I need your help now there is no volume on my computer
  • 27 Answers
Try looking at Start>Control Panel (Win XP) and the double-click on Sounds. Check the settings to see if they have been muted. If it is checked then uncheck the box and you should have sound. If unchecked then the volume may simply be all the way down. If neither of those then you may have a device problem. To check in XP goto Start>Control Panel. Double-click on System and then click on the Hardware tab. Click Device Manager and see if you have a question mark by Sound Category. If you do try removing by right-clicking and choose remove. Reboot your computer after this to see if your computer will reinstall the sound card.
Posted on Jul 29, 2008
Need to know how to put the volume on the desk top of the computer
Use a troubleshooters. Windows computers come with built in troubleshooters that can help you fix volume issues. Click on the "Start" bar, usually found on the lower lefthand screen. Click "Control Panel." On the control panel, click "Troubleshooting" and then "Hardware and Sound." From there, select the option "Troubleshoot audio playback." Your computer will ask you a series of questions that will help the troubleshooter determine the cause of your volume issue. In most cases, a volume issue can be fixed using Windows built-in troubleshooter.[
May 23, 2017 | The Computers & Internet
Volume on monitor
Take it in and have it bench tested.
Terry
Dec 16, 2013 | BenQ FP Computers & Internet
How to increase speaker volume on my laptop
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
hop this helps
Jun 09, 2012 | JBL CREATURE II Computer Speakers
Have Koss hd-50 (hand me down) would like a diagram, have no sound, running winxp on dell xperion 8400, says "no active mixer devices"
i will go through the process of setting up sound on your computer
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
if you need more help with this post a reply
hope this helps you
Sep 21, 2011 | Koss HD 50 Computer Speakers
Volume is turned off. There is only a down volume button on the bottom of the screen. How do I get the volume up?
hope this helps you
Aug 19, 2011 | Audio Players & Recorders
The speakers dont work even though the whole system is plugged correctley the light that should be lite near the volume controller is not working kindly help me in knowing the problem
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers if you dont have a motherboard disk you will need to download the sound drivers
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if you need more help with this posta reply
hope this helps
Aug 15, 2011 | Creative Labs Inspire T2900 Computer...
How do you turn up the volume? It only goes down.
To the best of my knowledge volume control on LCD monitors is controlled by the device that it is hooked up to. You probably have an 1/8" headphone type cable plugged into the back of it which runs down to your computer and is plugged into the Line Out / Speaker jack. So when you turn up the volume on the computer it should turn up the volume to the speakers in the LCD Screen. Let me know if you need more help, and if this fixed your problem please mark this as solved. Thanks.
Jun 30, 2011 | ASUS LCD Monitor
I can't find were you turn up the volume on my computer. i need a volume key on my toolbar.
try control panel sounds and audio devices speaker volume/audio hope this helps
Sep 02, 2010 | Toshiba (P000377700) Computer Speakers
Volume to low, need to increase , please help.
install sigmatel audio driver and it will increase ur vol
May 20, 2009 | Computers & Internet
In need of help with my opal
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 29, 2008 | RCA OPAL M4001 MP3 Player
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
