Question about Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard
Motherboard accepting sata cords for hard drives
I can't seem to find the fitment places for the sata hard drive cords on the motherboard. Is this motherboard compatible for this Hard drive?
    Genius:
  • 1,269 Answers
I searched the specs of this motherboard and it doesn't have SATA port. Better change your hard drive with IDE. Otherwise, upgrade motherboard with SATA.
Posted on Jul 25, 2008
    President:
  • 1,114 Answers
I'm afraid that this board does not support SATA drives.
Hi - You can download the manual from the link underlined in blue below:
8VM533M-RZ
Please update the question & let us know if the information given was useful to you - Good Luck!
When I switch on my computer it will not activate the hard drive, but keeps on restarting. The red and green lights on the motherboard stay on.
try to change the pin at the back of your hard drive, place it into master if it doesnt work move it to slave, and if doesnt work again. , change your sata or ide cord, and if doesnt work defenitly, your hard drive have a problem.Try to buy a new hard drive . .
and your power led is not a problem with that. .:)
Feb 09, 2011 | Gigabyte GA-EP45-UD3R Motherboard
How do you connect two hard drives to a computer?
1. For SATA, you just need a second SATA cable to plug it in and a power cable from the power supply.
2. For IDE, you will need a second IDE cable to plug the second hard drive, AND you will have to set both hard drives jumpers either to cable select or one Master and the other one Slave, based on which one you have the operating system.
Nov 12, 2010 | Maxtor Hard Drive
I wish to change my hard drive from ide to sata
SATA plugs are eith red or black. Usually grouped in four. They are plastic about 3/4 inch long and a 1/4 inch wide. I looked up your motherboard and the SATA connectors are actually blue. Located to the right of the green connectors.
Feb 25, 2010 | Foxconn Computers & Internet
How do i reformat C drive and keep my files on sata backup
dis connect the sata cable that attaches the sata hard drive to the pci card and then format c and re install with all the drivers you require for the pci card as well as motherboard drivers, network card drivers etc and then re attach the sata cable that way you dont get confused between which drives its showing if it manages to display the sata drive at boot up.
May 16, 2009 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Difference between HDD and SATA
Buying a new SATA hard drive is confusing if you don't understand the differences between the various drive types. Which hard drive should you buy?
SATA Hard Drives (Serial ATA) are the most popular drives being sold today. Alongside them in the store however you will also find boxes labeled Parallel ATA or SCSI. So what are the differences between these hard drives and which one should you purchase? Your decision is dictated by what your computer can accept. Check with your computer's manufacturer to see which drive style you can use. Most newer computers purchased within the last two years accept SATA connections. If your computer cannot accept one of the newer SATA hard drives you can purchase SATA adaptor cards that plug into an empty expansion slot on your computer's motherboard. You can purchase SCSI adaptors as well, so follow these tips to guide your decision.
SATA vs PATA: Serial ATA vs. Parallel ATA Drives SATA hard drives have many benefits over their older cousin, the Parallel ATA drive. Chief among these differences are:
  • SATA hard drives are faster and perform much better than traditional ATA drives and are better for high bandwidth applications such as video editing and multiplayer gaming.
  • SATA drives use a smaller, cheaper cable to connect to the computer's motherboard. These cables can also be up to three feet in length compared to eighteen inches with Parallel ATA cables.
  • SATA hard drives can be hot swappable, meaning that they can be disconnected and reconnected without powering down the computer. There are limits to this of course. You should never disconnect your boot drive while the computer is operating.
  • SATA cables are easier to plug in without damaging the delicate connecting pins on the drive.
  • SATA hard drives are significantly faster than external USB hard drives.
SCSI Hard Drives SCSI hard drives are the elders of the storage world. SCSI is one of the oldest specifications but it is also the fastest and thus has been widely used in network servers and other high speed, high bandwidth applications. Unfortunately this high speed storage has also meant much higher costs. SCSI drives were once standard in all Macintosh computers but have since been replaced by the cheaper SATA based hard drives.
  • SCSI drives are also hot swappable, similar to the SATA drives.
  • Some varieties of SCSI can be used with SATA
  • SCSI drives are often set up in a mirroring arrangment to allow for instant, continuous backups of the hard drives.
  • SCSI drives are still the most expensive drives on the consumer market.
Your basic rule of thumb should be to purchase a drive that is designed to work with your computer's motherboard. Try to avoid using SCSI adaptors or SATA adaptors unless absolutely necessary as the whole point of using a specific kind of hard drive is to get the most speed and storage for the money.
Thanks alot,
Sanjeev Kumar
Jan 22, 2009 | Tablets & eReaders
Dell gx280 hard drive and dvd drive
You can buy adapters for this very thing. Less than 20 bucks at most computer stores. I looked on newegg and they were 11.99.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822998001
Nov 30, 2008 | Dell (2336V) Motherboard
My new WD SATA hard drive does not have a 4-pin connector
Hi nas2,
You can purchas a SATA power cord addapter that can assist you. The cord is called SATA Serial ATA Power Cable. Unfortunetly, Best Buy™ does not carry these cables. You can however google the cord and order it online for cheap.
Sincerely,
Agent Xiong
Apr 28, 2008 | Computers & Internet
SATA hard drives
you have to use with very small 180 to 90 degree cable for your sata connectivity
Good Luck
Nov 26, 2007 | Intel Motherboard
Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard Logo
112 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
