I have hp laptop.i suddenly discovered a problem in the charging of my laptop battery.when it is plugged in it works properly but on turning it off and keeping it plugged in, the battery does not charge and if i attempt to start it without any ac supply it does not start.when it is working on power supply(ac mains) and if power fails process is no interrupted but it contiues(at this time the battery charge is used which is continuosly showing 17% remaining).please help me out.give me a solution other than repairing or changing battery.pllllzzzzzzz, im an engineering student and cant afford a battery renewal.looking for a solution.im very much upset with this.plzzzzzzzzz help me out.
thanks.
You won't like this solution--your battery is bad or your motherboard is bad. If the battery does not charge, it could have acquired a "memory." That is, it sees itself full when it really isn't and it will run down very fast.
If the battery doesn't charge at all, it could be the motherboard. One other thing you could try is cleaning the contacts on both the battery and the computer. This may help--could be dirty contacts are preventing it from working correctly.
