Refrigerators Logo
Posted on Feb 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Compressor fan has been replaced. Fan from freezer to refrigerator runs. Refrigerator cools then warms defrosting items in the feezer. Sometimes when I tap the panel where controls are located the refrigerator turns on.
Robert Moller
Level 3:
Guru:
  • Master 1,524 Answers
  • Posted on Feb 16, 2011
Robert Moller
Master
Level 3:
Guru:
Answers
1524
Questions
Helped
580046
Points
4327
Replace the control.
Fridge and freezer warm. condenser fan, evaporator fan and compressor running, cleaned condenser coils, new defrost heater and defrost thermostat. Still no cold air?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Unit not cooling down,compressor running,condenser fan running. suction line just cool,condenser line barely warm.
Check if evaporator fan is running. Is there any frost buildup on freezers evaporator cover? If so you have a defrost problem (bad heater, defrost thermostat, thermister, defrost timer or circuit board ). If no frost and the freezer is warm then you most likely have a sealed system problem(leak, restriction, bad compressor) which is costly to repair.
Need info for a kenmore side by side refrigerator model#59652673202 it it not cooling nor freeszing ; the light works and the fan works but not cooling any side please help me
Good day,
With that amount of info it would be hard to try to pinpoint it. Here's a list of items that can cause a refrigerator to not cool.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
As you can see it could be one of many,many items. If your handy with a meter you might want to start at the bottom back of the machine where the compressor is located.
Sounds as if it is not running, or running without refrigerant in the system.
Also, if it has a cooling fan motor in that area, make sure it runs, since all fan motors are wired to run at the same time.
Hello How to trouble my GE top feezer, it is making avery load noise.
Check the fan to see if it is hitting on built up ice...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Fan in feezer won't run
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
2answers
Poor cooling on frezer and almost no cooling on refrigirator
heatman101
My frigidaire refrigerator does not cool? what should i buy for it
Good day.
12. Excessively dirty condensor
Thank you for using FixYa
Refrigerated does not cool, freezer works
Most units have the cooling coils in the freezer section, then some vents and a fan circulates cold air into the refrigerator section.
If the vents are blocked by food items or ice, then the fridge will be too warm. Also, if the air circulation fan has failed, then cold air from the freezer will not get to the refrigerator.
On a self-defrosting refrigerator, this can be a sign that the defrost timer, defrost heater, or related part has failed. If the cooling coils are packed with ice, then airflow to the refrigerator does not occur.
Typically there is a electromechanical timer that you can see if you take off the lower front panel...this timer switch can be set so the defrost cycle happens when you want (like late at night).
You can also manually turn the switch to start the defrost cycle. Normally you hear the sound of water running and the scorch-hiss sound of an electric heater element touching water/ice when the defrost is taking place. The refrigerator compressor and cooling fan will typically be off during defrost as well.
3helpful
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
