Question about Sharp EL-531VB Calculator
"Fix" How do you get rid of the word "fix" from the calculator display.
  • Sharp Master
  • 7,993 Answers
The top of the screen displays reminders on the current configuration of the calculator. The FIX will disappear if you change number display to SCIentific or ENGineering, but it will be replaced by SCI or ENG. Why does it bother you, since that part is reserved for the calculator's usage?
Hope it helps.
Posted on Sep 20, 2009
The words FIX DEG appear on the screen and I can't get rid of it. It doesn't calculate properly
DEG says that the angle unit is set to degrees. You can change it to RADians, or GRADs. However much you want to get rid of all of them you will always have one of them. Learn to live with them.
FIX says that the decimal displays will always show a fixed number of decimals. You can decide how many you keep. Apparently your calculator is configured not to show any decimal digits: the number of fixed digits is set to zero. Change it to some other number
There are other display formats : Engineering ENG, and Scientific (SCI)
There is another format (possibly 2) called Norm 1 or Norm 2.
Set you calculator to one of the Normal formats.
Press SHIFT MODE to enter (Setup) and configure.
Advice: Learn to use your calculator. The best way to achieve mastery is to look inside the manual whenever you do not understand something.
Dec 06, 2013 | Casio FX-300 Plus Scientific Calculator...
How to get rid of scientfic notaion
If you want a fixed decimal display mode, press SHIFT MODE 6 and then a digit specifying the desired number of digits after the decimal point.
If you want the calculator to decide, press SHIFT MODE 8 and either 1 or 2 to select one of the "norm" modes.
Be aware that if the magnitude of the number gets too small or too large to fit onto the screen the calculator will automatically shift to scientific mode no matter what display mode you have set.
Apr 26, 2012 | Casio Fx-991es Scientific Calculator
How to get rid of sci?
To get rid of this result display mode you set the display mode to another one: FIX, NORMal 1 or NORmal 2. But since you do not disclose the model and make of your claculator (are you afraid of calculator identity theft?) neither I nor anybody else will be able to tell you how to do it. Sorry.
Jan 14, 2012 | Office Equipment & Supplies
How do I remove the word fix from from calculator screen?
Why? Does it prevent you from doing your calculations. It is just a reminder to the user that the number display format is set to FIXed. To get rid of it you must change the display format to another one.
To do so, press the SETUP key, select 1:FSE, then select any format you want
0:FIX , 1:SCI, 2:ENG, 3:NORM1, 4:NORM2
You will be prompted to enter a number between 0 and 9. This will decide how many decimal digits will be displayed in your results.
Do not be surprised to see that the FIX reminder is replaced by the one you just chose.
Feb 23, 2011 | Sharp ELW535 Calculator
How do I get rid of the "FIX" at the top of calculator?
It is there to remind you that the result display format is set to a fixed number of decimal digits. If you change the setting to SCI, NORM1, NORM2 or ENG, the one you choose will be be displayed. So you will always have something displayed there. Do you still have enough reasons to want to get rid of it?
Here is how to modify the setting
Press SETUP
Select 1:FSE
Select one of the 4 options: 0:FIX, 1:SCI, 2:ENG, 3:NORM1, or 4:NORM2
If you choose FIX, SCI or ENG, you will be prompted to specify the number of decimal digits (0 to 9).
You might want to select NORM1 or NORM2.
Then select the number of decimal digits to display
Feb 14, 2011 | Sharp ELW535 Calculator
My casio fx-992s is showing fix and deg on the screen. I think the "fix" is causing me a problem but I can't get rid of it. All my decimals are being rounded up to whole numbers! Thanks
The DEG is merely indicating that the angular mode is set to degrees. If you want to change it to radians or grads, press SHIFT MODE and make your selection.
Likewise, the FIX is merely indicating that the calculator is displaying numbers in fixed decimal notation. If you're not seeing any digits to the right of the decimal point, then you're in FIX 0 mode. To change it, press SHIFT MODE. You can choose FIX and the calculator will prompt for the number of digits, or you can select NORM.
Nov 29, 2010 | Casio Office Equipment & Supplies
Problem withi scientific calculator
How do I get rid of the word "Fix" from the calculator display.
Jul 25, 2008 | Office Equipment & Supplies
FIX numbers
If you press the setup key then 1 under FSE it will say TAB (0-9)? enter the amount of decimal places you want and it will change that for you.
Dec 06, 2007 | Sharp EL-531VB Calculator
Screen not displaying whole letters because of horizontal and vertical lines
I've had the same problem. A temporary fix that I have found is to turn up the contrast all the way (press [2nd] then hold down the up arrow) until the screen becomes mostly black. Then turn the contrast back down (press [2nd] then hold down the down arrow) until it is at a normal level. If you can get rid of all the white lines when you turn up the contrast the screen will be back to normal. Unfortunately this does not permanently fix the problem because I cannot get rid of all the lines and it seems to be getting progressively worse each time it start up the calculator.
Oct 24, 2007 | Texas Instruments TI-83 Plus Calculator
Sharp EL-531VB Calculator Logo
394 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
