The assumption is you are using Unity connections.
Complete these steps in order to change the speed:
In Cisco Unity Connection Administration, find the user account or
template that you want to edit. On the Edit menu, click
Playback Message Settings. Set the Message Speed to
Normal.
If the users make any changes while they listen to voicemail, they
are saved. In order to disable this, you can go to Advanced
> Conversation > Save message playback Volume
and Speed. Uncheck this to ensure that the changes made by users are
not saved permanently.
If you are not an administrator, you can press 4 or 6 during the message to speed up and slow down.
go into the menu and set the playback speed to normal,not fast or slow,if its a tape machine,set the speed using the small switch on the side that says 2.4/1.2
You should use the computer with Digital Voice Editor software to have more options when trabscribing. You could then use the transcribing keys to playback your recordings and regulate the velocity of the playback.
Download Digital Voice Editor Version 3.1.03 for Windows Vista/XP/2000. 64 bit version operating systems are not supported, though
Press RECORD/PLAY Button to switch from Record Mode to Playback Mode.
The Playback Mode is for viewing and managing movies and pictures as well as listening to voice and
music on the built-in memory or on an optional memory card.
Operation Display Screen
Press RECORD/PLAY Button ( ) to switch
from Record Mode to Playback Mode Main Menu.
• There are 4 options in the Playback Mode, movie,
picture, music and voice.
• Direction Buttons can be used to select the
specific option.
• Press OK Button to view movies/pictures, listen to
voice or music.
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
