Question about Refrigerators
Ice tastes and smells bad - Refrigerators
  • stanbennett Jul 28, 2008
    Thanks for trying but I changed the filter, cleaned entire inside of freezer and fridge (and contents containers) with bleach solution, and checked the water supply lines for mildew. There is still a reduced odor but mainly in the fridg side (of the sided by side) fridgidaire, and the ice still tastes slightly like freezer frost.
Inline water filter needs replacing.
Posted on Jul 25, 2008
  • 1073 Answers
SOURCE: Ice from Ice maker smells
if the ice has been in the freezer ice bin for a couple of weeks or if you added any food to the freezer that is not totaly frozen before adding then the ice will absorbe the odor of the food added, also the defrost of the evaperator will also add to bad ice taste
a new filter for the ice maker is maybe needed, depending on how long it has been since it was changed
if it has been changed, youcan try this whirlpool tip
put a small pie pan in the freezer and one in the fresh food section
add 1/2 inch of fresh coffee not coffee grounds to each pan
leave in for 24 hrs
dump out coffee in the sink drain
repeat the process
dump coffee in 24 hrs
odor GONE
Posted on Apr 17, 2008
  • 1122 Answers
SOURCE: ice tastes bad
need make and model number,i;ll get back with you-mike
Posted on Oct 15, 2008
Arius
  • 446 Answers
SOURCE: Ice tastes bad even after I changed the filter?
allow your ice maker to dispose old water that is still stucked on its hoses, just throw those unpleasant ices's and water would simply replenishes with a a fres and good supply
Posted on Nov 27, 2008
  • 9 Answers
SOURCE: Smell & bad taste of water from refrigerator dispenser
depending on the brand and the style, locate the filter and change it out. Please note that you must empty out the remaining water from the refrigerator cause if you don't, when you change out the filter you might get the same taste for a while until all the remaining water is replaced by freash water.
Posted on Jun 23, 2009
jvernice
  • 63 Answers
SOURCE: bad smelling water
The water lines are contaminated with bacteria and/or mold. This is a problem with many refrigerators. You need to turn off water and disconnect the feed line and filter. Mix 4 ounces of Clorox(R) in 1 gallon of water and pump it through with a NEW garden sprayer. You can remove the wand and clamp it onto the water inlet. Activate the dispenser while you pump the bleach through the system. Once bleach starts coming out the dispenser, vent the garden sprayer (de-pressurize), Let the bleach sit for 15-20 minutes. Re-attached water using a brand new filter (do not use the old filter and do not put bleach through filter). Run water until no chlorine odor (it can be a while). This process needs to be done at least once a year.
Posted on Jul 29, 2009
Bad fan blower smell and bad smelling and tasting ice cubes from ice cube maker
If unit has a water dispenser, how does water taste? I've run across bell peppers that will emit a bad smell. Keep in mind 95% of all refrigerators circulate air from freezer to refrigerator side and then back. It continues to circulate air so bad produce from refrigerator side will get into freezer side and ice will absorb smell. First, dump all ice. Then line shelves in refrigerator side with newspaper, that absorb smells. You can even try kitty litter in small cups in refrigerator side. Bell peppers gives off that metallic smell and can take some time to get out of unit. Highly unlikely a motor is bad and you've already changed outside water line.
Aug 07, 2015 | Maytag Refrigerators
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
BITTER SMELL AND BAD TASTE IN ICE IN FREEZER
try putting an inline filter in your water supply line before you hook it to the waterline
Jul 12, 2009 | Refrigerators
Ice maker water taste like chlorine but tap tastes fine
Put a in-line water filter on the water line if you want. The taste is from the food and items you have in the refrigerator. Clean it out and keep your items in proper storage. Ice collects the smells in the line and the fridge. Change your ice that is sitting in the bin, wask out the bin with water and baking soda. Hope this helps.
Apr 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker has bad taste and smell
Add a cap of Miltons or a couple of granules of pool chlorine. Allow it to stand for a couple of hours and then drain.
Mar 08, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
885 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
