Question about Panasonic KX-FPC95 Plain Paper Thermal transfer Fax
*99 Problem When I dial *99 from another phone on the same line to get messages from a Comcast message system the fax starts to squeal. I have to go to the phone on the fax and dial *99 to get the mesages.
  • robinsonelec Jul 25, 2008
    There was a delay, but it did the same thing.
  • 30 Answers
Try reseting your unit by placing the handset to its cradle then unplug the unit from its power source and plug again.
Posted on Jul 25, 2008
Off the hook
A "Phone Off Hook" message is not an error. It simply indicates that a telephone receiver isoff the hook(the handset is lifted) and the telephone line is open. This message would be expected in the following situations:
  • A modem on the phone line is accessing the Internet.
  • A phone connected to the HP fax (or the same phone line) is using the line, or the handset has been lifted.
  • A credit card machine is using the phone line.
  • Another electronic device is using the phone line.
  • The Start Fax button was pressed with no telephone number entered. Pressing Stop or Cancel should return the display to a ready state.
When the other device is no longer using the phone line, the display should revert to the normal message.
Lets try the following,
Disconnect the phone cable from the back of the HP product and the message should clear. If the message does not clear, unplug the power cable from the back of the unit, wait 15 seconds, and then plug in the power cable.
if issue still exists try the followign
Disconnect the phone cable from the HP product and connect it to a single line phone. Pick up the handset and listen for a dial tone. If no dial tone is present, replace the phone cable. If a dial tone is still not present, a problem exists with the phone system.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
Apr 22, 2014 | HP OfficeJet 4215 All-In-One InkJet...
My phone is flashing and has an envelope picture one it
It sounds like you have a voicemail. If you pick up the phone, and hear a pulsing dialtone, Either dial your own phone number, or press *99. It will give you instructions to listen to your voice message
Dec 23, 2013 | GE 30522EE3 DECT 6.0 3 Handset Cordless...
Can't get messages
Try Star 99. If that doesn't work, contact your local Comcast office or log on to http://www.comcast.com and ask for instructions.
Aug 02, 2012 | AT&T E2116 2.4 GHz Cordless Phone
Panasonic fax machine plays "not
First, the phone line to your fax machine should go through the filter.
Also, you haven't mentioned if you can just dial and call someone. Can you?
One way to test it is to dial manually as you would dial any telephone number.
Insert the document to be faxed, lift the receiver on the fax machine, listen for a clear dial tone, then dial the number.
If there is a fax machine at the other end you will hear the chirping sound after a few rings. Then press START and see what happens.
Jun 21, 2011 | Office Equipment & Supplies
No matter what fax number I dial, I hear the cannot be reached as dialed message. I have one verizon phone line, with verizon DSL running off of the same line. My phone line is okay, because I can reach...
It is probably the same problem I just had with mine through Comcast. All I was getting was a not answered message no matter what number I dialed. I had the telephone line running through a surge surpressor that had one line running in and then two lines running out. I had been hooking up my fax through one of the two out lines. When I switched it to the main line and not through the surge protector everything worked fine.
So if you have any splitters or surge surpressors on your line - switch to the main line and see if your problems does away like mine did.
Have a great night!
Jun 20, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
When trying to fax i am receiving the message no dial tone. i pick up the receiver to my phone and i hear the dial tone. is there a pne number to call for tech support.
Without knowing the exact model, I am unable to direct you to tech support....A common problem that causes this is either the phone cord is plugged into the out instead of the in jack on the back of the printer. Another possible situation is that you have VoIP phone service (comcast, or vonage) which doesn't provide a true dial tone for faxing, in which case you would need a dedicated phone line for the fax.
Sep 29, 2010 | Office Equipment & Supplies
I am unable to send fax, I get a 'phone line error' message. The phone line is fine, I checked it by pluging a seperate phone into it. When I go to 'On Hook Dial' I do not get a dial tone on the fax...
Please check the dial tone by following the instructions given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up Arrow" or "Down Arrow" repeatedly until On Hook dial is highlighted.
4. Press "Select" twice.
You can now hear the dial tone of the telephone line.
5. Enter the number to which you want to send a fax.
Note: Press the keypad numbers to use an automated answering system.
6. Press "Start Black."
Mar 29, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Fax won't work with new digital/internet phone system
True. ALL fax machines are analog devices. Internet phone lines are DIGITAL.
There is no way to make it fax reliably.
Dec 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
When I try to fax I get a message that there is no dial tone but I am using a modem from comcast. I contacted comcast and was told to contact lexmark
1) Take a regular phone and test the line
2) Check the status of your modem in your computer
Start >> Control Panel >> Modem
Verify if oyur modem is giving to you a response
3) Check if the cables has been connected into the right port (line in - line out)
Oct 29, 2008 | Lexmark Office Equipment & Supplies
Toshiba strata dk 280
it may be setup to block outbound calling, remember also, you have to dial a 9 to get dial tone on a centrex line, so in this case if your phone system is setup to dial 9 as a line access code you will actually have to dial 99. hope that helps
May 13, 2008 | Toshiba Strata PT-390 Corded Phone
Panasonic KX-FPC95 Plain Paper Thermal transfer Fax Logo
47 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
