Question about Onkyo TX-DS676 Receiver
Onkyo sub woofer
Hi
My Onlyo sub woofer has blown fuses and also resistance are blown too.
will my problem be fixed if I replace the fuses and the resistances or could there be other problems which are causing the obvious damage?
    Scholar:
  • 154 Answers
You will only blow fuses and resistors if there is a short of some kind you can change fuses, resistors and capacitors all you like if you don't find the short they will just keep on blowing. It maybe something as small as a bit of conductive material or fluff or dust on chip board wipe board down make sure it is clean (a clean toothbrush is perfect) and there are no signs of burns on either side of the chipboard befor you change anything. If there are burns or greenish build up clean them with some metho or water on a cloth not to damp though and make sure Burn or corrossion hasn't taken off the protective layer on the board.
Then try new fuses. Hope this helps you
Posted on Jul 25, 2008
Help me how to remove system error cod e000 for canon pc-d 340
PC-D320/PC-D340/FAX-L400 Chapter 4: Maintenance and Service
E000 Fixing unit failure
Cause: (1) Shorted/broken wired main thermistor (2) Shorted/broken wired sub thermistor (3) Broken wired heater/blown thermal fuse
Solutions: (1) Turn the power off and remove the fixing unit from the machine. Measure the resistance between the fixing unit connector J206-2 (FSRTH) and J206-1 (GND). If the resistance is not within the range between 350 KW and 520 KW (room temperature of 20°C), replace the fixing film unit. (2) Turn the power off and remove the fixing unit from the machine. Measure the resistance between the fixing unit connector J206-3 (FSRTH2) and J206-4 (+3.3V). If the resistance is not within the range between 370 KW and 520 KW (room temperature of 20°C), replace the fixing film unit. (3) With the fixing film unit removed, if there is no continuity between the fixing unit connectors J102-1 (ACH) and J102-2 (ACN), replace the fixing film unit. (4) Replace the ECNT board. (5) Replace the SCNT board
See Service Manual page 105 (4-25):
Canon PC D320 Service Manual Page 105
Jun 04, 2015 | Canon PC-D340 All-In-One Laser Printer
Sunfire true subwoofer signature one 7.5A internal fuse keeps burning out. what are possible causes and how to repair?
If you have an ohm meter (resistance) test for 7-8 ohms across each set of speaker leads to your sub woofer. Its likely you have blown speaker (load is causing amplifier to draw to much current) or just a bad amplifier in the sub (likely not worth $ repairing vs new). To test the sub woofer speaker itself you may have to take it apart to test its resistance.
May 26, 2014 | Durabrand STS98RW Theater System
Controler and sub woofer no power
This previous diagnostic, isn't good, if you test and no continuity between the positive and negative terminals generally means a blown sub.
You won't always get scratching or distortion from a blown sub. Sometimes the voice coil just overheats and burns out like a fuse. In this case there will be no sound at all from the sub, because no power can flow through the voice coil. A continuity test between the positive and negative terminals will show no connection.
Hope this helps.
Jul 05, 2011 | Audio Players & Recorders
So after getting my car back for the garage my subwoofer isn't working I checked to make sure all of the connections are correct and the settings are there why won't it work
Check to see if your amp is on. You may have blown a fuse somewhere maybe on your amp. Check for proper voltages and make sure the sub isn't blown by pushing on it. If you feel unequal resistance, you probably blew it. Also check the ohms on the woofer.
Jun 06, 2011 | Car Audio & Video
Hi i have problems with my subwoofer it wont play it's an alpine 12'' type e with alpine mrp m350 amp. there is light on the amp. how do I find out my subwoofer is blown or what else can be...
ok, your amp is in protect mode. either the speaker wires are crossed and shorting out, your woofer's vioce coils are melted and the speaker is blown or the amp is dead.
to determine if the speakers voice coils are melted, and thus the speaker being blown is the reason for the "protect" light, simply push in the cone of the woofer in gently with your hand. the woofer should move a little more than an inch, without any resistance, before bottoming out. if there feels to be any resistance, like a rubbing or scratching, before the woofer bottoms out, then your voice coils are fried, and you need a new woofer.
Nov 25, 2010 | Car Audio & Video
System error 004
E004 Fixing unit failure
E100 Scanner unit failure
E246 The Counter board is left out
E676 Communication error
E677/6F-61 ROM check error
E677/6F-63 RAM error
E733 A fault occurred in the communication between the SCNT board
and ECU board/TOP signal cannot be detected
New E805 Fan failure
TRY THIS:
Measure the resistance between the fixing unit connector J301-1
(FSRTH) and J301-2 (GND).
If the resistance is not within the range between 350 W and 520 W
Measure the resistance between the fixing unit connector J302-1
(FSRTH2) and J302-2 (GND).
If the resistance is not within the range between 360 W and 530 W
between the fixing unit connectors J303-1 (ACN) and J303-3
(ACH), replace the fixing film unit.
(4) Replace the EPU board.
(5) Replace the ECU board.
Jun 24, 2010 | Canon Office Equipment & Supplies
MY PIONEER WOOFERS DOESNT WORK
disconnect it from the amp and use a digital mutimeter and check the resistance, if it's a 4 ohm sub your reading should be close to that number, if the resistance number is below 1 ohm, your sub is probibly blown
Apr 26, 2010 | Pioneer TS-W252R Car Subwoofer
I am not getting power to my sub-woofer that i added on sub works fine just no out put to it checked resistance getting nothing
Nothing = zero or nothing = infinite?
If it is essentially zero, you are probably OK since the DC ohms of nearly any speaker measures very low resistance; they are rated in impedance which is a complex combination of  resistance (R), inductance (L), and a little capacitance (C) and becomes the 'Z' of the rating of (typically) 4-8 ohms.
If it is measuring open (a flashing display on any resistance range of a digital meter), then you probably have a problem.
You can safely take a single flashlight battery (or any 1.5 volt cell) and apply this by tapping across the input of your sub-woofer. If it makes a fairly loud 'click' then the speaker is functional.     If it passes the test, you have connection or output problems from your amplifier.
Feb 28, 2009 | Technics SC-DV290 System
Sub woofer not working
maby a fuse or blown speakers try to replace the fuse
Jun 23, 2008 | 1999 Ford Explorer
Car Audio (amp over heating)
The problem would be if you had it switched around. The 1200W subwoofer only means that it can handle 1200w of power the 1000w amp means that it can deliver 1000w of power. What you may have is an impedance mismatch. My question is what is the resistance rating on the sub woofer and what is the minimum resistance rating of the amplifier. These are actully the important issues at hand. the rating of the subwoofer resistance in Ohms should never be lower then the minimum resistance rating on the amplifier. in fact the resistance rating on the amp should match the resistance rating on the subwoofer.
Sep 09, 2007 | American Pro VS-2043 Car Audio Amplifier
Onkyo TX-DS676 Receiver Logo
114 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
