubuntu will not have anything in the grub configuration for Windows. This is where you’ll have to do a bit of manual editing to the grub boot menu file.
If you open the file /boot/grub/menu.lst with the following command:
sudo gedit /boot/grub/menu.lst
You’ll see a sample section for Windows, which you’ll want to uncomment and add to the boot menu list in whatever position you want it in. (uncomment by removing the #’s)
# title Windows 95/98/NT/2000
# root (hd0,0)
# makeactive
# chainloader +1
Note that you should also verify that hd0,0 is the correct location for Windows. If you had installed Windows on the 4th partition on the drive, then you should change it to (hd0,3)
Nov 20, 2009 | Canonical Ltd. Ubuntu
How to Install both XP and Linux?
I would install XP 1st then Open suse or Ubuntu. When you install either of these linux OS's ensure you install to another partition other than the windows one. Both installation routines will allow you to format the drive to the linux ext2 format and automatically install a boot manager (usually GRUB) which will allow you to select the OS you wish to boot.
Aug 09, 2009 | PC Mall Ubuntu 8.10 for Linux
2 operating systems
The Boot Configuration Data (BCD) store contains boot configuration parameters and controls how the operating system is started in Microsoft®Windows Vista.
Remove Windows Vista From Dual Boot System Windows Vista works slightly different from earlier versions of Windows when installed on a dual boot system, in that it has a completely different boot loader.
When Windows Vista is first installed as a dual boot operating system a new boot folder is added to the root directory of your PC. This is a hidden file and therefore is not noticed. When you boot your PC a menu appears with the following options:
  • Earlier versions of Windows
  • Windows Vista
Clicking the Windows Vista option will boot the PC into Windows Vista. If, however, you select the earlier versions of Windows option, another menu will appear from which you can choose Windows XP or whatever earlier version - Windows 2000 or Windows 2003 server - you installed first.
Because of this new boot loader it is not as easy to remove Vista from a dual boot system scenario. Simply deleting the Vista partition will, of course, remove Windows Vista, but, unfortunately, it will not remove the Windows Vista boot loader. For this reason, if you simply delete the Windows Vista partition, on rebooting your machine you will not automatically boot into Windows XP (or an earlier version). Instead you will once again be presented with a menu from which you have to choose which operating system you wish to boot to.
Obviously, once you have removed the boot loader and rebooted the Vista operating system will still be on the partition you originally installed it on. To remove Vista completely you will need to Delete the partition that Windows Vista was installed upon.
To remove this menu, or more to the point, the boot loader, proceed as follows:
1/ Boot the PC to Windows Vista
2/ Ensure you are logged onto the Internet and then download the freeware boot loader utility VistaBootPro (www.vistabootpro.org)
3/ Once you have downloaded VistaBootPro, install it on your machine
4/ During Install VistaBootPro will install an icon on your desktop
5/ Locate the VistaBootPro icon and Right Click on it. Then, from the drop down menu, Click on the Run As Administrator option
6/ User Account Control (UAC) will pop up and ask for permission to run the program
7/ After you have given UAC permission - you must be the administrator or have administrator privileges - VistaBootPro will run.
8/ Once VistaBootPro opens, Click on the Bootloader tab
9/ In the Bootloader Maintenance section, Click on the Radio button next to the option marked 'Uninstall the Vista Bootloader (Used to restore Legacy OS) option' and then Click the Apply button
10/ Finally Reboot your PC
11/ On rebooting your machine you will boot directly into Windows XP (or an earlier operating system). No menu will appear.
12/ All that is left to do now is to delete the partition which originally contained Windows Vista. (Assuming you wish to remove the Vista partition from your hard drive).
Sep 12, 2008 | Acer Aspire 3680 Laptop
Dual Booting
possibly by first creating a new partition large enough for Linux OS, but does not solve your problem...try getting a VISTA startup disc from another pc (floppies if you have the drive) and startup from these.
Sep 09, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
