Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS120 - 9 Blinks
I too have the KV-32FS120 and the set will not power on. I get 9 blinks when I try to turn it on. I have unplugged it for two days to reset and get the same result. Can you tell me what needs to be replaced? I have no problem soldering.
Thanks for your help!
mkurp2@yahoo.com
  • 125 Answers
I just fix one like this one for $200.00 usually is $275 you have problems in the zero cross detector inside the tv
Posted on Aug 06, 2008
SONY Trinitron Wega KV-36XBR800 not working
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 04, 2016 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
I have a Sony Trintron KV-PG21P40. When I'm
Since the set recovers under some conditions, I would first look for poor solder connections. With a set of your vintage, it is common for some of the connections to become faulty. If you can solder, resolder any connections on the board that appear grainy or have rings. Please note that there are potentially dangerous high voltages present inside the set even when unplugged.
Keep us posted on your progres.
Dan
Mar 09, 2009 | Sony Televison & Video
My 32'' sony wega blinks 5 times
The 5 blinks means a problem in the set's AKB (auto kine-bias) circuit. Sony TV's monitor the operation of the picture tube. When some kind of trouble has been detected, the TV blanks the screen and flashes the 5 blink error code. This may be due to problems in the video circuit, a bad picture tube, or adjustments that have changed due to aging of parts. There isn't anything I can suggest you try on your own to fix it. Because several things may cause the problem, and the proper tools and service information needed to troubleshoot, you should refer this repair to a professional.
Feb 17, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Sony Vega Service Codes
    KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
    There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
    If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
    Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
    KV-36FS10 - No picture or sound Stand By Light blinks
    5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
    Jun 15, 2008 | Sony KV-36FS100 36" TV
    No Power on Sony TV Model KV 36FS120
    Hiii....
    The sympthon 9 blinks :
    Check at G board : D6301 D6116 ( replace with new one !!!! ).Voltage around +/- 12 -13 v .
    Thank's
    [Vrya]
    e-mail : be_cek@yahoo.com
    Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Sony WEGA KV 32FS100
    No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
    Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
    Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
    165 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
