Hi a lamp was left on and its damaged the jog wheel on my cdj. is it possible to replace the jog wheel ? if so how much does this usually cost? Thanks
    Scholar:
  • 154 Answers
What sort of unit is it? Make and model. Most just pop off but not all. Some have a small c pin holding them on and if you try to force them you will brake the jog wheel
Posted on Jul 25, 2008
My cdj mk1 jog wheel is stiff when turning an scratchin.
One or more of the bearing wheels have become damaged underneath the jog wheel. You need to strip the unit down and remove the wheel to get access to find the broken / stuck wheels. Replace, or re-seat, and you should be back up and running. The jog wheel is a lot simpler than it looks, once you have it out. Just be careful of the sheet switch, which detects pressure on the wheel. They're very fragile and vulnerable!
Apr 02, 2011 | Pioneer CDJ-1000 CD Player
My jog wheel sticks / doesn't glide like it should...
I had the exact same problem. I was working a party when some drunk ******* spilled some beer in my coffin case, thus getting into the jog wheel and cue button. I continued to work with it for a few months but got pretty fed up and brought it to a pio dealer. They fixed it up quick and cheap, now it glides like my other mk3s. I'd say bring it in a get a quick quote.
Mar 31, 2010 | Pioneer CDJ-1000 CD Player
Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 28, 2009 | Pioneer CDJ-800MK2 Turntable
Pionee cdj-100s jog seems to be lagging
pull the jog wheel off and give it a clean and some grease on the shaft, also don't push it back down the whole way
Aug 26, 2009 | Pioneer CDJ-100S CD Player
Pioneer CDJ-1000 CD Player jog wheel display
The only way of solving this is to bring it to repair shop and get a replacement screen.
Jan 30, 2009 | Pioneer CDJ-1000 CD Player
Cdj mk3 jog
Does the jog wheel lcd light up ?
Regards.
Paul.
http://www.audiovisualservices.info/
Dec 27, 2008 | Pioneer CDJ-1000 CD Player
CDJ800 vinyl modus
Hi Mate
My last post was a CDJ with a separate fault, causing a similar type fault.
99% of the time, this particular fault is the Flac switch under the platter jog wheel, take the jog wheel apart clean the plastic strip that runs around the jog wheel, the one with rubber feet that activates as a pressure switch.
Often there is air bubbles, liquid, condensation in between the two layers - causing it to stay in touch mode. If that doesn't fix it then you need to replace that strip (pressure switch). They are about £30 quid.
All the best and good luck
Dec 04, 2008 | Pioneer CDJ-800 Turntable
Pioneer CDJ 1000 - Jog Wheel not working.
Take it to your nearest pioneer repair centre as this liquid will have to be removed before it causes further damaged, you can send it to us if you havent had it repaired.
Regards.
Oct 26, 2008 | Pioneer CDJ-1000 CD Player
CDJ 800 JOG WHEEL IS not working
sounds like the jogwheel sensor,if you havent had it repaired you can send it to us.
thanks.
May 06, 2008 | Pioneer CDJ-800 Turntable
 Grubhead
Grubhead
