I keep getting a message : run (C:)chkdsk/f but I do not know how to do this - please help
    Genius:
  • Computers & ... Master
  • 1,056 Answers
If this is on an XP machine, close any programs that are open, click on START>RUN and type in chkdsk /f and click OK.
It may ask if you want to run it on the next start up, tell it yes, and then reboot your computer.
Depending on when and where you are getting the message, this may be early warning signs of a failing hard drive. I suggest you back up any important data as soon as you can.
Posted on Jul 25, 2008
When I try to defrag my pc I get a message that says "Disk Defragmenter has detected that Chkdsk is scheduled to run on the volume (C:). Please run CHKDSK/f. Don't know how to do this
above statements are right you may also run disc defrag to your system
click start/controlpanel/Administrative Tools/computer management/storage/disk defragmenter
then select or highlight the drive where your operating system is installed
click defragment
Sep 10, 2011 | E-Machines eMachines Desktop PC
Chrome.exe - corrupt disk the file system structure on the disk is corrupt and unuseable. Please run the Chkdsk utility on the volume C:.
While installing Google Chrome, the installation program detected problems with the file system and wants you to run chkdsk to repair them. Either go to a cmd prompt (or click on Start, Run) and key-in chkdsk /f The /f instructs chkdsk to fix any file system errors it finds as it checks your hard drive, You will receive a message the the disk is currently locked and asking you if you want to run chkdsk the next time the system starts, Respond with Y. Then restart your computer. You will receive a message that a disk check has been scheduled - allow it to proceed. Chkdsk will execute and repair any problems it finds with the file system. After completion, your computer will start up normally. Now you should be able to install Chrome.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jul 13, 2011 | Google Chrome
Message= block 20560772 uncorrectable data hard drive
Hello sicily0144,
One possible solution is to open a cmd window and type chkdsk /f.
• The cmd window can be accessed by clicking on Start and Run. Then type cmd and click ok*
• Type 'Y' (Yes) if the following message displays when running chkdsk /f :
"Chkdsk cannot run because the volume is in use by another
process. Would you like to schedule this volume to be
checked the next time the system restarts? (Y/N)".
Chkdsk will try to fix the bad block problem when the computer is restarted.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 04, 2010 | Dell Inspiron 1501 Notebook
Can not use defragmenter on computer. Windows XP system, when I try to defrag I get a message disk defrag has detected that chkdsk is scheduled to run on the volumn:(c:) Please run chkdsk/f. When I try...
Manual steps to run Chkdsk at the command prompt
Click Start, and then Run.
In Open, type cmd, and then press ENTER.
Use one of the following procedures:
To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
Note If one or more of the files on the hard disk are open, you will receive the following message:
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
check additonal instructions on:
http://support.microsoft.com/kb/315265
This will help you to solve the problem
Aug 30, 2009 | Computers & Internet
Restart
Chkdsk is a utility designed to check the integrity of the data on a computer's hard disk drive as well as find and fix errors which could corrupt such data.
Running chkdsk on your Windows XP or 2000 system can repair minor Windows problems
There are several different methods that can be used to run chkdsk
start with this one..... chkdsk c: /p
1. Click the Start button then... Run
2. In the Run window's Open box... type in ... cmd
3. Click OK and an MS-DOS-style black screen will appear in a new window
4. Run chkdsk by typing one of the the following commands where the cursor is blinking...
chkdsk c: /p and then press ...ENTER...
This is a short test that will tell you whether or not a longer test is needed. If after the test is done and a message ...One or more errors detected on the volume... appears then proceed to one of the next options...read them both first
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 17, 2009 | Intel Pentium 4 630, 3.0 GHz...
I have a Dell system with microsoft windows XP. The last 2 days I have gotten a message that a file is corrupt and unreadable and to run a chkdsk utility. I have tried to on two fronts but it refuses to...
use this one:
chkdsk /r
box will come up saying your drive is locked.
Type "Y" for yes. press enter.
Restart the computer and let the disk check process run.
Pay attention towards the end you'll get a two second flash telling you if there were any problems, etc.
Let me know what happens.
Mar 02, 2009 | Microsoft Windows XP Professional for PC
Can't get to disk defragment my laptop
How To: Fix Windows Built in Defragmenter
Had the same problem, turns out that in SP2 you have to have "DCOM Server Process Launcher" enabled in administrative tools> services for the
· First open up a Command Prompt, this can be found at:
Start -> All Programs -> Accessories -> Command Prompt
· Change into your windows\system32 directory. Your windows directory will be either windows or winnt. Type:
cd \windows\system32
Register the defrag components, by typing:
regsvr32 dfrgsnap.dll
regsvr32 dfrgui.dll
At this stage, you may find the defragmenter works. If not, there is one more step you can do.
Using Windows Explorer browse to your windows\inf folder.
In there you will find a file called
dfrg.inf right click this file, and select Install.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 19, 2008 | Dell Latitude D600 Notebook
External disk drive full when i try a operator initiated backup
Before runnning the backup please go ahead and run the check disk once..
chkdsk /f/r use this command on the command prompt
Nov 11, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Computers & Internet Logo
David Payne
David Payne
