Question about Whirlpool Kitchen Ranges
Main oven of Whirlpool AKP 951 not working. It tripped circuit and fan appears to still be going round but no heat.
  • 4 Answers
Hi
I had the same problem and it turned out to be an open circuit oven element. This is fairly easy to replace yourself and should cost £30-£40 for a non Whirlpool replacement. Takes about twenty mutes to do once you have taken the oven out of its housing.
Hope this helps!
Posted on Sep 14, 2009
Whirlpool Absolute Built-In Oven in Stainless Steel AKP 7460 IX user manual ?
Dalene, we recommend the link below for the User Manual.
http://www.whirlpool.co.uk/appliances-1/ovens-3/whirlpool-absolute-built-in-oven-in-stainless-steel-akp-7460-ix/857774601700/
Jan 16, 2018 | Whirlpool Ovens
Bosch HBN7052 - main fuse tripping even after replacing the heating element
It appears there is too much current (electricity) being drawn towards the element, seeing once you replaced it, it worked fine for 5 minutes and then tripped again...I believe the problems lies within the wiring going towards the element, or the thermostat that controls the amount of current coming towards the element. Instead of turning off at a desired temperature, its not and continuing to heat up to the point of tripping the fuse. Try replacing the thermostat.
Dec 01, 2013 | Bosch Ovens
When i switch the oven on the oven trips the main circuit. the oven used to work normal then it started to trip out after it had been on for a long period. you could leeave it off for 10 mins then it would...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Feb 15, 2010 | Candy F248P Electric Single Oven
Beko dvc62 main fan oven stopped working, doesn,t get hot but fan still works, it tripped circuit breaker and hasn,t worked since, peter
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer
Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 14, 2010 | Ovens
No heat in main oven, fan is working ok as is top oven. main oven was working ok then power was lost due to circuit breaker tripping??
You need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
Dec 20, 2009 | Neff U1721 Double circotherm Electric Oven
No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Apr 12, 2009 | Ovens
SMEG SA410X-S heat not coming on for fan forced cooking. The fan and light work, and the heat works fine for grilling.
The fan element (round) is more than likely blown. Open the oven door, take the rear cover off inside the oven (covers the element) and have a look at the element with a torch. If it is buckled, warped or has a blow hole in it, then it's faulty.
Mar 18, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Plz rate my solution.
Thanks.
Dec 18, 2008 | Whirlpool AKZ159IX Oven
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Kitchen Ranges Logo
381 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
