Question about Gateway Wireless-B Router (wbr-100)
Router gateway error
Hi guys
i just tried to access my router gateway on 192.168.11 but had no joy..i have a bt voyager 2110..i am trying to add a port forwarding rule
cheers
shane
  • bigfishuwish Jul 25, 2008
    Sorry guys typing error it was 192.168.1.1
Problem sorted not quite sure how but it is just tried one more time to log in and it worked??????????
cheers
Posted on Jul 25, 2008
How do I reset password on 7voyager
To change the access password on your BT Voyager router:
  1. Open the Router Manager by going to http://voyager.home
  2. Click 'Advanced'.
  3. Click 'Continue to advanced'. When prompted to login, enter your username and password. What is the username and password for my BT Voyager router?
  4. Click 'System'.
  5. Click 'Admin Access/Password'.
  6. Enter your new password twice. Please keep a note of this new password somewhere safe. If you forget this password, you will need to reset your Hub to factory defaults to restore access to the configuration of your router.
  7. Click 'Apply'.
  8. If you now browse other pages of the Hub/Router manager, you will be prompted to enter your new password immediately.
http://www.voyager.home/
Oct 30, 2015 | Computers & Internet
Bt voyager 2110
If you're talking about the Security Code/Password that you need to access a WiFi connection, that passcode is set by whoever set up the Login requirements on the router itself. You have to get that password from that person or the WiFi Router Admin page (if it's your personal WiFi at your home) If it's a Modem/WiFi unit from your Internet Service Provider (cable company), then you should contact them for the password (if they were the people who set up the password).
Dec 22, 2013 | Computers & Internet
I want to change from a bt voyager 105, to a bt home hub how easy / hard to do I am not really computor minded. telboy..
It is not hard just you need to reconfigure your router WAN settings.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 01, 2010 | Computers & Internet
Installing BT Voyager 105 on XP Pro PC shows newdev.dll error
I recently had this problem after buying a voyager 210 modem/router to replace the voyager 105 (in my case supplied for AOL broadband)
I tried to uninstall the voyager 105 and encountered exactly this problem - newdev.dll missing, Admin privileges required
After alot of Internet searching I found no answers. But in desperation tried this and it worked. I am by no means any computer expert so don’t blame me if this does not work for you, or damages your machine.
To install my 210 modem I was following instructions found here -http://www.sohodata.co.uk/soho.htm But first I had to get rid of the 210
Here is what I did, exactly as I did it (some of it is probably unnecessary) Further below is a condensed version I expect would work.
1) Firstly I restarted in safe mode by pressing F8 in start-up ( I was doing this because i had remembered an administrator profile and considered attempting to uninstall from there.)
2) I logged on as the administrator.
3) Attempted to uninstall the voyager 105 via control panel and via the uninstall icon in the programme folder. - Both Failed with the above-mentioned problem.
4) I navigated to programme files. (Start> My computer> C drive> Programme files)
5) There I highlighted the folders "British Telecom”, "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", "Voyager Test". I cut these folders wholesale and pasted them to my USB pen/stick (incase I needed to put them back)
6) I then ran disk cleanup (Start> All Programmes> Accessories> System Tools.)
7) Then I turned off my computer and unplugged the USB pen/stick and the USB and DSL cables from the back of the Voyager 105.
8)I turned the computer back on (starting up normally), logged on with my normal username which has admin privileges. Ran the driver install for my new router (previously downloaded from BT at –(http://www.btopenworld.com/broadband/adhoc_pages/driver_homepage.html#yahoodrivers) It stated that a BT driver was already installed.
9) Navigated to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall …. AND IT DID IT! No error, or messages about newdev.dll or privileges.
10) This left me free to install my new driver and go through its install process ending in plugging the USB into the back of the modem and having internet again.
Here is what I expect would work
1) Turn on and log on to any account with admin privileges.
2) Navigate to programme files. (Start> My computer> C drive> Programme files).
3) Select and delete (or to be safe, cut and paste to a removable drive) the folders "British Telecom", "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", and "Voyager Test".
4) Remove removable drive and run disk clean up (Start> All Programmes> Accessories> System Tools).
5) Then I turned off my computer and unplugged existing modem.
6) Turn on computer log back onto account with admin privileges. Navigate to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall.
7) Install desired drivers/modem.
If you find this works for you too and have asked this question elsewhere, please copy this solution so others can solve this problem too
Jul 11, 2009 | Computers & Internet
HP 530 Notebook Cannot find router but can see others
ACTUALY THAT IS ONE OF THE PROBLEM OF HP 530 LAST YEARS I MEET THAT PROBLEM ONE OF MY CUSTOMER COMPLANE ABOUT THAT WIRLESS CANNOT DETECT I TRIED MANY TIMES TO RE INSTALL DRIVER THAT DIRVER I GOT FROM INTERNET BUT THE SAME.. I TALKED HP SUPPORT REGARDING ON THAT PROBLEM,, THEY GIVE ME THE SOLUTION,, JUST INSTALL INTEL PRO WIRELESS..OR YOU CAN TALKE WITH THEM ABOUT THAT THEN THEY GIVE YOU THE LINKS OF THAT ESPECIAL DRIVER... GO TO HP THEN CLICK HP SUPPORT ONLINE CHAT WITH THEM.. THANKS
Jun 05, 2009 | HP 530 Notebook
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
I have an iPod Touch and I have been trying hopelssly to connect to the wifi. I have a BT Voyager 2110 router. I have been putting in the right password and it even says I am connected as it has a tick...
Well... since you said PLEASE help!
So what is the IP Address that the iPod Touch gets? Does it match with what range the BT gives out?
Does anything else connect through that router successfully?
You might try changing the WEP, WPA, WPA2 that you are using ... see if that helps the iPod touch to connect. I've seen where certain computers, etc. do not like WPA or WPA2 or certain passwords or key codes.
Mar 01, 2009 | NetGear DG834G Router
Trying to configue a 3com router as an access point
You have to configure the WDS on the 3comm, configuring it to the MAC ADRESS of the BT router (if it is wireless), if not connect it by ethernet and set the 3comm as WDS allowing the other 3 more u want to add as acepted MAC ADRESS for access points.
Feb 20, 2009 | 3Com OfficeConnect Wireless Router
Sharing internet with bt voyager 210 adsl router and linksys broad band router
hook you linksys uplink you cabel out from adsl router uplink other end goes to links wan
Aug 14, 2008 | Computers & Internet
Connection to intenet new router
hi
to login to the router your checkk the default gateway address and type the same in to the browser and launch in to the router to do check the configuration...
mac - check in network coonections
pc - ipconfig
cheers !!!
Feb 13, 2008 | Buffalo Technology AirStation WBR2-G54S...
Gateway Wireless-B Router (wbr-100) Logo
137 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
