Question about SanDisk Sansa e250 MP3 Player
Error 000099 When i turn on my MP3 the numbers 000099 appear then the MP3 turns off if you have any solutions please inform the site.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
Error code 1442 keeps coming up every time i try to restore my shuffle 3rd generation.
If your getting the 1442 error code wile trying to restore your ipod than you may need to reinstall itunes. The following URL will bring you to Apples ipod shuffle trouble shooting assistant. This site will provide you with a more descriptive trouble shooting process.
http://www.apple.com/support/ipod/five_rs/shuffle3gen/#
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 27, 2010 | Apple iPod shuffle MP3 Player
When I turn it on I get "System Err 50 please pwr off" how do I fix it.
Hi this is the only solution for your query jut do that
i) If these error occur, turn the DR-1 power OFF and restart the unit. If the error message continues to appear, contact a TEAC Repair Center
other than that no solution we have so far.
Apr 13, 2010 | Tascam DR-1 MP3 Player
When i open any site the message warning visiting this site may harmful to your computer and blank and blocked the windows. what is the solution.
The message "this site can harm your computer" means that the site is listed as a phishing or malware site. Actually, you can turn it off (there is an option in "under the hood" options tab), but it's not recommended., because it will not inform you of any other malicious sites. However, if this error appears for every site you login into, try installing a good anti virus software that also scans websites (I use Kaspersky anti-virus) and turn off the feature.
Jun 18, 2009 | Computers & Internet
I turn my mp3 on and its just turns off and when i connect it to a computer it will not work
The cause for the power failure has to due with the source, the reason why it wont work with the computer can be a varity of reasons, without further information it would be hard for me to provide a good solution.
Apr 22, 2009 | MyMusix PD-6030 MP3 Player
Alba mp31gd12 error 000099 and not conecting to pc or turning on shows only nubers
PLEASE NOTE: Re-formatting the MP3 Player will result in a loss of all original files!
I can personally say that the comment posted by 'babayigit-em' works perfectly. The procedure I followed was:
1) START > Run > (In this section enter the command: CMD)
2) In this black MS-DOS box enter the following command: FORMAT F: then press ENTER (Note:' F:' was the name of the drive my MP3 took, this will be different for many people so enter the one in 'My Computer' which your 'removable disc' MP3 takes up)
3) The command will produce a set of information i.e. your MP3 has so many bites and free bites etc., it may ask you to press ENTER again at a later stage it did for me click ENTER where it says and the message 'Format completed' should appear on the screen
4) Remove the MP3 drive from the PC, switch it on (It will say NO MP3 FILE) then re-insert it and hey presto it should work normally again but unfortunately the original files will have been lost.
Jul 09, 2008 | Audio Players & Recorders
The same problem...
Solution number 2 was not useful to my problem. My computer can't even recognize the usb port where it is plugged into. This happens on all computers - it goes unrecognizable! Any solutions to this besides throw this so called mp3 player out the window?
Mar 30, 2008 | SanDisk Sansa m240 MP3 Player
Help
when the starting screen comes up hit the menu button
Mar 15, 2008 | iLO MP3 Player
CRAIG MP4 plus video player- disk error message appears.
make sure the songs you download are right for your mp4 player because Limewire only plays mp3 songs. so i would go on the internet and find a music site that has mp4 songs
Jan 28, 2008 | iLO (2 GB) MP3 Player
Owners manual
Hi! Dear I have Owners Manual I can email you Also can you explain me how to open Gigabeat to remove battery and HD Please email me at PATELJITU28@hotmail.com I will attached manual once you provide me your email Thanks Jitu
Sep 01, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
SanDisk Sansa e250 MP3 Player Logo
133 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
