Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Lx30H actual model
I keep getting an E5 code, the manual says something about it draining but It drains fine. I figured the rear probes are going bad. And I on the right track?
  • 640 Answers
I would clean the 2 back probes with emory cloth and the sump probe underneath the screen.then pour half of cup of c.l.r. (calcium,lime,rust) remover in the dishwasher and run 3 cycles.If you still have this issue let me know.
Posted on Jul 26, 2008
LX30H THROWS A CODE EO after running awhile. I hit the high reset button under the flaps on the front for both the boost and reg elements . It will work for a couple cycles and then does the same thing....
Machine won't fill or won't fill high enough. site water pressure meets minimum flow pressures. (LX18, LX30 display shows working.
"E0," "E2," "E3," or "E4". LX40 display shows "DR1 PRBLM," "FILL1 PRBLM," FILL2 PRBLM," or "FILL3 PRBLM". Machine will not run.)
1. Low water pressure - check for clogged hose strainer; check that
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be
4. Drain valve open - turn machine OFF to drain machine, then
ON. Repeat twice (this assists in clearing any drain valve
obstructions). Wait for machine to reach READY mode and
press WASH. Slowly open door several seconds later and note
water level. Close door; 30 seconds later, open door slowly and
check that water level is the same as it was. If not, repeat the
OFF-ON procedure. If problem persists, call your local Hobart
Service Office.
5. Delime machine.
Dec 10, 2013 | Hobart Lx30h Commercial Dishwasher
Error code E5 for model : MOB-10KDCHR
I have Boston Portable ac MOB-10KDCHR can not find a parts number for the drain cap and drain hole (rubber plug)
Apr 16, 2012 | Heating & Cooling
Hi, my Hotpoint Aquarius + WF630 screen has what looks like something E5 something on the screen and goes from prewash through to spin within a few moments and no water enters. i have made sure the drain...
If you have cleaned the drain filter AND checked the operation of the drain motor, for Hotpoint (and the manufacturer Indesit) E5 states ' pressure switch jammed on full or pump blocked- check switch and module'. Sometimes there can be bad connections between plugs/cables/module (PCB). If you haven't done already please make sure that the pump does actually work by removing the filter, seeing the pump motor and putting the machine on spin. You should see it rotate! Otherwise it looks like a service call ;-0(
Good luck,
John C
Mar 20, 2011 | Hotpoint Aquarius WD640 Front Load...
I have a PD code on a Hobart LXI dishwasher. What does that mean
PD is not an error code. It shows that when it draining water out shortly after power-up and when shutting down. If it seems to be showing "PD" longer than usual, it means the dishwasher's control circuitry believes there is still water in the tank, due to a faulty water level probe, most like the one under the lift-out screen. It has a plastic body with a metal probe coming out the center.
There is also a dual probe at the rear of the machine, but I believe the dishwasher uses the front probe to determine when to stop draining the machine during "PD" - most likely meaning "Power Drain" or "Power Draining".
If you are not seeing any E- codes (E1, E2, E3, etc.) then these water level probes are likely just fine and the "PD" is appearing normally, as it should during draining conditions.
Feb 08, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
the p2 err. is on open or shorted rinse thermistor which is located on the back of the mach next to the vac. brkr. as for draining ck the drain valve for debris, and the end of the drain hose where it connects to the building drain
Dec 25, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
The machine has an E5 error code , it will drain itself and then needs to shut down and turned bavk on to get it working again
e5means water did notdrain below top water probe, there are 2 probes in theright corner of the mach. make sure they are clean you can use a copper tubing cleaning brush to clean probesmake sure to clean the back of them, then try 3 cycles, if after 3cyc. the e5 doesnt come back you have fixed your d/w dont forget to vote
Oct 23, 2009 | Hobart LXIC-6 Dishwasher
E5 everytime we run the wash
Try running the drain hose into a bucket next to the machine. If it drains Ok, look for the restriction in your plumbing. If it won't drain into the bucket, look for a closed drain valve, open fill valve, bad middle or top probe, check power at drain connector ( it's DC volts from the bridge rectifier in the top drawer on the relay board.. Basically, water is at top probe at beginning of rinse, or it didn't drain down after the wash. Drain hoses can kink from hot water if not routed well.
Jul 17, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
E-5 error code and no draining or rinse cycle machine less than 3 months old
E5 is a drain error - machine is not draining - check drain hoses - pull out machine if needed - check air gap. hope this helps. jimmy.
Sep 26, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
LXGH E5 Code
I need to check my codes to be positive. And I'll check them this weekend. But, I believe E5 is from excess water in the unit, and so it won't go into rinse and add more water.
First and most common -- the drain hose, at the back of the unit is kinked. The unit gets pushed back against the wall and kinks the line.
Second, your probes are dirty. The ones in the back right corner detect water level. Clean them with a green scrungee even if they look clean.
Good luck - Mike
May 05, 2008 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
308 people viewed this question
Top Hobart Dishwashers Experts
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
