Cars & Trucks Logo
Posted on Jan 31, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need wiring diagram for 1992 Chevy Truck K 3500 4WD V8-454 7.4L. Someone other than me disconnect and pulled the complete wiring harness out, and as he came and handed it to me I stood there like a bump on a pickle in stunned shock. Help! If possible, can the diagram be faxed? ....Linda
Rick M
Level 3:
  • Chevrolet Master 4,148 Answers
  • Posted on Feb 01, 2018
Rick M
Chevrolet Master
Level 3:
Answers
4148
Questions
0
Helped
1254107
Points
13941
5 Related Answers
Anonymous
  • Posted on Dec 25, 2008
SOURCE: chevy s10 broken vacuum line
The plastic line in the wiring harness goes to the heater controls; and believe it or not , the other end goes to the vacuum tank - but its in the FENDER !!!!! behind the ABS, kinda under the drivers side hood hinge - great place to put one ain't it ? No wonder GM is going broke !! Good Luck
Anonymous
  • 290 Answers
  • Posted on Apr 03, 2009
SOURCE: 1998 Chevy blazer radio wiring diagram
http://www.the12volt.com/installbay/stereodetail/435.html
Anonymous
  • Posted on Jul 24, 2009
SOURCE: need wiring diagram for taillights on 2000 chevy venture van
I have a marker light out and it's the wiring somewhere, how's the best way to find the problem
Anonymous
  • 2926 Answers
  • Posted on Jul 24, 2010
SOURCE: Need diagram for spark plug wiring for 1997 Chevy
01f93b7.jpg ..............................
Testimonial: "Thank you for your prompt response. Saved my husband from some distress!"
Anonymous
  • Posted on Sep 03, 2010
SOURCE: wiring diagram for 92 chevy blazer
My Wife Lost the keys to her 92 Chevy blazer so i bought a new ignition key and forced the old ignition cylinder out.The new ignition would not turn forward.So I turned the ignition forward and an alarm come on I didnt no it had.I removed the alarm I ties all the same color wires together now im not getting any power.
Wiring diagram for heater blower switch in a 1992 chevy 3500 truck
try: https://www.google.com/search?q=Wiring+diagram+for+heater+blower+switch+in+a+1992+chevy+3500+truck&rlz=1C1GCEU_enUS820US821&source=lnms&tbm=vid&sa=X&ved=0ahUKEwit5ez6oLbeAhVh64MKHfBqB2IQ_AUIEygB&biw=1536&bih=775
How to wire the harnesses back to normal under dash after removing aftermarket alarm now the truck won't crank or start on my 1990 chevy c1500
go back and check the wiring you have removed some wires that you have disconnected ie ign or starter motor need to be reconnected back together check the wiring colors and reconnect back together to complete it back to origional good luck
Install new dash 1993 chevy cheyenne
quickest way here is to visit a wreckers and get the whole dash (gauges and all). Watch shows of vehicle assembly lines and you see that a completed dash is put in with nothing else to do except connect the wiring harness to the dash wires.
1998 Chevy SuburbanC1500 Wiring diagram
Your best bet would probably be to find a good harness in a salvage yard and change it out. There is nothing worst than trying to unscrew someone else's rats nest.
1992 chevy truck wiring diagram
The best way to get a wiring diagram for your truck is to buy a Haynes manual (about $25) for your truck at the auto part store. It'll give you a lot more than just the wiring diagram.
1helpful
1994 s-10 blazer 4.3 vortec wiring harness
The color codes will be different so when you take the harness off the 95 make sure that you label ALL the connectors to make it easier to install it on your Blazer. You may also have to change some sensors or switches up to 95 so that the harness will fit. Label all the empty connectors with their location in the 95 because they will be for options that may or may not be on your Blazer. If you have to access a wire diagram to complete the job then use the 95. DON'T let someone else take the 95 harness out for you andtake a rough diagram of your truck with the plug-ins marked for location and # of pins for wires. Basically it should fit but attention to detail is a must.
Also check out faxonautoliterature. They list GM service manuals but also GM books for engine interchanges that may prove to be very helpful. Hope this helps.
Need engine harness wiring diagram for 2001 chevy truck V8
The Best diagram you can get is at alldatadiy.com it has the sections and locations and color of wires with pictures.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
