Canon Pixma MP500 All-In-One InkJet Printer Logo
Anonymous Posted on Feb 16, 2011
I have an error on my canon pixma mp500... it says The type of printhead is incorrect. Install the correct print head. I bought some ink that says that it is compatible for my printer and when I tried it out it worked. A day later I got this error...any sugggestions that might help?
Anonymous
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on Feb 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
29
Questions
Helped
7529
Points
96
I would like to suggest that u should not use any alternate cartridges, plizz buy the originally manufactured ones, else ur printer could get damaged! the reason being that the ink head of some compatible cartridges short circuited very easily compared to the genuine ones, and a fake cartridge could damage ur printer in an instance! so, be careful!
  • Anonymous Jun 05, 2011
    This is not dealing with the question and is nonsense. Sure, some after-market inks may be poor but certainly not all and they're a 10th of the price saving the price of the whole printer in very little time.
1helpful
The type of print head is incorrect. Install the
yes . put exactly the cartridge that is compatible with your printer , make sure that you are replacing with the one that has the same number on it as that of the previous cartridge
I have an printhead error for no reason. Please advise. The message says "The type of print head is incorrect. Install the correct print head.
There is always a reson. Try checking that the cartridge you installed is the correct one for your printer. Some refurbished also cause this problem as they have been recycled too many times.
Please rate my help++++Thanks for using FIXYA
4helpful
6helpful
Error msg - Print head is incorrect.
The printhead has gone out, you need a replacement, # QY6-0059-000. Around $50.00
4helpful
Incorrect printhead
It just means that the printhead is defective, All of the Canon machines say that when the printhead goes out.
2helpful
Canon Pixma MP500 error
ok I figured out what to do. Open the over take out all your ink cartriages. Then flip the print head level on the left hand side up and squeeze the top of the print head (where all your ink sits on) and lift it up. You may want to blow off any dust that may be in there and put the peint head back and replace al your ink put the level down and you should be good to go if not you may have to replace the head.
18helpful
3answers
CANON MP830 all in one is sayin" the type of printhead is incorrectn Install the correct Printhead."
Hi follow the instructions as above...
ie Remove inks and print head...
But instead...
Whilst Canon print head is out...
Use cotton wool and alcohol and clean electrical contacts on back of print head and where they make contact inside printer.
Then install print head and inks and test.
If it does not work you may need to replace print head.
Hope it helps!
Good Luck!
John
https://magicinkjetflush.com
1helpful
My Canon PIXMA MP830 all-in-one is saying "the type of printhead is incorrect, install the correct printhead."
The cartrige is what holds the ink, the printhead is the device that puts the ink onto the paper.
So if your out of ink, then you need a new cartridge, if you have a new cartridge and you are having issues printing good quality, then you may need a new printhead.
you can get the ink here: http://printerinkcartridgesearch.printcountry.com/canon-pixma-mp830-ink-cartridges.htm
printhead is about 49.95
http://www.precisionroller.com/k_canon_pixma_mp830_print_head/m114d8577c104/
Hope this helps!
Brad Nelson
36helpful
4answers
Error: The type of Printhead is incorrect, Install the correct printhead.
Ok i know this is kinda old, but i found a solution.
First to those people to state I found a solution from hp, cannon etc etc and not give out the direct link, or instructions, then whats the point fing posting????
This error happens when you install an oem cartridge onto your system. Or havent used it in a while, so the machine is somehow misfigured.
This solution is for canon mp800, simply switch off printer. HOLD stop/reset and press and HOLD on/off button. release stop/reset. Now press stop.reset twice. then release on/off button, press stop/reset 4 times, wait 20 seconds, press on/off button twice.
switch machine back on and the printer should find the cartridges.
This method maybe the same for your mp*** if not google RESET CANON PRINTER MP*** and you'll find the correct buttons to press.
here's a printer on reseting a bunch of canon printers http://tricks-collections.com/reset-printer-canon-mp140-mp160-mp180-mp210-mp220-mp460-mp470-mp500-mp510-mp530-mp600-mp610-mp800-mp820-mp810-mp830-mp960-mp970/
good luck.. and FU canon for adding you scamming chips into cartridges.
old marine
old marine
ZJ Limited
ZJ Limited
