Question about Indesit Washing Machines
Clothes smell after wash cleaned filter still clothes smell
    Scholar:
  • 97 Answers
Set the machine off on a 95c wash with no clothes or soap in, the most likely cause is a build up of soap scum on the inside of the drum, also try to alternate between washing powders and liquid tablets.
hope this helps
Posted on Jul 25, 2008
My Dyson Animal vacuum smells horribly of dog. It's worse than my dog has ever smelled - even at his worst. How do I take apart the Animal to clean it properly? Can I use a weak water/Chlorox solution...
hi Donna.
Complete removal of pet hair from the home is a quandary many pet owners face. The Dyson Animal series vacuums use centrifugal force to remove animal hair from carpets, floors, curtains and upholstery. The high-powered vacuum is bagless, allowing you to extract pet hair from surfaces without worrying about running out of vacuum bags. As your Dyson Animal vacuum is exposed to pet hair and dander, a smell can develop. Similar to other small appliances, a vacuum needs periodic cleaning to keep it looking and smelling clean. When you use basic cleaning and deodorizing techniques, you can get the smell out of your Dyson Animal vacuum.
Step 1
Remove the bagless receptacle for pet hair according to the directions provided for your Dyson Animal vacuum. Hold the receptacle upside down inside a trash bag and tap the bottom to remove pet hair and dirt.
Step 2
Mix 1/2 tsp. of dishwashing detergent with 1/2 gallon of warm water in a bucket. Dip a clean cloth into the soap solution and wring it out.
Step 3
Wash the inside and outside of the receptacle with the cloth to remove dirt and dander that cause odor. Rinse the receptacle with a cloth dampened with water. Dry it thoroughly with another cloth.
Step 4
Remove the HEPA filter from your Dyson Animal vacuum. Pick visible clumps of pet hair off the filter and discard them. Flush the filter with cool water to wash out dirt and hair. Rinse the filter until the water runs clean. Gently squeeze the filter and allow it to air-dry for up to 12 hours to ensure it dries completely.
Step 5
Moisten a cloth with undiluted vinegar. Wipe off the exterior of the vacuum with the vinegar. Deodorize the receptacle and interior areas, where the bagless receptacle and filter go, by wiping them with the vinegar-moistened cloth. Dry the vacuum with a clean cloth.
Step 6
Place two drops of vanilla extract on a cotton ball. Drop the cotton ball into the receptacle before securing it to the vacuum to prevent odor from building up. Vanilla extract is an effective natural odor absorber.
hope this helps you out.
Nov 28, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a front loader that smells like something died in it. I have tried affresh bleach Tide washer cleaner Basic G leaving the door open cleaning the gasket washing the drum cleaning the filter and hoses...
you can open the filter drainage under near the drain hose. there may be something that comes into the washer drum and died leaving a smell. how to open the filter is rotated and pulled out only. then you try to drain the washing machine how to turn it. will allow water or sewage, which is in the drum filter out of the hole. and do not forget to clean the exhaust filter the water, there will be a lot of dirt.
Jul 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Clothes stink
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washing machine smells!!
Run a load of just water and chlorine bleach. Run it HOT. After that, use bleach to clean the door seal and seat.
Apr 10, 2010 | Zanussi ZWF1640 Front Load Washer
Machine smells mouldy- washing stinks!
Find out where your filter is; it is at the end of the thick hose coming down from the bottom of your tub; open up and clean out. Another possibility is there could be something stuck in your drum, feel if you could locate it. Next clean out the hoses in machine. After all this flush out with a hot wash, without clothes. People shd ask the service man where the filter is. If he knows that is.......................It gives you the biggest problem if you dont check.
Mar 19, 2009 | Whirlpool Washing Machines
Samsung washing machine filter
it has a self cleaning filter. if you want to clean out the tub and filter thoroughly then:
  • run a cycle with no clothes using hot water and a gallon or two of bleach.
  • after the tub has filled up add a teaspoon or less of dish liquid like palmolive. this acts like a surfactant for the bleach.
  • make sure you also run an extra rinse cycle to make sure you have all the bleach out of the machine before putting clothes in.
Aug 04, 2008 | Washing Machines
Clothes smell musty
Clean th filter in the front of tha machine. Than take an OLD towel and run a hot wash with chlorox.
After that you run it again with vinegar and that should relief your problem.
i have an LG too.
Jun 21, 2008 | LG WM-2077C Front Load Washer
Musty smell, but can't tell from where
I have the same problem with a 3 month old ge front loading washer.after 1 month it started off smelling musty..I thought it was my imagination, now at 3 months old our clothes smell so bad I think we might just have to buy new clothes! everytime I wash a load the clothes smell worse and now you can even smell it just walking into our closet 2 floors up. A new washing washing machine should NOT be doing this! so far leaving the door open in between washes has helped a little but I plan on tipping it back and finding the hidden filter today. Isn't it lovely that they don't mention a filter that needs monthly cleaning or it's location in the manuals?!
Apr 25, 2008 | GE WBVH6240F Front Load Washer
Washing Machines Logo
173 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
