Question about Nokia N95 Cellular Phone
No display on screen nokia n95 8gb
The phone switches on, i know this because i can hear it and the buttons light up, however there is nothing on the screen, its as if it's switched off.
If i take it into a store to be repaired will they delete all the songs, pictures and videos?
  • 1 more comment
  • seosniper Jan 09, 2009
    I also have the same fault and can only view the screen if i run it through a tv using the phono leads provided.
  • Anonymous Apr 17, 2009
    same problem n95 8gb
  • georgalee Apr 18, 2009
    my Nokia N95 first strated not telling me i had recived a text message and then the screen would make all black blotches so that i could not see anything. it now has completely shut down the screen so that i cannot see anything, although i can call people by typing in their numbers because i cannot go into my phone book on my phone. i can recieve calls but cannot always make them only when it chooses to let me itself. it makes funny beeping noises when im not using it and when i turn it off, sometimes an alarm will go off even though the phone is off and i havent set an alarm, the alarm may have been from a previous setting the last time i was able to set it befor ethe problems started to occur. please help me. i tried putting all my details from my phone onto the computer, i saved all my images but was unable to retrive my contact numbers and text messages. the screen looks like its cracked but its not because when i press on it,it just makes funny lines and patterns with some colours apart from being black. please help what can i do?
    Sniper:
  • 87 Answers
Most likely the data on your phone will be wiped out.
just do a back up on your phone by connecting it to the computer.
use the tv cable adaptor and connect it to your phone to see the content on your phone with the use of your tv whilst using the usb cable to connect your phone to the computer.
Posted on Aug 15, 2009
SOURCE: nokia n95 8gb
hy i have the same proble with security code my imei it is 359980101771319 my emai it is eutudb23@yahoo com or the im id it is eutudb23
Posted on May 28, 2008
SOURCE: MY nokia N95 8GB Front cam
My camera started working again !!
Originally my n95 8gb is the rm-320 (or n95-2 8gb), I changed the region code of the product so I could use spanish language on it since the beginning and it all worked fine.
After the 15.xx xx firmware messed it up, and installed firmware 20.xx and did not fix a thing in the phone.
I was almost resigned until last weekend, I ran out of battery and the only charger I had in hand was an E65 , which uses a lower ohm/amperage
and then two days later the camera just started working again !
MHhhhhh strange thing, but now that i recall, when charging with the original adapter the screen sometimes used to flash a bit, as if it was some electrical deficiency or excesiveness.
greetings and hope this helps you, I will NEVER update firmware again, thats what i´ve learned from this model.
Posted on Jun 04, 2008
mohammed387
  • 1952 Answers
SOURCE: puk code for nokia n95(8gb)
12345
Posted on Aug 27, 2008
rawrskiis
  • 87 Answers
SOURCE: nokia n95 8gb lcd is blank but i hear it's turning on
if its blank you have to replace the lcd screen with a new one.
sometimes it maybe a flex cable problem which occurs in some slide phones.
at mobile phone repair stores, the cost of an original lcd screen replacement is usually $150-$200, though sometimes an original lcd screen may not be fitted into your device but rather a hong-kong made one which is similar to the original but is less brighter and a little less sharper.
if you take it to a nokia care centre to replace the lcd screen you may have to pay over $250.
you can just buy an lcd screen off ebay, replacing the lcd screen yourself isnt hard with the tools provided. you just have to take the ribbon cable from the old lcd screen and insert the new lcd screen and plug in the ribbon cable for it.
the reason for original Nokia n95 8Gb lcd screens being so expensive to repair/replace is that it is also the same lcd screen used for the Nokia N96.
cheers.
SOURCE: nokia n95 8GB no display
if you hear the audio,then it may the problem of display contact.so treat it with an hardware expert
Posted on Sep 27, 2010
Nokia c7 showing empty screen on start up
Your phone formate:-
Step by step.
1.Phone Keybord (Right Side 'Call')
2.Type: *#7370#
3.Then 'Yes'.
4.Restart your phone with solve your problem.
Feb 26, 2013 | Nokia C7 (8 GB) Smartphone
Tip
How to know if the problem of nokia phone is LCD display or corrupted...
how will you distingguish if your nokia phones problem is LCD or corrupted software if it is in white scrren or blue screen status?
here "s how...
1.removed sim card
2,dial 112 or 117 ,it defends in your country if what is the emergency hotline..
3..if you hear something from an operator ,it is display problem...change a new one comes from working unit ,if still no display it must be display driver (a small chips that makes lcd display functioning)..
4..if you hear nothing ,its your phone software isa the problem...
on Jun 14, 2010 | Cell Phones
I can phone out but i dont hear nothing and there is a headset icon on the screen that wasnt there before
oki its easy... Surely, you must hear when you put on your earphone.. it is a misjudgment of your phone system... to SOLVE this, : 1. SWITCH OFF YOUR PHONE. 2.REMOVE YOUR BATTERY FOR 1 MINS. 3.REPLACE AND SWITCH ON.. 4.PROBLEM SOLVED. 5.PLZ plz leave good feedback.. thanks...
Oct 25, 2010 | Nokia 6021 Cellular Phone
My nokia n72 phone's flash is not giving proper light when the flash is on.Rather it gives a faint light.pl.solve my problem
please format the phone , use this code to format the phone
first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
then try to use the camera and check the flash,
if the problem check the flash hardware
Oct 25, 2010 | Nokia N72 Cellular Phone
Hi! I have a problem with my Nokia 7370 : the screen is blank and nothing is happening. I tried switching it off, then on again, but no luck, I have nothing but a blank screen. Even when I plug the battery...
can u hear any sound like nokia tune which comes when u turn on your mobile? It could be because your display is damaged or not working so please visit nokia showroom and they will help you.
There can be several things which can be reason for blank screen like:
1. Your display is not working
2. Battery of mobile is not working.
3. May your mobile is not charged and charger which you are using is not working. Try charging with some other charger of nokia same pin.
4. It could be software issue. Please update software in your mobile.
60% it could be a display issue.
Jul 21, 2010 | Nokia 7370 Cellular Phone
I dropped my n95 and now it will not switch on it makes a noise but nothing happens ie screen doesnt light up
May be you display is with a problem. Visit the nearest Nokia care and the service personnel should help you out..
Thnks - billa
Jul 07, 2009 | Nokia N95 Cellular Phone
Only white light appears nothing else appears.
hi
first try to connect to a pc using the usb and check if u can get connected and browseif this works then there is a problem with the display else the OS of the phone is lost
beware that all your data will be lost on the phone if the following procedure is followed
hold the green button '3' button and the '*' button simultaniously and then power on the device hold the keys till 'FORMATTING' is displayed on the screen
hope this helps
Cheers
Jun 17, 2009 | Nokia 3230
How to format nokia6300 mobile phone
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons
Aug 12, 2008 | Nokia 6300 Cellular Phone
I see nothing on my nokia 6630 screen..
Try to do a master rest on the phone.
Dec 16, 2007 | Nokia 6630 Cellular Phone
Nokia N95 Cellular Phone Logo
2,326 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
