Question about Electrolux 23 in. ESL624 Built-in Dishwasher
Electrolux dishlex dishwasher
Apperantly some problems (ch 7 today Tonight), with above dishwasher, which model number does this apply to??, Peter
Here is the full story.......
Sale of fire-risk dishwashers banned 5:00AM Thursday July 24, 2008
New South Wales last night banned the sale of dishwasher brands fromAustralia's largest whitegoods supplier after the faulty machines werelinked to a string of home fires.
More than 26,000 Electrolux,Electrolux Dishlex and Westinghouse dishwashers sold in Australia andNew Zealand since April last year have a potential wiring fault.
TheNSW Fair Trading Minister, Linda Burney, said her department had beenalerted to 73 incidents involving the appliances, resulting inexcessive heat and kitchen fires.
Electrolux identified a fault with the dishwashers last year and has issued three appeals to consumers.
"Despitethis, Fair Trading has received reports that fires or incidentscontinue to occur," Ms Burney said. Up to 5000 of the dishwashersremain in households unchecked.
The minister said a wire connector within the appliances could cause plastic components to melt in the control panel.
The largest number of faulty washers are in NSW.
The state Commissioner of Fair Trading has moved to ban NSW retailers from selling their remaining stock of the appliances.
"The prohibition will ensure that any dishwashers not alreadyquarantined by Electrolux, which may be in retail outlets and not inthe possession of Electrolux, are not sold," Ms Burney said.
Theban and the recalls cover Electrolux, Electrolux Dishlex andWestinghouse washers with serial numbers ranging from 70700000 to72400000.
The NSW Government said consumers with one of thesemodels should stop using the machines immediately and contactElectrolux to arrange for a technician to fix the problem.
- AAP
This story was found at: http://www.nzherald.co.nz/section/1/story.cfm?c_id=1&objectid=10523214
Posted on Aug 11, 2008
Www.nzherald.co.nz said it affects Electrolux dishlex machines with serial numbers 70700000 to 72400000
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Dishlex 302 leaks from underneath
Good Morning Friend,
This appears to be a UK Electrolux dishwasher; however, if you have a US Electrolux model, here are a few tips you can attempt to troubleshoot the issue: First, Use only fresh detergent designed for automatic dishwashers. Measure detergent carefully. Possibly try a different brand of detergent. Secondly, spilled rinse aid can cause foam and lead to overflowing. Wipe up any spills with a damp cloth. Lastly, check to see if your dishwasher is level. If your dishwasher is still leaking, after trying the above solutions, I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best regards-
WP
May 19, 2014 | Electrolux 18 in. ESL4114 Slim-Line...
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
I need a free manual for the dishlex global 450. Most sites request you sign up.
Here in the state, Dishlex is the same as Electrolux. I would think the models are the same,except fort he number. Take a look.
http://www.electroluxappliances.com/kitchen-appliances/dishwashers
Oh yes here is the Australian manual download site also:http://www.dishlex.com.au/downloads.html
Hope this helps.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
Feb 20, 2011 | Dishwashers
Wanting a maunal for Dishlex 300 global dishwasher. Model DX 300 WA * 01. Thanks
Try this site. www.appliancehelponline.com Just supply your model or product number.
Hope this helps.
Jun 07, 2010 | Electrolux Dishwashers
User manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Nov 12, 2009 | Electrolux Dishwashers
I want to download a Dishlex DX103 dishwasher manual
want to know as this is my first dishlex dishwasher dx103. As there is no instruction manual being a rented property i want to know how to get solution on my problem. Was working last night but went to put a load on this morning but now have lights and thats it no cycle please help.....
Sep 19, 2009 | Electrolux Dishwashers
Dishlex Global Unable to remove heater element retaining screw
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
May 24, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
I have a dx302. its not heating the water or drying.
My six year old Electolux Dishlex DX 403 dishwasher stopped heating the water. I found comments on the internet about burnt out solder joints in the control box. A friend opened the control box and found a blackened area on the back of the circuit board. Once the connection was re-soldered the water heated again. We also found that quite a few wires leading to the control box had overheated and the insulation had melted. Considering that this dishwasher was the top model from Electrolux at the time, I was not impressed. I had previously had a Vulcan Dishlex for almost 20 years.
Thanks to those people who previously posted information about this fault.
Feb 10, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Electrolux 23 in. ESL624 Built-in Dishwasher Logo
1,288 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
