Question about Olympus Stylus Verve S / ?-181 mini S Digital Camera
Battery compartment lid broken
Need advice on buying new part and making the replacement.
Thanks!
Joel
  • jearnest Feb 08, 2009
    After confirming what I suspected--that a factory repair was too expensive--I used model airplane glue tor re-attach the broken locking tab. After six months of intermittant use, the tab is still in place.
    It is important that the tab is correctly positioned and that the glue is allowed to thoroughly dry. I let mine dry for a week, just to be on the safe side. I've also learned to treat the cover as a very delicate component, and am a lot more careful with it than I was before.
  • 3 Answers
2008 CTS trunk won't unlock
Hi Jeff,
I was going to say, check fuse/ jump the load side of relay Good post.
Mar 19, 2017 | Cars & Trucks
I need to replace the lid of the battery compartment which has broken off or the compartment itself. Is this possible?
lids are detachable in some cameras for installing battery grips. try to add photo if possible.
www.facebook.com/aaleee
Oct 04, 2015 | Cameras
Can battery compartment be repaired when tabs are broken off which hold lid down?
possibly...if it is the body where the tabs are broken off the manufacturer (Olympus) might be able to replace the body shell. I'd check with them.
Aug 16, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
Fujifilm S1500. Batter compart doesn't close
If you can't return the camera for service, my advice would be to close the battery compartment with tape. Not pretty but better than buying a new camera, I've done it a few times on old cameras and apart from cosmetics, works fine. Just make sure to use enough tape so the batteries won't fly out when using it.
Jul 14, 2010 | Pix FUJIFILM Fine S1500fd Digital Camera
Keep putting in new batteries but the camera power on then when I turn the camera back on the camera do not come on
Hi,the problem you are encountering is definately a power problem which is possibly from a broken little switch under the battery lid.Here is the solution;
1.Check the little switch beneath the battery lid,it might be missing or broken,if it's broken you have to solder it bact to its place with the help or a soldering iron,if its missing you have to purchase another one from a part shop.
2.A temporary solution(maybe permanent),you can jump a tiny connecting wire on the switch,which makes it on a constant on status.
NOTE;by doing so,you won't have the battery lid detect function.The camera can be turned on even when the battery lid is open.
Thanks and take care
Apr 23, 2010 | Kodak EasyShare C613 Digital Camera
Clasp to lid console top box broken. How do you
This part is available at your local Infiniti dealer. The plastic part is replaceable.
Feb 09, 2010 | 2008 Infiniti FX35
Broken battery compartment lid
you could but the cost and time would not be worth it,just find you some gray electrical tape,works wonders,but make sure you press down real firm while putting a good solid peace on ok. good luck hope i helped.
May 01, 2009 | Olympus FE-210 Digital Camera
Sentry s3877 battery compartment broke
I had the same problem with my Sentry S3877. I found the exact 4-battery replacement (with snap attachment on top!) at an online electronics.retailer, but had to purchase a lot of three. I don't need the other two, so I'll sell them for just $6 each to the first two folks to contact me mark@irregardless.net.
Oh, by the way, once the batteries went dead, you lost your combination! When you pop the new battery compartment in, the factory default combination will be in effect. That default combination is in your user's manual. I'm currently searching frantically for mine! Gee, how could I have misplaced it ... I just had it in my hands when I purchased the safe 10 years ago !!!
Anyone know the default combo for the S3877?
---- Mark
Sep 15, 2008 | Sentry Fireproof Safe
Replacement crock for rival crock pot model #38601
Go to www.crockpot.com and click on replacement parts.  The glass lid is $10 and sold through a company called jardenstore.  They are connected with crockpot.com.  The companies phone number is 1-800-323-9519
It is worth replacing
Oct 03, 2007 | Rival 38601 Smart Pot 6-Quart
Olympus Stylus Verve S / ?-181 mini S Digital Camera Logo
87 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
