Question about Hoover Vacuums
I have a Hoover Telios T5732 with broken cable winder, have purchased a replacement winder unit have loosened 5 screw but still cannot separat the covers . some advice please.
  • 3 more comments
  • billnixon32 Jul 25, 2008
    Five words were of no help at all
    Servicev manual would help but hoover says there are non available. have pulled it quite
    hard and see stress lines at cover near power switch wheel.
    I do no see a plastic cover do you mean under the outer plastic cover it seems fixed from
    underside.
    Done that still seems secure at switch end
    Well done Thanks for the diagram and help
    Genius:
  • 1,011 Answers
After unscrewing all the screws, try to open it evenly, not more from one side.
check this link,
http://www.espares.co.uk/diagram/vacuum-cleaners/hoover/t5732-001/p/1086/107/56/386685
Posted on Jul 25, 2008
    Genius:
  • 2,035 Answers
Please give it to a local service center and they will charge a you small amount as you have the replacement part with you ....
Thank you......
  • 2,071 Answers
You must tug each corner to loosen the cover. It's stock already due to accumulated dirt and dust.try this option...
Regards,
VOTIT
    Genius:
  • 3,422 Answers
Access to the push switch, and its connections, is below a plastic cover behind the switch. Its secured with a torx screw.
  • Priya darshan Jul 25, 2008
    If you need any,more help let me know before you rate it.If this solution was enough to fix the problem then please don't forget to accept it.
    Guru:
  • 1,894 Answers
Have you tried pulling it a bit hard.
since it has not been opened for along time it may be stuck.
have a service manual for better understanding.
    Sergeant:
    Champion:
  • 310 Answers
Using the -ve screwdriver pull it .................
Why does metallic cover keep blowing off when operating?
Hey there! It sounds like your vacuum may be clogged causing it to redirect the air flow which may be causing the cover to blow off. To check the vacuum for clogs disconnect the hose from the cleaner and the wand, use a broom stick to gently loosen and remove any clogs from hose. Also check the wand and the nozzle for blockages. If it is the filter cover that is coming off and there are no clogs, the tabs on the filter cover may be broken. Contact a local service center for information on replacing the filter cover. Reference part 59135033. Or you may contact Hoover Customer Service at 1-800-944-9200. Hope this helps!
Aug 27, 2014 | Hoover S3330 / S3332 Straight Suction...
Telios 2000
This is normally caused by restricted airflow, causing the heat sensor switch to trip. Please make sure the hose and bag are not clogged, verifying you have good suction and airflow to the hose end when you initially turn it on. The heat sensor switch is intended to shut off the motor if sufficient cooling air is not present.
Mar 09, 2010 | Hoover Vacuums
Forward/back cable broke
The cable is user replaceable, but you will need to contact Hoover, or a parts center, to purchase the cable. You will remove the Upper Handle by removing the black screws at the base of the upper handle fit to lower handle (on back).
You will also have to remove the hood to loosen the one screw that holds the cable to the powerdrive gearbox.
Oct 12, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Cable does not wind in. Hoover Helios 2000. Found the 4 font fixing screws - there must be more at the back. How do you get at them?
The flex is fitted to a spring loaded cord reel.
in side the Telios, chances are the reel is faulty and too expensive to change, either get use to it or buy a new one. sorry
Sep 19, 2009 | Vacuums
The hoover keeps switching on and off automatically.
Sounds to me like there is either a loose wiring in the pedal or mains power cord. Check that the plug is secure. Check both filters though - one behind the bag (usually square and slides out) as well as the main exhaust filter at the back between the power on and cord rewind button. I used to own many Telios models but they are known to have cheap shearing cords which can only be replaced by a Hoover repairer. Sometimes the On pedal can be affected as well particularly if it has been stamped on heavily.
Dont forget to rate, ty.
Mar 28, 2009 | Hoover S3330 / S3332 Straight Suction...
I need instructions for H30 bag and filter installation for Hoover S3332 Telios Canister vac. Where can I find the instructions. I have long since misplaced any instructions which came with the vacucum...
go to hoover.com,when the page comes up click on customer service at the top then when that page comes up look on the page for product manuals and info,you will get what you need there.
Dec 06, 2008 | Hoover Vacuums
Cord rewind
A bit late for the original questioner, but perhaps this will help someone else.
There are many models of the Hoover Telios. This solution applies to the T5603 at least, but perhaps not to all models... sorry, I don't know about the others.
Anyway, this is it. The cover is held to the base by 8 screws. Two are clearly visible near the handle, two are in the bag compartment. They are easy!  The problem is finding the others, because they are concealed by the foot-operated switch plates, and you have to get those plates off without breaking them.
Basically, those plates slide off backwards (i.e. away from the handle end) but you have to release a plastic catch first.  The catch is part of the switch-plate, and is located roughly mid-way along the straight side of the plate, just by the raised bump.  You can just see the catch if you shine a torch light down the gap.  The catch is released by inserting a small screwdriver or other flat blade and levering it away from the centre-line of the machine.  If you apply gentle rearward pressure on the plate while doing this, you will soon feel when it's released.
Once the catch is released, the plate will slide off completely and the remaining four screws are revealed.  After that, it's simple!
Hope this helps someone!
Feb 23, 2008 | Hoover S3330 / S3332 Straight Suction...
My Hoover is picking dust , very poorly
The Telios has a bad design on the handle and it sounds like something has definately got stuck. Unfortunately the nature of the cheap European design means the handle can only be removed by someone who owns a vice in their garage without breaking the removal points. Alternatively find a long bamboo stick or pole to put inside the hose mount which connects normally from the main bin of the Telios (not the other way around up the handle) which has no sharp edges and push up and down vigourously to dislodge any clogged dirt which may have inadverntely got stuck either by the handle or in the hose itself.
Another thing to do is to check the suction from the Telios itself by removing the hose. If there is suction coming from the main dirt bag/bin door with the hose removed then there is no problem other than a clogged hose and handle. Hoover updated the handle and hose in 1999 and spares can be found by looking on Ebay.co.uk for cheaper prices.
Aug 12, 2007 | Hoover S3330 / S3332 Straight Suction...
Vacuums Logo
123 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
