Question about HP LaserJet 2550L Printer
HPCLJ2550 goes offline
Everytime I print to our networked HP Colour LJ2550n it goes offline afterwards. Does anybody know why this is happening? It has the latest drivers and it has worked normally before. It also prints colour at times!!
Cheers
  • 38 Answers
Check for the latest firmware software at www.hp.com and its may be problem with network card its come embedded with main board
Posted on Jul 29, 2008
  • 4 Answers
Do da coal reset,& check da printer.
Posted on Jul 31, 2008
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
HP LaserJet Pro 400 MFP showing offline when printing
My computer says that the printer is offline and my printer will not print idk what to do... suggestions????
Oct 10, 2012 | HP Laserjet Pro 400 Mfp M425dn...
I plugged in the printer to my mac and everytime I try to print it says that the printer is "offline".
The first thing I would do is download the latest drivers from the hp website. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=219&lc=en&cc=us&dlc=en&sw_lang=&product=1139325#N669 Once installed the downloaded software may run a wizard which will allow you to setup the printer failing that go to system preferences choose print and fax and then clcik on the "+" sign and if the printer is plugged in it should show up under the printer names select your printer and then the under the Print using select the print driver. Hope this helps
Sep 24, 2010 | HP Deskjet 3915 InkJet Printer
DOES ANYONE KNOWS HOW TO SOLVE MY PROBLEM?HERE IT IS..IT ALWAYS OFFLINE MY PRINTER EVERYTIME i print it,he goes offline and the print is unabale to print can anyone help me?to fix..thank you. im using HP...
when you hook up your printer to your pc via USB...can the computer detect your printer? does it prompt out any msg such as new device is installed and ready to use or did it ask you to install the printer driver?
if your pc can't detect your printer, replace the USB cable and try again.. and try to plug into a different USB port on your pc.. and if all fails, then most probably your printer main board is faulty...
May 28, 2010 | HP DeskJet F380 All-In-One Printer
Hp deskjet 6980 will not change to online. Working wirelessly. It says Offline and can't be changed to Online. I have to reinstall everytime.
Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
Aug 29, 2009 | HP Deskjet 6980 InkJet Photo Printer
Printer offline HP 4500 series wireless.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | HP Photosmart C4580 All-in-One InkJet...
HP Officejet L7780
Do you have the latest drivers for this printer using vista?
Go here http://h10025.www1.hp.com/ewfrf/wc/product?product=2512010&lc=en&cc=us&dlc=en&submit.y=7&submit.x=5&lang=en&cc=us
for the latest drivers, software and support for your product
I hope this helps
Oct 20, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Printer offline issue
Check your network/network card settings. Is your network card falling asleep when there is no activity?
I had this issue once.
Isn't this a color printer? Isn't it supposed to print in color?
Jul 25, 2008 | HP LaserJet 2550L Printer
Need installation software
Kevin download drivers and software to suit HERE - please rate
In case I stuffed the other link link
Dec 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP LaserJet 2550L Printer Logo
260 people viewed this question
Ben Johnson
