Question about Lexmark E232 Laser Printer
Light error I have lost the manual for my Lexmark E232 printer. I have installed a new ink cartridge in there but the printer will not print. The light second up from the bottom is permanently on and I don't know what it is. Can anyone help please? Lin
Open the rear door, you might have a paper jam. I did not even realize there is a rear door. You can have a paper jam that only can be found by opening the rear door.
Posted on Aug 11, 2008
    Sergeant:
    Champion:
  • 221 Answers
You should contact Service Center regarding this.
Posted on Jul 25, 2008
Hi, My Lexmark E232 printer is on but will not print. The light second from the bottom is orange. Help!!
That second from the bottom orange light indicates a paper jam. Press Continue to resume printing once all the jammed pages are cleared from the paper path. Press Continue twice quickly to see the secondary error code. See "Secondary error codes" on page 69 of the user manual for more information.
Here's a link to the manual: http://www.lexmark.com/publications/pdfs/e230/eng/ug.pdf
Mar 21, 2011 | Lexmark E232 Laser Printer
The second light on the front panel of our Lexmark Laser Printer E232, Machine Type 4505 is continuously blinking yellow. It is the picture with the ink cartridge - which I have changed. The cartridge...
The light sequence means that the photoconductor kit's drumis full and needs replacing. Press to continue button to resume printing. Ifprint won't work you need to replace the photoconductor kit. For further assistance,please contact Lexmark Technical Support.
Feb 04, 2011 | Lexmark E232 Laser Printer
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Mar 04, 2010 | Lexmark E232 Laser Printer
Putting a E332 cartridge into a E232 Lexmark Printer, it doesn't
Return it. The E332 and 232 cartridges are the same size and shape but are not the same. You will get tons of errors.
Nov 02, 2009 | Lexmark E232 Laser Printer
E232
I have the same problem. At least not it's printing but the lights still on. But while researching on the Lexmark Website I see that this printer has a recall. Check the website for additional details.
Sep 30, 2008 | Lexmark E232 Laser Printer
Printer not printing
you might need to check your driver if it is install correctly for the correct OS, i'm not sure what OS you are using but below link might be helpful to help solve your issue
http://etech.maiila.com/?p=42
all the best..
p/s please rate me...
May 29, 2008 | Lexmark E232 Laser Printer
Printer will not operate.
With this model, it is a Toner cartridge, you need to be more specific in what the error is.
Mar 25, 2007 | Lexmark E232 Laser Printer
Lexmark E232 Laser Printer Logo
260 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
