Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark 5400 series printer
Display showing "clear the carrier jam{" what is solution for this When I try to print something it goes straight into the printermenu, then when I go to print nothing happens. I have full ink and my printer is set as default it use to print as soon as i pressed the print button and it wont scan now either. please can some one help fiona
  • dav347j Sep 25, 2008
    I have a virus from trojan something or other and it has knock out my c drive and cannot access my lexmark 5400 printer.
It seems you have some piece of paper in the carrier.
Could be just a very small piece somewhere in it... remove the cover and take a very close look. Check all rolls if they are loose or if something is locking them.
Posted on Jul 26, 2008
I bought this printer a couple months ago because I loved my last Lexmark and this was on sale. Worst printer in the history of printers. Won't print, jobs get stuck in spooler, plus a hundred other small problems that make printing one piece of paper a major event.
Dump it and buy something else because there is no solution to your problem.
Posted on Aug 26, 2008
Clear carrier jam
>> Remove the print cartridges.
>> Gently move the carriage from Right to Lift, Left to Right twice.
>> Re-insert the print cartridges
>> Try printing.
It may help.
Dec 28, 2013 | Lexmark International Lexmark 5300 Series
What's a Carrier jam?
Carrier Jam means that the Carrier which carries the cartridges is not moving correctly in this case please follow the below Steps:
Lift the Flat Bed Scanner up so that you can find the Cartridges Inside.
Remove the Cartridges from the Printer.
Move the Cartridge Carrier Back and Forth as fast as you can!
Replace the Cartridges back to the Printer!
Good Luck!!!!
May 07, 2013 | Lexmark 3-Pack Axis 5400 Print Server .:...
Clear carrier lexmark x3470m
Pull the power cord to the printer!
Take the paper lid out!
Check inside for jammed paper or other stuff!
Grab the paper with both hands and slowly drag it out whit out taring it!
When everything is clear! put the tray back in and plug in the power cord!
Restart and test to print something!
I hope it helps :)
Jan 14, 2013 | Lexmark X3470 All-In-One InkJet Printer
My lexmark x5630 x56xx series displays carrier jam the carrier bangs to the left, i saw a thin strip of plastic in the printer looks like its broken off from something please help
just try to fix it .but i think it is broken so you need to replace the broken part i advise you to show it service center.
Have a nice day and do not forget to rate please...!
Feb 03, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
I have a lexmark 2500 series all in one, the problem i'm having is that when i try to print, the paper does not feed in straight and then it stops feeding so i cannot print. i checked if anything has...
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Jan 14, 2010 | Lexmark X2500 All-In-One Printer
Lexmark 3500 carrier jam
Hi adirag! This is directly out of the user's manual! Clear Carrier Jam These are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges
______________________________________________
Hope this helps and good luck!
-WB
Jun 14, 2008 | Lexmark Wheelwriter 3500 Typewriter
Error 1203 and carrier jam error
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
May 24, 2008 | Lexmark P915 InkJet Photo Printer
Lexmark 5400 series paper jam
As several previous posts said there was a pieces of paper folded up inside. Per a previous post remove the sheet feeder rack. At this point I removed the two outside screws (of the three) on the backe. After this the whole top lifts about 3/4 inch (19mm) to give your fingers more room to clear it. Looks like she will print another day.
Thanks for the tips on here.
Ken Bowd
Nov 07, 2007 | Brother Multi-Function Center MFC-240C...
Just today, our Lexmark 5400 began having paper jam issues. We'd try to print, and the paper would initially feed into the back and then wouldn't go any further. Then it gave printer jam error messages. After peering and poking into various areas of the unit I wound up disconnecting the printer from power, phone line, and USB connection, I took it to a better lit room.
Peering carefully into the back paper feed area, I discovered a pencil!! After excising the pencil, the printer worked fine. One of my precious children must have accidentally dropped a pencil into the back, or a pencil was resting on top of the unit and rolled into the back paper feed area.
Lesson learned, don't put pens or pencils on top of the printer.
Jul 09, 2007 | HP PSC 2210 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
280 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
