Question about Video Cameras
JVC GR-DX67EK Remove and replace battery fault
Hi Benimur
Thanks for the suggestion. I have checked the batteries and they are giving 8v +/- .01v steady with no load. I have tried a new battery from another camera and get the same fault.
We checked the start-up with another camera and the difference is that mine seems to wind the tape for much longer, then the fault shows up. If I switch on to Manual Record, and immediately press the Menu button, I get the menu to show until the tape winding completes then the fault shows. It does not give me time to get to the camera reset command.
If I set it to the switch to Still, ie through the memory card, I can get to the camera reset which then allows me to take still pics but I again get the fault showing on the video setting.
Is there another way to get into the software on this camera?
Many thanks
John
    Brigadier General:
  • 6,966 Answers
Hi again,
Appreciate the "Ask Me". With your indulgence, I would be reposting this in your original problem/post here.
Bear with me on this one, the battery. Your post, "wind the tape for much longer" (all other things being equal) would indicate a comparatively weak power source (the battery). Assuming that the battery is not weak, then the problem may lie on how the power of the battery is transferred to the camera.
Here is a test, try the camera with the AC adapter (with or without the battery). If problem persists, then it is internal to the camera, if it works and you could perform the reset, then it is a battery issue.
As earlier stated battery issues need not be the battery itself, it maybe how the battery transfers power to the camera. Check the terminals of the camera where the battery contacts. Clean or scrape and when you try the battery, apply manual pressure (press on the battery) to add force to the contact. See if problem persist.
Software (firmware) update - I am not aware of any updates for your particular model GR-DX67EK, however pls try here.
Again, good luck and would appreciate an update at your convenience.
Posted on Jul 25, 2008
JVC GR-DX67EX Digital Video Camera - Safe Mode Fault
Might it be that your problem is caused by weak battery or the battery contacts in need of cleaning? In certain instances, it may be necessary to lightly scrape the battery contacts so as to remove corrosion. In some versions/models, the battery contacts could be slightly bent in order to provide a more tighter contact with the battery when inserted. Please give the cleaning,bending a try.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 23, 2008 | Video Cameras
Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Apr 28, 2009 | JVC Video Cameras
Hi, Regarding the above fault with my JVC camcorder, I have solved the problem by removing the tape and replacing with a new one. Thanks anyway.
Regards,
**** Coupe
Mar 30, 2009 | JVC Video Cameras
My JVC GR-D77OU Mini DV Digital Camcorder is giving me the next messages: eject en reinsert tape. unit in safeguard mode. After ejectirn and reinserting the video tape it still does the samething. I have...
Remove the battery and or the power supply (plug), leave it out for a few minutes, then reattach. This should solve your problem.
Let me know if this helps....
Jan 03, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Camcorder keeps asking me to remove lens cap
Contact JVC, they fix this error FREE. They fixed my GRD-50. It's a common fault with lots of them. Give it a go. Good luck.
Dec 07, 2008 | JVC GR-D20EK Camcorder
JVC gr-d350u camcorder
TRi to check the take up wheel and idler gear or capstan motor is engaged with idler gear.
Jul 15, 2008 | JVC GR-D350 Mini DV Digital Camcorder
My Jvc Digital Video Camera GR-D371u has gone into SafeMode How would I go about getting it out of safemode i need it because i need it for my sisters wedding
JVC has some known faults with their camcorders-- and most of the solutions are outside the abilities of average users. JVC says in this instance, to remove the battery and the charger, and let the camera sit for some period of time. If the camera also has a small battery for keeping the date, remove it as well. Let is sit and then replug it in and see if this cures it.
Jan 24, 2008 | JVC GR-D370 Mini DV Digital Camcorder
JVC GR-DX67EK MINI DIGITAL VIDEO CAMERA
Previously, when I have experienced this problem, I have removed the battery for 24 hrs and on replacement switched the Camcorder to (M) and quickly pressed the "Menu" button. This has allowed me to scroll down the menu options to the Cam Reset option. Then I reset the camera and all is well. This has worked for the last 3 to 4 occasions, however, this time I cannot get the menu to stay on long enough to reset the camera. Any ideas?
Dec 10, 2007 | Video Cameras
Eo4 error code
HI SIR the fault is caused either by the take up or supply reel in the camera they are not rotating when the tape is inserted.maybe A defective tape or hung reel brake can cause this issue.or maybe a bad loosen guide of the tape path is lame , Try replacing the tape, if this does not resolve the problem you may need to seek professional service to have the reels checked. thanx and plz try to rate and remember i am here just to help u thx
May 08, 2007 | JVC GR-SXM920 Camcorder
Video Cameras Logo
192 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
