Some letters are locked
When i press L i get 6,U i get 4... how do i unlock it?
thanks
  • Deb60137 Oct 11, 2008
    That, I believe, is wrong. I have a laptop HP Pavilion dv9815nr Notebook PC. My keyboard worked fine and my numeric keypad worked fine - now all of the sudden, if I want to use the numeric keypad, I have to turn on the num lock and if I don't turn it off, my alphabet keys give me numbers and garbage....It did not need me to do that before, so why now? What could I have hit to change that?
    Master:
  • 461 Answers
The Num Lock default is normally set in the BIOS depending on the model you can press F1,F2, or DEL to access setup while booting and change the default for Num Lock to Off
Posted on Nov 20, 2008
  • 3 Answers
From the question I can assume that you are using a laptop computer. The reason that his happens is because you have hit Num Lock thus enabling the numerical terms in place of your alphabetic ones. The reason that they overlap the keys is that laptops are compact and cannot hold their own number pad, so they simply make it a toggle on/off thing for people who like using the pad version rather than the lengthwise one above the normal letter keys. Hope this helps!
Posted on Jul 29, 2008
When yo press a key on the keyboard like the letter J instead of the letter J appearing the number 6 appears
Welcome to Fixya
Try to press Fn + numlock key. The keyboard might be number locked.
Thank you for choosing Fixya!
Oct 07, 2011 | Lenovo b560 Notebook
Tip
Thanks Robotek. Here is what worked for me- the differences is in how you enter...
Hi there, there is a standard procedure we use to bypass the code when we have the gear on the test bench for repair. Try this and it should sort out your problem
You need the remote control to do this, if you don't have one, then you may need to go to a KENWOOD agent and get them to clear the code for you, or purchase one for your use.
KENWOOD KDC SECURITY CODE CLEAR procedure
Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
The security is canceled and the set enters the TUNER mode!
:) POSITIVE FEEDBACK :)
A FixYa rating would be fantastic for helping you out with this techo tip.:)
A FixYa vote is a great reward for the challenge of solving your problem
ask Robotek
on Dec 07, 2010 | Kenwood KDC-135 CD Player
I have the BC370CRS SCANNER I am trying to clear all the memory and reset it. It is telling me to hold down 2, 9, and hold and turn it on. That is not working. Can you please tell me another way to do...
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again. Restoring All Locked Out Channels You can restore all locked-out channels in a bank only when the bank is selected for scan. Follow these steps to restore all locked-out channels in a bank. 1. If you de-selected the bank, press SCAN then press the bank's letter. 2. Press MANUAL. 3. Hold down L/O for about 2 seconds. The scanner beeps twice and unlocks all To delete a stored frequency, press 0 then press E. Channels with no frequencies are automatically locked out hope this helps
Mar 29, 2011 | Uniden BC370CRS Base Scanner
Bc898t all 500 channels are locked out. How to unlock all of them
Mar 29, 2011 | Uniden BC898T Base Scanner
How can ii unlock a blackberry.?!
How To Enter the Unlock Codes on a BlackBerry Cell Phone
422851199_3d16b31e6c_o.pngModel : All BlackBerry Models (except T-mobile)
1 – Using the menu go to Settings Menu -> SIM card press select.
2 – While holding the SHIFT key, type MEPD or (MEPPD for Vodafone Handsets)
3 – You should now see the five locking categories listed.
4 – While holding the SHIFT KEY, type MEP2 or (MEPP2 for Vodafone handsets)
5 – Release the shift key.
6 – You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 – Enter the code
8 – Enter Return/Enter
9 – The device should then be unlocked
Model : T-mobile BlackBerry Models
1 – On the Home screen, click the Tools icon. The Options screen appears.
2 – In the tools screen, select the Settings icon.
3 – Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4 – Type ‘mepd’ to display the first five levels of SIM locking.
T-Mobile uses network locking so the Network should display Active. All other states should display Disabled
Please note: For the Blackberry 7100t you will hit the “P” twice when entering the ‘mepd’ and ‘mep2′ for steps 4 & 5.
5 – Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
6 – Input the Network Unlock code
7 – Press ENTER and reboot handheld.
Model : BlackBerry Pearl 8100 (Alternative instructions if above instructions do not work)
Can be done without a sim card inserted
To Unlock:
1 – While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 – Choose “Advanced Options”.
3 – Select “Sim Card”
4 – There is no area to type these letters, you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled ( you will not see text appear on screen
while typing )
5 – Type m e p p 2 to display the dialog box asking for the unlock code
(Press the Alt + 2 key to get the number 2) ( you will not see text
appear on screen while typing )
6 – Input the SIM Unlock code
7 – Press in the trackball in once
Your phone is unlocked
Apr 10, 2010 | Cell Phones
My dell laptop types numbers instead of letters on some keys without pressing fn key
HI,
If you Are writing numbers instead of letters when you press the keyboard of your laptop and you must hold down the Function key (Fn) to write normally.
This is due to the fact that the digital lock is activated. To solve this, simply press the Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
Hope This Helps
THANK YOU
Feb 27, 2010 | Dell Vostro 1510 Laptop
Keyboard error keys
you have number lock on your keyboard, just unlock it and your keyboard will work correctly it should be next to your f12 key
good luck!
Ruben
Jul 19, 2009 | Sony VAIO VGN-N320E Notebook
Letters are num locked. pushing num lock key does not resolve
Number lock, a situation where numbers instead of letters are typed is as a result of the digital lock being active. to deactivate pressing the Fn+Numlk or Fn + Shift +Numlk key combinatioins
Jun 18, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
How to unlock a blackberry
BlackBerry Pearl 8100 Can be done without a sim card inserted To Unlock:
1 - While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 - Choose “Advanced Options”.
3 - Select “Sim Card”
4 - There is no area to type these letters, you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled ( you will not see text appear on screen
while typing )
5 - Type m e p p 2 to display the dialog box asking for the unlock code
6 - Input the SIM Unlock code
7 - Press in the trackball in once
Apr 28, 2009 | HTC TyTN Smartphone
Free unlock for samsung e250
i need the puk code to unlock my sansung E250 thanks
Jun 22, 2008 | Samsung SGH-E900 Cellular Phone
Computers & Internet Logo
628 people viewed this question
David Payne
David Payne
