Question about HP Photosmart 2710 All-In-One InkJet Printer
Does not recognize black cartridge
Black print became faint so I replaced with a full cartridge refill from Cartridge World. I have used thier refilled cartridges for years with no problems. The printer shows an error and says there is no black cartridge in it. I used a q-tip and isopropyl alcohol to gently clean the contacts on the cartridge and the printer, but it still does not recognize that it is in place. I have tried two different "new" refilled cartridges.
I did notice that there is a zig-zag spring wire on the right side of the cartridge holder for both the color and the black, but on the black side it looks like spring is not held in place like it is on the color side. Could this cause the cartridge to not be held to the electronic contacts correctly? Any fix if this is the problem?
  • Anonymous Feb 05, 2009
    i have the same problem
    Scholar:
  • 154 Answers
Well cleaning with isopro was a bad idea on a printer head as alcahol eats the protective coating and spring allinment maybe a problem but if you left it for more than a couple of days with a empty cartrige it has probably clogged the print head and once clogged they are nearly impossible to unclog. Ink has a property in it that makes it go hard very fast when exposed to air and when empty they get clogged very easily. Once clogged your best bet is to get a new print head but most print heads cost more than a new printer. As I've found out the hard way sorry. You can try to clean with turps on a earbud but this is not a reliable way to do it as it can eat the coating on the print head that connects to the printer to tell printer there is a cartridge in the printer to.
Posted on Jul 25, 2008
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
Hi, I just got a Cannon369 MP360 the black ink is empty,but there is color ink in it. It will not print anything. Do I have to replace the Black to get color in to work??? Since it's 2nd hand I don't want...
With this type of printer you need to have a full black cartridge to print black and white. The new Canon BCI-24 black cartridge from Staples is only $8.29. These cartridges are even cheaper from refillers. I recommend Cartridge World or Office Depot for printer cartridge refills.
Feb 02, 2010 | Canon MultiPASS MP360 All-In-One InkJet...
I have a Lexmark X4650 I refilled the cartridge and now I cannot get the printer to recognize the cartridge it prints black only and tells me Color is low . any suggestions on how to bypass this prob get...
I own a Cartridge World ink refilling store and I can't refill the Lexmark 36 and 37 cartridges. Your printer deactivates the electronics on this cartridge when the ink levels get low. Your printer needs a black and a color cartridge with functioning electronics to print. I NEVER recommend Lexmark printers. They are poorly made, don't accept refills easily, and have the most expensive ink across manufacturers and it is designed to clog your cartridge unless you use it quickly. If you keep this machine you are stuck buying Lexmark brand ink (the return program cartridges are a little cheaper though).
Dec 24, 2009 | Lexmark X4650 InkJet Printer
HAD BLACK INK CARTRIDGE REFILLED AND REPLACED , PUT IT BACK INTO HP7550 PRINTER, NOW IT DOES NOT PRINT AT ALL DID NOT PRINT A CALIBARATION PAGE
You usually have to install a DIFFERENT cartridge at first to fool the printer into thinking you changed the cartridge then swap to the refilled one... Their feeble attempt at making sure you don't refill and use the same one.
Oct 27, 2009 | HP PhotoSmart 7550 InkJet Printer
Refilled my #21 cartridge, poor or quality or nothing is printed.
You have an air bubble between your print head and ink supply. This is something that commonly happens when you hand fill these cartridges. These cartridges need to be filled under vacuum to prevent this from happening. I recommend refills from Cartridge World because they have good prices with a 100% satisfaction guarantee.
Jun 17, 2009 | HP LaserJet Q2612A Printer
New black ink cartridge installed. Print became
Return the cartridge to the supplier - it is faulty.
Jun 10, 2009 | Office Equipment & Supplies
Printer cartridge is a refill and does not seem to be recognized
Maybe you can try to reset the black ink level 1st. To reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
Dec 23, 2008 | Lexmark X2500 All-In-One Printer
Working with cannon ip 1300
You need to have a black and a color cartridge installed to use your printer. That doesn't mean the color cartridge has to be full. You can have an empty color cartridge in the printer and it will work as long as the electronics are good on it so the printer can recognize it's there. You cannot refill these cartridges yourself. Your printer remembers what cartridges have been in it so that it can reject refills (it sees the same serial number twice and catches you trying to not give Canon their money). You can use refills, but you need to get them from a refiller with a high turnover of cartridges so you don't get the same serial number twice. I recommend Cartridge World stores as they have high quality refills with a 100% satisfaction guarantee.
Sep 21, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Recalibrating a refilled black ink cartridge for a photosmart 7960
your printer probably cannot recognize one of both cartridges
clean the contacts of the cartridges and the contacts of the cartridge carrier  with a wet towel
if that does nt work your ink cartridge has probably overheated  because air has left in the cartridge after refilling and must be replaced
check here the right way for refilling
http://www.youtube.com/watch?v=dhDaKSzou50
Sep 09, 2008 | HP PhotoSmart 7960 InkJet Printer
HP Photosmart 2710 All-In-One InkJet Printer Logo
186 people viewed this question
Seeker5211
Seeker5211
