SOURCE: Reassembly of brush roll bearing/washers on Hoover Runabout
It will make no difference which direction those washers are installed, just that they are installed.
SOURCE: Visible dirt escaping from hose wand.
http://www.bissell.com/images/UserGuides/3574-3576_1005.pdf
check out the user manual to fix this
SOURCE: Dirt Devil overheating Belt Okay
the belt is probably worn , so when the spool turns it heats up and looses friction with the belt.
SOURCE: Ran over a cord. Wrapped around the roller brush.
it was the belt should cost a few dollars at bimart or like ace you can do this by taking rollers out from bottom of vac. u can use a butterknife to unscrew it ull see the belt.
