Cuts out when hot
Vw polo 1.6l year 2002
  • 417 Answers
you can try and take the access cover off the amp portion of your speaker set, try and run the speakers with it off and see if that helps. You can try drilling some additional air vents in the amplifier section of your speaker set, I would take the computer amp box apart first to make sure your clear of any wiring or obstruction, and drill holes in the cover you just removed, maybe if you have a spare cpu fan or something you could build a little vent system for your speakers' amp.
good luck,
J
Posted on Jul 26, 2008
Vw polo 1.9 di year 2002 started losing power for 3 to 4 miles then cut out will start and run for 3 or 4 secs then cut out
Sounds like the fuel filter is plugged up. replace with new filter. also check air cleaner. Also try a few bottles of Heet dry gas in case this is a water in fuel problem. Try the dry gas first.
Oct 06, 2016 | Cars & Trucks
I have a vw polo 2002,when stuck in traffic or after long drive,the ar goes off
does the temp gauge reach the red area? check eng coolant .Over heating could cause eng to cut out so as not to cause more damage check the cooling system.When travelling slowly or at stand still turn heater to max heat and max speed this will cool eng but is only a temporary solution
Mar 26, 2014 | 2002 Volkswagen GTI
Vw polo engine 2002 model
clean your throttle body .build up of carbon.try a fuel system cleaner in your fuel tank first.
Dec 15, 2013 | Cars & Trucks
VW POLO classic 2002 model(old shape) switches off wile driving what could be the problem
hey , i have a vw polo 1997 and the all the clocks, (rev,speedo,fuel and temp gauge ) will cut out is this a ecu fault as i found it was wet ??
Apr 16, 2012 | Volkswagen Polo Cars & Trucks
I have a vw polo 1.2 year 2002 and the heater is blowing out hot air no matter where dial is set thanks
the flap isnt closing for whatever reason ,ask a local mechanic to have a look for you
Jan 08, 2011 | Volkswagen Polo Cars & Trucks
2002 VW Polo - EPC Light and Loss of Power
It is a wiring fault, but they are looking on the wrong end. You will need to have a VW dealer "repin" the electrical connector at the throttle body. What this means is, the dealer will take apart the connector, cut off the old pins and crimp on new ones and reassemble the connector. This is a common problem on drive by wire VW's. The dealer has a bulletin on the problem and I don't know why they missed it. They will probably have to order the connector kit however. Good luck!
Feb 06, 2010 | 2002 Volkswagen Golf
02 VW Polo 1.2 steering wheel warning lights on
Red this article:
Eventhough the level is right, the fluid might need replacing (every 3~5 years and 50.000-100.000 miles).
You can read how to recognize bad/old fluid here: http://www.hondaclub.com/forum/articles/1492-power-steering-fluid-lifeline-your-steering-system.html
Aug 25, 2009 | 2002 Volkswagen Golf
I can hold the speed above the 40
The VW is the problem. Put a Dodge in your garage!
Jun 09, 2009 | 2002 Volkswagen Beetle Turbo S
VW Polo Map sensor fault code idling pooly
Hi, I have a 2001 polo 1.4 mpi it lackes power when you hit a hill it just dies, It has had new cat, fuel filter, fuel pump and throttle body, but is still the same it just dose not want to give me full rev's?
Mar 30, 2009 | 2002 Volkswagen Golf
93 people viewed this question
 Grubhead
Grubhead
