coils burnt on these at times, also check for grond strap coil grond into cap (is itmissing strap?) check 2 wire harnesses inside dist.
was it running before and is it running now?
to install SM BUS controller driver you need to install chipset driver of your motherboard. It is also used to install Audio devices. Go to the compaq website and look for your make model and install the requied driver
Hi, You need to install the chipset drivers before it will take the audio driver. Go here to Acer support, download and install the chipset driver, then you can install the audio driver >>>>>>>
disconnect your batterys grond cable first. Next remove the wiring from the starter. Next you will need to remove the two starter bolts running upoward to the engine. Take note if any shims are there which I doubt. Reverse proceedure to install
the final stage resistor on all BMW blower motors controls everything (power and grond ) 99% of blower motor issues is the resistor. not to hard to install either.
I am having HP pavilion dv6915ee laptop. I have installed windows Xp and installed all device driver except sound driver. When I try to install it It is asking to install the microsoft bus driver before installing audio device. Please anybody help me to fix it.
goto to system devices look for the question mark, right click, and try reinstall the drivers again, this should normally work and reboot your machine and the drivers should be there.
may be the bus driver you are trying to install may not be compatable for your machine, check with the user manual to see what bus derivers you can install
