Minolta EP 6000 error code C0072 will not go away
Error code CO200. What is this.
Posted on Aug 12, 2011
  • Afzaal Hussain
    Afzaal Hussain Nov 30, 2013
    200 code is krono wire ki safai karian
210 code
Posted on Nov 10, 2010
Minolta ep 6000 error code 410
Sir/Mam the bright light under the big glass is the problem it is not coming on or is having problems. See about replacing the lamp or the circuit board associated with that lamp. To reset open front door to your left is a small access cover remove and with machine on press the trouble reset switch. If the code comes back get a new lamp and or board
Jan 04, 2014 | Minolta EP1030/1030F CS/PRO Copier
C0072 copy error
The error code C0072 deals with the toner hopper. I would remove the toner bottle and close the front door and wait till the copier comes to ready and make a copy, if it works install the toner and see what happens. The problem may be in the toner bottle holder.... There is a "HP" sensor that may be dirty or broken. Good Luck
Nov 05, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta CSPRO EP 3050 CODE ERROR C0072
Sir/Mam Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the front cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Aug 28, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta ep 5000 error c0072
A C0072 error code deals with the toner bottle. Remove the toner bottle and close the front door and let the machine warm up. Make one copy and install the toner bottle again. The toner holder may have not been in the correct position. If it continues, you may need to call a service person. Good Luck
Dec 07, 2012 | Minolta Office Equipment & Supplies
Minolta 6100 displays message C0072
Are you certain it is a Minolta 6100? The only 6100 I am aware of is a Magicolor 6100 color printer. My service manual for that model lists no service code C0072.
C0072 is a common Minolta copier code which pertains to the toner add system. I had a service call the other day for C0072 and it was the toner cartridge not fully "locked" in to it's receptacle, so you can start there. Opening and closing the front door on most Minolta's will reset this code.
Good Luck
Oct 21, 2009 | Minolta Office Equipment & Supplies
Copier Minolts ep4050 error code C0072 +
C0072 is aerror code for the sub hopper unit. It is having a hard time adding toner or that the toner motor is ON for to long. It is having a hard time kepping up with the ATDC. The M2 is a counter, it can be reset in service mode, but major parts have to be replaced to clear it..
Mar 25, 2009 | Minolta EP4000/5000 CS/PRO Copier
Minolta EP 5000 error code c0b63
Hello sir; that code means sortr bins problem, I belived when you moved hit somewhere soter bin out of track( not line up).
Mar 22, 2009 | Minolta EP4000/5000 CS/PRO Copier
342 people viewed this question
jasbo
jasbo
