Question about Sony Handycam DSR-390L DV Digital Camcorder
DSR 390 error
We are recordind in a beach. We turn off the camera, after 10 minutos, we turn on again.
The imagem doesn´t appear. The erron indicats in 95-123
    Scholar:
  • 154 Answers
If you put it down on the sand you probably got moisture or sand in it or possibly both if you put it down on a towel you may have gotten sand in it, try pulling the camera apart carefully and cleaning the chip boards unfortunately salt water will actually eat the protective coating on the boards and salty sand is worse most times you can't save them, sorry hope it works for you though
Posted on Jul 25, 2008
MINHA PLACA GV -650/800 (S) CONGELA IMAGEM DEPOIS DE ALGUNS MINUTOS DE Ligado.
Voce pode ter alguns virus e malware.
Comece o seu PC e prima F8 varias vezes ate que o menu de inicializacao vem a tona. Em seguida, selecione "Modo Seguro com Rede". Agora se alguns ou todos os programas gratuitos abaixo.
Baixe, instale e execute o Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
Quando Instalacao escolher a versao nao-profissional.
O download, descompacte, instale e execute TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Baixe, instale e execute Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
Se voce tiver um programa anti-virus desatualizado depois baixar, instalar e executar o Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Certifique-se de selecionar TODOS os "categorias de ameacas" quando voce instalar ou configurar o Avira ...
Vocee deve estar em boa forma, se voce executar e instalar todos esses programas.
Jun 29, 2012 | Computers & Internet
My camera view finder shows"Check
Good day,
The CHECK DIAG appears in the view finder when the camera's automatic self diagnostic function detects an abnormality.
From here you must first perform error checking on your camera by doing the following:
Press the menu dial.
This will perform the error check on the Digital Signal Processing(DSP) and the Memory Circuits.
When no error is detected OK will appear.
If an error is detected it will be displayed next to DSP or Memory on the screen. Diag Error will also appear.
If Diag Error appears contact your Sony dealer!
What this means is that the camera is doing a routine check or has detected an abnormality with the system.
I hope it is just performing a routine check and there is nothing wrong with your camera!
Best of luck and let me know if this was useful!
Kind regards
Dec 01, 2010 | Sony DSR-500 Mini DV Digital Camcorder
Lens error was at beach no sand but yet when turned on it says lens error
Anyone who has ever been near the beach knows that as soon as you are within 100ft of the sand you will feel sand in between your toes even with your sneakers and socks on. That's because sand is in the air and contaminates everything. Therefore, if you value your camera, mp3 player, radio, cellular phone PDA, or laptop computer, DO NOT TAKE IT anywhere near the beach. Solution: use an air compressor. Blow air & dust through the hose first. Use clean air to blow out extended lens area. Open and close lens and blow out several times. Firmly jolt the camera into the palm of your hand to dislodge the dirt particle. Use more air. You may notice sratches on the side of the lens cylinder that were created by the particles of sand. 99% pure isopropyl alcohol (91% if you're in a pinch is available at any drug store) can also be used on a Q tip and swabbed around the lens barrel cylinder. Make sure you use a few CLEAN Q tips on the lens. Now go buy a disposible camera and $10 mp3 player for the beach and leave the $200+ camera and IPOD at home or at the hotel room. Now you'll surely have a wonderful time at the beach.
Jul 28, 2009 | GE A730 Digital Camera
My cam is a sony dsr-390
Error code 91-258 is described as follows..
91- Microcomputer and its periphery device error
2- THREADING
5- S side reel FG
8- Detected abnormal current
Your camera got mechanical problem with Supply Reel and failed to load tape.
Jul 24, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
Looking for Filter Unit Optical Number of SONY DSR 390
hi ! i jasdeep working in superb broadcast
can provide the optical filter for your camcorder
Jun 25, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
Sony DSR 45P error code C3125
Press the power butten several times while holding down the eject button. It will solve your problem and clear the error. If it not then there is something wrong with your reel motor or the circuitery which deals the reel motor. You must consult your nearby sony service center.
Rajab Ali
Mar 08, 2009 | Sony DSR-45P DV / Mini DV VCR
Error problem
the error Er91-1d3 Parity error occurred in communication between the SY MICRO COM. and the DV MICRO COM. here what u have to checked is the cable coming from the MB board and FB board there is Three cable u juat check them and try to put it.
Hope it will work
Dec 14, 2008 | Sony Dvcam DSR-390P DV Digital Camcorder
Sony DSR-PD170 Color Problem
sounds like a problem with the image sensor, or an intermittent cable connection to the sensor.
Jan 06, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
DSR-1800 Lost Lock
This error 07.042 means Detected the abnormal capstan speed.here what u have to do go to maintanence menu.and check the capstan speed
Sep 28, 2007 | Sony DSR-1800 DV/Mini DV VCR
Sony Handycam DSR-390L DV Digital Camcorder Logo
107 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
