Back to:
Tags:
Protron PD-DVR100 DVD Recorder
Not recording (by 2 users)
posted by c_hudson63 on Jul 25, 2008
I've had problems since I first got it.It's made me miss a lot of nascar races.Sometimes when I set the timer it would record right.Then sometimes I would come in and everything would be shut off(tv)too.Then I'd turn everything on and it would say error in disc or tape is empty.Now I can sit right here with it,watch the record kick on,turn it of when I'm done,go to play it and it says it's empty.Please help.Can't find my manual either.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by kdoud, posted on Sep 12, 2008
I feel your pain brother i will let you know if i figure this out i have 2 units and i might be able 2 send you a manual if i can find the other one if you want......let me know!!!! Mine used to wrk but both of them now do the same thing yours does after recording has stopped or is manually stopped................
Solution #1
posted on Aug 03, 2008
Not Rated (0)
SARGEQUANGTR
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
HOWDY---CHECK THE DATE AND TIMER SETTINGS IN THE MENU-FOR A MANUAL, GO TO THE SECTION AT PROTONS SITE AND ORDER ONE---SARGE
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on not recording:
I don't want to Accept this solution
Can you Help with these DVD Players problems?
i don have a remote and phone number and the web site...
When connected through the dv terminal I get a message...
i switched over from cable to satelite and when i do a...
MY protron dvd player when turned on runs with lines...
it sucks and so does the number given to call and so does...
Loading problems.
Repair Service
Find DVD Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
