Question about IBM ThinkPad 570 2644 Notebook
MY LAPTOP KEEP SAYING "NO OPERATION SYSTEM FOUND"
I tried installing the laptop with a emergerny boot up disk, but it seem to have problem reading the disk...i tried the disk on a desktop and it's work but currently i tried putting ino the laptop, it's seem to have the problem.
tried using window 98 second edition as a boot disk but also fail..
i do hope you can help me solved this question...thanks
    Genius:
  • 2,028 Answers
This is generally a hard drive failure, but the machine should still read a disc. This sounds like a bios glitch, so try flashing the bios, then running the disc. If you flash the bios and it still won't read, then the problem will be with either the CD drive or the motherboard. Most likely the motherboard.
Posted on Jul 25, 2008
Hello, I have a Packard Bell branded laptop displaying the error there is no boot disk see details and the photos in first comment to know what happens and did someone can help me with it?!
If you set the boot order to USB first boot device and HD second. Insert USB and boot from there. It should find your HD and then you can install your OS. Another system for a different laptop will not work!
Jun 15, 2016 | Packard Bell Computers & Internet
Computer problem
take caution the SATA HD is Not reconized by Operation system as Installing Booting seq. Need to Change the Bios Setting from HD S*** to IDE. is needed in some computers, and try again
Dec 25, 2009 | Toshiba Satellite P105-S9722 Notebook
No operating system found
If the error message says "No operating system found" it is most likely a faulty disk controller or a faulty hard disk.
Reseat the hard disk, if this doesn't work you need to test the hard disk another way. Remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer sees this as an external hard drive and you can open the folders and files then the hard disk is OK and the fault is the disk controller on the the 4115c laptop.
If the hard disk is not detected then the hard disk is faulty. You need to install a new hard disk, install Windows and the laptop's device drivers and programs to get a working laptop again.
Sep 11, 2009 | Computers & Internet
I can't boot up the Vista install on a Sony Vaio VGN-NR160E
go to your BIOS Setup, see to it that there is a Hard Disk Boot Priority, maybe you didn't put it there.
Jul 21, 2009 | Sony VAIO VGN-NR160ET Notebook
The Problem is when i turn on the laptop system operation not found is written on the screen.
More than likely, your hard disc is gone, or a virus has corrupted your Operating System.
Try inserting your Recovery CD into your drive, and then boot from that disk for a restore. You'll probably lose your files.
May 28, 2009 | Fujitsu LIFEBOOK E351 (FPC030171) PC...
Toshiba Satellite 1800 Disk Drive Problem
There's an issue with the way yout laptop is booting, either its set to the incorrect boot device or windows cant properly access the hard disk. Take it into a PC repair centre.
May 17, 2009 | Toshiba Satellite 1800-S253 Notebook
Hard driver problem
you need to install an operating system on the hard drive, have you got a recovery disk with the laptop?
Nov 19, 2008 | Acer Aspire 3680 Laptop
Operating system not found
On my Windows 7 laptop, I have got "Operating System not found" error. to fix problem, Windows Boot Genius helped me finally!
Mar 15, 2008 | Gateway M305CRV Notebook
Compaq armada e500 850mhz p3 laptop
I'd like you to get into your bios. At the main bios window make sure your bios is seeing the hard drive correctly (model number). Also check that your cdrom is listed. While in the Bios go to boot & correct the boot order. 1st should be cdrom, 2nd should be your new Hitachi.
You mentioned you connected it to a PC. Than you installed WinXP & everything went fine. Disk read error means your laptop does not like the FAT. When you bought the Hitachi did you get a disk utility? If not download it from the link provided here & test your drive. Use the disk utility to set up your new drive & format
it with the utility. Try again to boot to your cdrom & install WinXP. If your XP does not include SP1 or SP2 your drive may show a smaller size.
http://www.hitachigst.com/hdd/support/download.htm
Good luck, I hope the disk utility fixs the problem.
http://www.hitachigst.com/tech/techlib.nsf/techdocs/50C8DBC2A315A4C786256F400065B756/$file/7K100_SATA_FINAL_DS.pdf (Info)
Feb 23, 2008 | Dell Inspiron B130 Notebook
Help me
Your Hard Drive is dead, time for a new one (but before you throw it out, be sure it was conencted tightly). (assuming you tried booting from abother a nother laptop's hard drive), if you tried to reinstall windows on it, then there is something wrong with the IDE (or ATA) controller in the laptop, you'll need a new motherboard. However if you just inserted the drive from the other laptop, just to see if it will boot up, theres a 99.9% chance that it will not work unless you format the Master Boot Record.
Aug 09, 2006 | Gateway SL1450-30145063 Notebook
IBM ThinkPad 570 2644 Notebook Logo
Top IBM Computers & Internet Experts
Computer Links
Michael Vincent Cruz
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
