Question about HP DesignJet 450c InkJet Printer
450 c i have a 450 c ...... it starts "ok" ... i get to the load media command put the paper in and it runs thru the command and then spits my paper (18"x24") back out and then the media lights blinks ...... can you help me.
Make sure your paper is aligned with the left edge of the rectanglular holes on the right side of the printer paper feed slot
those slots are monitored to check for proper paper alignement and if it is not --it spits out the paper
Posted on Aug 04, 2008
Got a new ktm 450 2003\04 and will not start in the cold have been trying to bump it and still no working and got a new spark plug for it and have been trying to start it for 3 days know when I bump i
You need 3 thing to make an engine run.spark at the right time ,fuel /air ratio to be correct,and compression.Isuspect you have tight intake valves.The valves are to tight letting compression out.To adj valves take your plug out put motor on tdc compression stroke .intake should be .006 exhaust .008.If this checks out to be ok you may have a fly wheel key that sheared and your ignition timing is off.
Feb 08, 2015 | KTM Motorcycles
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
Installed new printhead,took new ink I had just put in old printhead and put it back in new printhead. Will print nothing.just spits put blank 4x6 photo paper it says to load in to get calibration.Then it...
The document specs of your printer is given below:
Document & Media Handling Max Original Size Legal (8.5 in x 14 in) Original Type Sheets Min Copy Size 3.5 in x 5 in Max Copy Size Legal (8.5 in x 14 in) Standard Media Capacity 100 sheets Output Trays Capacity 50 sheets Document & Media Handling Details Input tray - 100 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ Output tray - 50 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ ADF - 3.94 in x 5.9 in I would rather suggest to take a print in normal A4 size plain paper and see what you get. Please revert back Suspected 1) paper scanner faulty not able to judge paper.
Sep 10, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
My Brother printer reports the message "No user defined Paper.Load milti-purpose paper in tray". I put the paper but the printer does not work. What can I do?
check printer spooler
Click on Start, Then Run
Type CMD in the run window and hit OK
A black box will come up. In that black command window type this:
net start spooler
Sep 02, 2011 | Brother HL-4050CDN Printer
Canon ir3320 problem is a 2 side copy command after 1 side print ok 2nd side pcopy is a lite
If one side looks great and the second side is faded try loading fresh paper in the copier. Sounds like there is moisture in your paper. It dries out after going thru the fuser section on the first pass so on the second side the paper is dry and the copy will look alot better.
May 11, 2010 | Canon imageRUNNER C3200 Copier
I cannot figure out how to load the paper in my new canon mx300 printer. I put the stack of paper in the back of the printer, but none of the sheets will feed through. Any suggestions?
Hi,I assume you gave a print command from PC but printer did not print?
Did you try to make a "copy" of something ? as photocopier function. thru the command keys on the printer..
Please give me more detail then I can give more solutions..Regards
Jan 26, 2010 | Canon MX300 Office All-In-One Printer
Power steering belt came off cant put back on because the top pulley is loose, the vehicle will not start anymore it was running ok then it spit and sputtered and died, it will crank but won't turn over...
Broken wires to fuel pump and little rodent of some kind chewed thru it. the power steering pump shaft was broken so it got fixed cost about $450 parts and labor!
Jan 17, 2010 | 2002 Chrysler PT Cruiser
Out of paper issue
Instead of restarting, try this:
1. Start
2. Run
3. Type this in the box: services.msc
4. Hit ENTER
5. Scroll down to PRINT SPOOLER
6. Right-click on it and choose RESTART
this will clear out your print queue without having to restart. Good luck!!
Hi this is the more effective way to refresh the print queue.
Manually Stop and Restart the Spooler Service
1. Click Start, click Run, type command, and then click OK to display the command.com window.
2. Type net stop spooler, then press .
3. Type sc config spooler depend= RPCSS start= Auto, then press . The spaces between = and RPCSS and = and Auto are important. Without these spaces, the command fails.
Type net start spooler, then press
NARENDER KUMAR RANA
narendertacl@gmail.com
narendertacl@yahoo.com
narendertacl@hotmail.com
Nov 15, 2009 | Kodak EasyShare Printer Dock Series 3
Sir i adjust the Legal size page 8.5x14.0 and also select the same from the tray when i sent the command printer made a red light and cancel the command.
There is a green wheel at the back left of the paper trays, make sure they are set to the size paper you have loaded.
Sep 09, 2009 | Ricoh Aficio 450 Copier
How to Find the Ethernet Adapter's MAC Address
Follow these instructions to find your adapter's Media Access Control address (MAC address). This is not the same as a Macintosh computer, it is a fixed string built in to the hardware, that uniquely identifies a computer device. Windows 2003 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. (no spaces around the /) 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows XP 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows 2000 1. Click Start > Programs > Accessories > Command Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Windows 95 and Windows 98 1. Click Start > Run. A command prompt window appears. 2. Type winipcfg. 3. Click OK. 4. Copy down the "Adapter Address" (the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows NT 1. Click Start > Programs > MS-DOS Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Macintosh OS (10.3.5) These instructions also work for some earlier OS. 1. Click Apple Menu at top left > System Preferences > Network icon. 2. Select Show: Built-in Ethernet in the pull down menu. 3. Click Ethernet. 4. Your adapter's MAC address is the characters in Ethernet ID.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
HP DesignJet 450c InkJet Printer Logo
106 people viewed this question
Ben Johnson
