Question about Intel D845GVSR Motherboard
Is there any problem in using a 1GB DDR with 400MHz speed in Intel D845GVSR board?
Hai friends,
I am having a PC with Intel D845GVSR Board and Pentium 4 Processor 2.40 GHz (Prescot). I was using a 128MB DDR with 333 MHz speed. For want of more speed, recently I have upgraded my RAM to 1GB. As 1GB RAM with 333MHz speed was not available in the market, I purchased a 1GB DDR with 400MHz speed. Though the manual provided by Intel says that this board will support DDR with 200/266/333 MHz speeds only, the retailer told me that it will support 400MHz also. When I installed the RAM into the Board, the PC worked without any problem. Now I want to know whether this will create any problem in the future. Kindly help me with your valuable advices.
Thank you.
Regards.
(Joby T Saju)
  • jobycwa1 Aug 07, 2008
    Hai friends,
    Thank you.
    Regards.
    (Joby T Saju)
    Scholar:
  • 93 Answers
Since Intel says that this board will support DDR with 200/266/333 MHz speeds only.There should not be problem with your board more so that it works fine.
Posted on Jul 25, 2008
Testimonial: "Thank you very much"
Thank you for sharing your experience. I was also in a same problem and now i decided to go with 400 Mhz 1gb ram. Once again Thank you :)
Posted on May 02, 2012
  •  Abraham Vivian
    Abraham Vivian Aug 08, 2012
    It's working fine now :-)
Hai, my pc mother boaed cd had lost, i want mother board cd to downloadf or System Model: D845GVSR,and Processor: Intel(R) Pentium(R) 4 CPU 2.40GHz, how can i solve this proplem
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+845+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D845GVSR
Sep 03, 2011 | Computers & Internet
Does intel d845gvs1 motherboard supports DDR2 ram?
From an Intel page of this boards nearest "relatives" in the d845 series...
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008824.htm
It shows the following for memory speed options:
333, 266 and 200 MHz DDR SDRAM
And if I remember correctly, that era of motherboards came out when ddr2 didn't exist in the market. Beyond that, the above stated memory speeds show that this board didn't even support the PC-3200(400MHz) ram, which was the final step in DDR1 memory.
The short answer to your question is: No, that motherboard of yours does not support ddr2 ram.
I hope that gets you the information you need.
Mar 12, 2010 | Intel Motherboard
Emachine 4250 wont boot gives 3 beeps
beeps indicate a hardware fault, go to the manufactures sight to determine the nature of the fault
Jan 25, 2010 | Computers & Internet
The PC is not shutting down
It could ofcourse be a virus, so I'd recommend a system restore back to before that happened. If that doesn't help load a backup or do a clean install.
Could also be the power connector on your motherboard is shorting with the reset connector (they're right next to each other) Maybe you'd check that first, before the clean install. Don't know if that mobo has a reset button though. They're usually in the right bottom corner of the mobo, together with all the other front panel connectors. Maybe you could insulate the power and reset buttons?
Else you could always buy socket with an off/off switch, and connect the PC to that. Just shutting it down and than turning off the socket when the reboot starts won't hurt the PC.
Dec 09, 2009 | Intel D845GVSR Motherboard
Hai friends........ I am not able to shut down my PC
Ive seen this happen B4..
try holding the power button in..
If your useing the power button every time, it could be sticking,, Or you have it setup to restat when the power button is pushed.
If button is ok and power setting are set right then its *********** board
Dec 01, 2009 | Microsoft Windows XP Professional With...
I have a intel 845gvsr board, want to replace a Ram. What type of RAM is suitable for this board?
Your Intel D845GVSR has,
1. Two ram slots.
2.Maximum Amount of ram is 1GB for EACH ram slot.
3.Maximum TOTAL Amount is 2GB, (1GB in each ram slot)
4.Uses DDR Sdram at 400MHz, (PC3200), OR
DDR Sdram at 533MHz, (PC4200)
This is an example of DDR Sdram at 400MHz, (PC3200),
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1354&name=PC3200-DDR-Dual-Channel-Memory&Nav=|c:1352|&Sort=0&Recs=10
(Not advertising for this website. There are many places to buy ram memory)
512MB + 512MB = 1024MB, or also stated as 1GB
1024MB = 1GB
Nov 13, 2009 | Intel D845GVSR Motherboard
Whether Intel D845GVSR Board support a 1GB DDR RAM with 400MHz Speed?
Yes your mainboard can support 1GB ram400mhz without any issues.check your board manual However if any issue arise you can upgrade the bios
Hope you find this information helpful.
Jul 16, 2008 | Intel D845GVSR Motherboard
Regarding upgrading RAM
You'll need 184-pin ddr sdram memory
Supported speeds are 333, 266, and 200 mhz
Max memory for your motherboard is 2 gb, so the best you can get for your motherboard is:
2 x 1GB 333mhz 184-pin DDR SDRAM
May 21, 2008 | Intel D845GVSR Motherboard
Regarding Upgradation of Rams in My mother board
Please don't post your question twice, I've already answered your other post of this problem
Memory upgrade
you can use any DDR 180pin. But having two RAM of different speeds may not be compatible sometimes, so upgrade it to 1Gb by just using (1) 1Gb pc3200.
May 15, 2007 | EliteGroup P4VMM2 Motherboard
Intel D845GVSR Motherboard Logo
223 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
